The Official Core 2 OverClocking Database *READ 1st Post for Instructions*
UPDATE:
Added: Rats, Forsaken1 (2nd Entry E6400, 1st Entry was X6800, try to get the bios version i just put the date you listed for now thanks), aldy402 (just put 3,600 might be more though, i just put what you claimed), AndyM (2nd Entry WaterCooling D-TEK, 1st Entry was E6600 3.6GHz).
Deleted: None.
Editted: menlatin (changed brand of RAM to Patriot was Corsair)
First post of thread reflects current changes. Please REFRESH! (database and summary pic will change)
Panzer_V you need to run two instances of Prime95 for dual core for over 4 hours here is a good tutorial:
http://www.playtool.com/pages/prime95/prime95.html
mccorry you need a pic please post when you are ready with your pic so i can add you thanks...
Hey, not sure if I'm ready to post this yet since I'm planning on improving it more. But I got fed up with the ds3 and my buffalo blew up, so here's a new screenshot I did:
It's 8x425=3400 e6400 es 5b1 l617 a856 1.4v actual water swiftech apogee p5b vanilla 1102 bios
win2k3 again. ocz 8800 this time. 1:1 425mhz (850) 4-4-4-4 4-20-3-9-4-10 (memset shown just for reference but actual values set in bios).
2.29v actual vdimm.
1.25vmch, 1.2vfsb, 1.5vpcie, 1.057vich
large fft orthos 16 hours (been longer but never screenshotted)
Currently, I'm unable to go much beyond 450fsb, so I had to settle at 8x425 with the weaker strap performance. I hope to look into actual vmch values and hopefully be able to run 7x485=3400 or better.
ram ic is d9gmh
edit: forgot validation: http://valid.x86-secret.com/show_oc?id=176368
edit2: forgot about the format. I realized it was a bit messy so here it is:
User Name: ziddey
Stability: 16+ hours orthos large fft
CPU: E6400
OC: 8x425=3400
Stepping: 5B1
Week: L617
Code: A856
Vcore: 1.40v actual (might be able to do lower but haven't tested)
Cooling: Water
Cooler brand/model: Swiftech Apogee
Motherboard: Asus P5B Vanilla
Bios Version: 1102
Operating System: Win2k3 x86
RAM brand: OCZ
RAM rated speed: 8800 (1100mhz)
RAM actual speed: 850
Latency: 4-4-4-4
24hr
in the cooler mfrs, Sunbeam and Tuniq should be combined. they are the same company.
yes you are right thought about it for awhile was gonna make the change but never got to it...... mentok1982 probably didnt know that it was the same company... real name is
sunbeam tuniq tower 120.... thanks for your concern
Ok
I give up on how to identify the stepping my chip is
SL9S8
L639F039 so far in the database that Kyle is keeping there isn't any e6600's
with code F039
SO someone give me a clue :p
LOL
http://edspc.net/core2.JPG
New to this.... so bear with me.....
CPU: E6400
OC: 3008 MHz
Stepping: 6B2
Week: L629
Code: A997
Vcore: 1.325
Cooling: Air
Cooler brand/model: Thermalright XP-90C
Motherboard: Gigabyte GA-965P-DS3 Rev 3.3
Bios Version: F9
Operating System: Vista Home Premium 32-bit
RAM brand: Corsair
RAM rated speed: 6400
RAM actual speed: 940
Latency: 5-5-5-15
Orthos 7.5 hours stable.....
User Name: Panzer_V
Stability: 4hours+ Orthos
CPU name : X6800
OC: 3500Mhz
Stepping: 5 B1
Week: L617
Code: A778
Vcore: 1.420
Cooling: Air
Cooler brand/model: Tuniq Tower 120
Motherboard: Gigabyte GA-965P-DS3P
Bios Version: F4
Operating System: XP 32
RAM brand: PATRIOT
RAM actual speed: 1000Mhz
Latency: 5.7.7.20
http://valid.x86-secret.com/show_oc.php?id=177092
I started the orthos today after work but still running orthos ; )
User Name: AliP
Stability: Orthos Beta (Dual Core one) 10hrs and 45min so far
CPU: E6600
OC: 3200Mhz
Stepping: 6 B2
Week: Doesn't look like ill be able to find this one out
Code: Doesn't look like ill be able to find this one out
Vcore: 1.3250 (stock)
Cooling: Air
Cooler brand/model: Zalman 9700 (black one)
Motherboard:eVGA 680i
Bios Version: P25
Operating System: XP32
RAM brand: Crusial Ballistix
RAM rated speed: 8000 (running at 800 now)
RAM actual speed: 800
Latency: 5-5-5-15 (Can handle more but I don't want to have to stress my memory or give more voltage.
