Very nice, w1retap. What's the specs?
Awesome w1retap, Specs?
Technically mine is still a Lian Li, so...
Here it is before:
Not sure which model it is - got in 2000 or so.
Here it is currently:
It is still a work in progress.
I love my old 602. When I get around to doing my i7 build It will go in my old school Li. I've been shopping for a new box, be it Li or other. I've found no box worthy of replacing my my current box. It's a bit loud and its old. Its got some mods. But its never let me down. Just like my wonderful wife. All ways there in a pinch!![]()
Any one with v1000z ?
I think you mean icon win, folder fail.icon fail^
haadij404, is that fan cooler that effective for the video card or would you say that it still gets warm to the touch when gaming? I have a similar system and I would like to know these things.
I can't wait till I'm done with my PC A10B. You'll all crap your pants in amazement.
I'm going to grab the toilet paper... getting ready... alright now let's see![]()
Just a sampler:I'm going to grab the toilet paper... getting ready... alright now let's see![]()
Just a sampler:
4. Blue UV reactive PC Ice
I'm not running pc ice yet... still running distilled and hydrx. what's the problem with it? I have the dye bomb as separate, actually.Just for a noob (no offense) but after a year be ready to throw away your tubing, blocks, res and pump. O and the rads.
Should of done your homework
I'f it's not too late dump that crap and rinse your loop with "scrubbing bubbles", replace the liquid with distilled water, pentosine, PT Nuke and you can get some color (dye) if you want.
To be honest, I was much more impressed with 2Reds rig.
In a previous build I used the UV red PC Ice for a year and a half with no problems---the pre-mixed, not "Dye Bomb" PC Ice, that is. At the next rebuild I got new PC Ice, the "Dye Bomb" version. Within a month there was red crud building up in my waterblocks.I'm not running pc ice yet... still running distilled and hydrx. what's the problem with it? I have the dye bomb as separate, actually.
StlthMd, how do you make the DVD tray slide out (other than via software)?
Have you considered adapting the fan controller to the lian li face plate? 4 holes for the knobs and 4 holes for the leds and you're set. That fan controller is looking a little out of place there.Correct, I put a couple pieces of foam tape on the plate, and it fits like a glove.![]()
^ And this is in the Lian Li gallery why?
What are you guys talking about? I see it!
It's just MIND F*CK. When you see it...you'll...
