The Lian Li Gallery
here's mine since I switched to an Intel Core 2 Duo system. I also have an ASUS Commando board that I may switch to.
Fans are a recent addition, from white LED fans to some Blackfire UV Orange fans.
Other shots show off the mess inside :p
I'm aiming for a new sleaved PSU, new CPU cooler, 2 more UV fans and a window to show it off once finished.
Very nice. I love that case. Must.......... kill.............. for...........V1000.
Its awful empty inside that big case. You should transplant it into an A05 or something. :p
Oh I don't know. I have V2000 Plus II, and the components I have are in my sig. There aren't that many, so air can flow pretty freely.
It doesn't mean that in small cases air will flows less. In large cases you'll need more powerful fans to make the wind reach your components. Air will loose speed before it reaches the exhaust. With smaller cases you can make a more powerful constant air stream more easily.
Very true, I'm just saying that having a big case with few components isn't such a bad thing. I'm running 3x 120mm fans so air flow for me isn't a problem.
I need room for expansion too... more pr0n! :D Also if I decide to drop a 120mm fan up front and another DVD drive, and a couple more hdds then it would be filled.
Some great looking rigs... nice choice of cases everyone ;)
Here's mine, still waiting for the side panel to get back from being cut...
Ignore the bottom part, that won't be seen when the window is done
I agree. After buying a case as huge as the Lian Li PC-7077, I can't go back to a mid size case, even if I didn't have a dual water cooling loop in there. :p
im thinking about getting
Lian Li PC-V2000BPLUSII Black Aluminum
LIAN-LI V Cool PC-V1200BPLUSII Black Aluminum
Dont know which one would be better in my case..
Any recommendations? and why you chose that chose .
I'd go with the v1200, but this is only because i don't need the drive space available on the more expensive V2000. In fact, i'd get the V1000 over the V1200 because i don't need the extra 10cm length the latter offers. Do you have lots of hard drives and optical drives to fit in the case? If not, i'd get the V1200.
I have the V1000 and wish I would have gone with the V1200.... only because it "IS" very tight fitting with the PSU and the hard drives... also you can make it look a lot cleaner. The only downfall might be needing longer cables? I don't know... Overall... I still like the V1000. I just don't like how it's so tight.
the only reason why i ask is because. its a $30 difference between the 2 choices.
and the difference of the cases is height by 4"
So is $30 worth the extra height?
Because i love hwo they look. And I want a nice big case :D to fit everything.
Thanks for your replys. :)
Honestly... If you don't upgrade often or swap out parts...ie mobo. Then just get the smaller one... if you do swap a lot, get the big one so you have lots of ease when working on putting it together.
Nice case. I am interested in getting this case. How is the workability within this case? Does it have a motherboard tray? Does it keep your componenet pretty cool? Is it loud when the fans are on? If it is loud, what did you do to remedy the problem? From my research, it looks like this case does not have an exhaust fan. How does this case remove hot air?
Thanks
Kmat
Very easy to use, no removable motherboard tray but there is loads of space so it isn't a problem.
Everything runs nice and cool, cpu is around 28c idle and 33-36c load with a 22c ambient. I am using Nexus fans so it is very quiet but there aren't any noticeable vibrations from the case itself.
As for the exhaust it uses positive pressure and you can set the GPU fan to exhaust if you need to, I just run the normal intake at the front and exhaust on the rear though :)
Can you get feet like the V600 on the V1200 Plus II Case? Don't really like the wheels because my case wont be moving too much. Does anyone know if Seasonic M12 700 power cords long enough for the V1200 Plus II Case?
Thanks
Kmat
How's the cooling in that V600, Jasonx82? It looks pretty cramped in there. Very nice case, nevertheless!
I wont lie its a snug fit! =) but fits a 8800gtx acs3 ko badaxe2 and pcpc 750quad just fine! (temps mine idles around 48c X6800 stock clock with stock cooler)
Thanks
Kmat
I had a v1200 plus as well, didnt come with feet =(