Pics, link;
http://valid.x86-secret.com/show_oc.php?id=177368
Is there any way to find out that Week and code other that disassembling my PC? Btw. This was my first oc :D
Yes, if you kept the original CPU box. The info is written on a label and match the writings on the CPU.
User Name: unclewebb
Stability: 4hours+ Small FFTs Orthos
CPU: E6400
OC: 3520 MHz
Stepping: 6 B2
Week: L633
Code: A988
Vcore: 1.5250 v bios
Cooling: air cooled
Cooler brand/model: Intel OEM heatsink & fan
Motherboard: Asus P5B Deluxe
Bios Version: 1004
RAM brand: Team XTreem
RAM actual speed: 880
Latency: 5-5-5-18
My first try at 3520 MHz was stable for 10 hours but unfortunately Windows adjusted the system clock by 3 seconds during the run so it looks a little suspicious.
Hopefully this second run is enough to get me into the [H] OC database as one of the quickest Intel cooled E6400 chips.
http://valid.x86-secret.com/show_oc?id=177525
Here are the motherboard settings I used:
MEM = 2.25 volts
CPU = 1.5250 volts
FSB Termiination = 1.40 volts
Northbridge = 1.55 volts
Southbridge = 1.60 volts
ICH = 1.215 volts
Memory Timings = 5-5-5-18 and 6-42-10-10-10-11
Enabled C1E, CPU TM, Execute Disable bit, PECI, Speedstep
Disabled = Vanderpool
UPDATE:
Added: ziddey (2nd entry, new asus mobo, and ocz ram <-- very nice sticks!), mccorry (wanted cpu-z but ill just accept you even if you have the everest cpuid, but next time show cpu-z!), Panzer_V (nice mobo!), AliP (good oc for first time, but i need week and code before your entry can be color green, its hard to determine the week from newegg, they have so much cpus in stock), and unclewebb
Deleted: None.
Editted: None.
my e6600 is at 3.6ghz daily now on air.. tuniq tower 120... temp in home is around 80*F cpu idle temp is 65*C is this allright? will i shorten the life of my cpu...
yes and you will also shorten your own life by living in that furnace
hahaha your funny rats.... well we will see how long this chip will last... i live on a tropical island it burns everyday... coldest it ever got one night was 73*F haha... maybe ill invest in an A/C unit for my computer room....but dont want to spend alot on power :(
User Name: n7/sardonic.n7
Stability: 8 hours+ Blend Orthos
CPU: E6600
OC: 3501 MHz
Stepping: 6 B2
Week: L632
Code: B173
Vcore: 1.45V bios/1.38V load
Cooling: Air
Cooler brand/model: Thermaltake Big Typhoon w/ Noctua NF-S12
Motherboard: P5B Deluxe WiFi-AP
Bios Version: 0711
RAM brand: Team Xtreem
RAM actual speed: 972.5
Latency: 5-4-3-4
CPU-Z validation: http://valid.x86-secret.com/show_oc?id=179300
User Name: ziddey
Stability: 4 hours orthos large fft and going
CPU: E6400
OC: 3500MHz
Stepping: 6 B2
Week: L628
Code: A901
Vcore: 1.456V
Cooling: Water
Bios Version: 1102
Operating System: 2K3
RAM brand: OCZ
Latency: 5-5-5-15
Will repost screenshot after 24 hours hopefully.
This is an update to my earlier listing of 8x425=3400 on the p5b vanilla.
I've found that enabling spread spectrum allows my p5b vanilla to go from 460fsb max to around 520fsb. Unfortunately, performance isn't spectucular, due to 1333strap.
This listing is not fully tuned and tweaked in terms of memory timings and voltages. It was an initial attempt at 7x500=3500 stability, but should update the existing 8x425 entry well, and does prove the point of the c2d's overclock.
It should also be noted that there's something wrong with my apogee waterblock and temps I've been seeing recently are way higher than when I initially started using the block in January. I used to be able to run 1.55vcore and still keep under 60'c under full load.
I did run orthos along with 3dm2k3 last night for 10 hours, but since it was a custom test (8-1024 in place, 5 minutes), I didn't bother screenshotting. Currently, this is large fft that is about 4.5 hours already, and shows no signs of instability.
edit: It is a different cpu than in the previous listing, but I hope to sell that one soon. Surprisingly, both cpu's have had nearly flat IHS's and similar temperatures under the same conditions.
update: 16 hours and going
update: I was still sleeping when it hit 24 hours. When I woke up, the screen was blank (from power saving) but system was locked up. Reset does nothing. Had to cut power from back. It came back at 7x500. I got fed up and tore the motherboard out and alcohol washed the entire motherboard. Looks like now it's doing 500fsb without spread spectrum, although it sometimes won't post. I'm working on that, but it's definitely an improvement over before, when I needed spread spectrum to post 500fsb.
