Velocity Micro LXE Exclusive Case [Modified]:
Lian Li V600:
hmm i dunno if in single channel, my old mobo config was 1color each stick, ill have to read the manual. Yes you can turn the cage around but its hassle and the sata cables have enough slack.
Ooh.. How do you like the velocity micro case? I've been finding a lot of those on ebay for cheap, and supposedly, they should have the same lian-li quality..
It looks like they used the same machinery from the v1100 cases..
How is it compared w/ the v600? I was thinking about getting either...
The V600 I bought from work because we had it as a sample and they wanted to get rid of some stuff and I'm using it for a friend's PC. So far I like it but I hate the proprietary screws for the hard drive mounting, they're expensive to replace.
My buddy has one and he had trouble getting a good overclock on his e6600 with it. You have experience or had any chance to try overclocking in this case? I've been thinking about picking one up after Christmas for another build.
Here's my PC-7B I'm workin on.
I have a blue Bulgin led ring vandal switch I just need to wire up and cut a bit out of the front frame so it will fit since this Bulgin switch is much deeper. There will be a few more of the billet fan grills as well.
That's very nice.. Is that front 120mm mount from MNPCTECH.com? If you like the silver/black contrast (I do) that's great.. If you wished the aluminum was black, you can take it to a powder coater in your area and it should cost no more than $30 bucks or so if you want it black. Nice build, BTW.
I'm also thinking of getting a front plate like the one on your VapoLi made for it with a front blowhole and 2 holes for Bulgin switches.
I have those same stands, however, they're holding up a pair of paradigms. =]
Why didn't you list the model number? You know that's what I was asking for...
Thanks!nice!^^
Maybe anti-kink purposes?![]()
yep. its cheap tubing and i had none of those anti kink stuff so i just used zip ties. im goin to upgrade to tygon tubing when i get a window so i wont worry about that.
what size wattage is that ultra -xfinity psu? what are your specs ? i have the 600watt sli one but im worried it might be a problem im having..
The Zalman fancontroller will be exchanged with the CF635.