I tried low voltages (mch, sb, ich, fsb) and it locked up in the same fashion really quickly. So I'm imagining the lockup I had last night (I checked orthos log and it looks like it locked up after 26 hours) was due to motherboard issue.
edit: damn, looks like 500fsb is no more. I can't maintain it stably anymore at all. I'm pretty sure the cpu is stable though, but I guess hold off for now. I'm testing 7x438=3066 right now with everything relaxed to make sure 438 is stable, so I can prove 3.5 first. Can't wait for dfi to come out...
Hi peoples. I'm back with new result
User Name: Gam3Ra
Stability: 8hours+ Orthos
CPU name: E6400
OC: 3600Mhz
Stepping: 6 B2
Week: L631
Code: B102
Vcore: 1.336 by CPU-Z, 1.332 by DigitalMultiMeter
Cooling: Air
Cooler brand/model: Noctua NH-U12F
Bios Version: 1004
Operating System: Vista Ultimate
RAM brand: Patriot
RAM rated speed: PC6400LL
RAM actual speed: 900
Latency: 5-5-5-16
2nd Entry
This is my buddy's E6300, the batch # is L28 but the rest is unknown cos this cpu was lapped.... It was watercooled using Swiftech mcw5000 waterblock and Bix 3 radiator with 3 120mm 121cfm fans .... The radiator is outside my window with 363cfm of 5c air blowing at it, watertemp during orthos was 8c:D
User Name: luihed
Stability:4 Hrs Orthos
CPU name: E6300OC: 3780mhz
Stepping: 6 B2
Week: L628
Code: ???
Vcore: 1.61v
Cooling: Water
Cooler brand/model: Swiftech MCW 5000
Motherboard: Asus Commando
Bios Version: 0702
RAM brand:Crucial
RAM rated speed: PC5300
RAM actual speed:1080
Latency: 4-4-4-8
Screwed up saving the whole screen lol....
About 30s after turning off Orthos....
Im working my way up.
User Name: LOCO LAPTOP
Stability: 4hours+ Small FFTs orthos
CPU: QX6700
OC: 3555
Stepping: 7B3
Week: L635
Code: A676
Vcore: 1.45
Cooling: Water
Cooler brand/model: Apogee GT
Motherboard: BFG 680I
Bios Version: P26
RAM brand: Gskill
RAM actual speed: 820
Latency: 5-5-5-12
Some nice overclocks... I'm really debating switching over to one of these chips in my desktop setup :)
UPDATE:
Added: n7/sardonic.n7, moe.ron, luihed (2nd entry, seem that every cpu he touches he makes them fly!! nice work top E6300!!! but sorry entry is in Black since you couldnt get the Code, maybe finding the retail box can get the Code?), LOCO LAPTOP (you spelled Apogee wrong but its cool corrected it, Fastest QX6700! )
Deleted: None.
Editted: ziddey (changed to 3,500MHz, also changed your Week and Code to what you stated, and changed your RAM speed good job so far :) dont worry 26 hours is stable enough! and yes i always liked DFI good things are to come :D )
Gam3Ra (changed to 3,600MHz, changed bios, changed OS, and RAM Speed)
drizzt81 not enough info to be posted into the db sorry!
Highest I can get so far without crashing.
CPU: QX6700
OC: 3600 *better speed :) *
Stepping: 7B3
Week: L635
Code: A676
Vcore: 1.504 *higher voltage*
Cooling: Water
Bios Version: P26
RAM brand: Gskill
RAM actual speed: 842 *higher speed*
Latency: 4-4-4-5 *better timing*
Videomasterz, the whole code is L628A221..... I knew he had the box somewhere cos he's chinese....lol ( me too..)
New E6600 CPU, L644F262.... getting later in the production year, 44th week.
So far, 3GHz (9*333MHz) Orthos stable for 4 hours @ 1.375 Vcore.
I'm pretty happy with the ease of getting to 3GHz, and hopefully looking to get 3.6GHz later this week. Seems the "F" code CPUs are nothing to be scared of, thankfully.
(Not looking for database entry yet, more of a info post for people looking for F-code CPU info, feel free to nuke this post if warranted)
Only one other MSI board on record...makes me kinda sad :(
Username: ANewPrelusion
Stability: 7 hours+ Small FFTs Orthos
CPU: E6600
OC: 3608 MHz
Stepping: 6B2
Week: L629
Code: B379
Vcore: 1.43
Cooling: Air
Cooler Brand / Model: Coolermaster Hyper 6+
Motherboard: MSI 975x Platinum V.2
Bios Version: 7.16 Beta
RAM Brand: Corsair
RAM Rated Speed: 6400
RAM Actual Speed: 802
Latency: 4-4-4-12
Backup Link:
When using Orthos it says I'm runing 400 Mhz faster than I am.
Anyone have a solution to this?
When testing at 3.2 it reports 3.6
