The Lian Li Gallery
Well, its a start but here is my v300 so far... Worklog started here with more pics.
Here you can see the video card cutout
Here you can see where I cut for the Modular PSU cables to come threw.
Front of the sexyness..
The radiator installed, also a closer look at the cutout for the PSU cables.
Ouch that was close!!!!!
You can see the tray made it all the way in.. yea!!!!
And I thought my V600 W/C build was tight !
Looks like you feel the same way I do when people say you can't fit everything you plan to in that case. Watch me !
Looking forward to the final stages.
Here's my new main rig. Based on a Core 2 Duo Processor.
System Components:
Processor: Intel E4300 (running at 1.80GHz @ 0.975v)
Mainboard: Gigabyte GA-945P-S3 (F4 BIOS)
Graphics Adapter: Gigabyte GV-NX76T256D-RH
Hard Drive: Samsung T133 HD400LD 400GB (in Scythe Quiet Drive)
RAM: Kingston KVR533D2N4 x 2
Sound Card: Auzentech X-Mystique 7.1 Gold
DVD-R/W: LG GSA-H42N-BK
Power Supply: Seasonic S12 430 + Yate Loon D12SL-12 (5v)
Chassis: Lian-Li PC-V1000B Plus II w/ Window Panel.
Wiring routed behind the mainboard tray.
The only 2 fans in the system. Both Yate Loon D12SL-12s running at 5V.
Just added another hdd today.
My data storage: HD321KJ + HD400LJ
Gel-Stuff for damping vibration.
Thats a dope case jnelson01
I have the default my comp came with :(
I'll have to get something like that after I buy my secondary monitor.
Thanks for the compliments.
There not as expensive if you get them from coolerguys. I got all 4 of them for about $37 shipped
Right, this is how my rig currently looks... I still have to fit more paxmate to hide wires, set up my water cooling and get the window sent off to be cut but it is slowly being done. In order to route the cables under the motherboard I used two risers stacked on top of each other, it worked quite well...
do any of the LIAN LI tower cases hold mATX mobos?... ihave a qpack case..but i want a lian tower since they so nice!...
omFG!!..your making me excited!...haha....can anyone else confirm this? or have pics?
Why wouldn't they hold mATX boards...? The mounting holes are there for them. Just put the standoffs in the mATX holes. :)
Update on my water cooled v300 mATX case ;)
Easy removable cooling system!
Reposted for antok86, the qpack ain't got nothing on the v300 :)
i know the qpack sucks!!...i want a tower style LIAN for my qpack parts....any suggestions? i dont want the v300...even though its very nice...looking for a tower....i didnt know mAtx is standard in tower style cases..i always see the sizing of mobos in inches..and they say ATX......i learned something new...thanks
u think there will be enough air flow ....one of the reason i dont like my qpack is the heat...even with additional fans....does this A05B have good air flow?
I'm looking to pick up a PC-A16 but I can't get hard numbers on the side panel dimensions.
Any1 know if any of the Lian Li window panels fit this case?
No, they don't. PC7 window is the closest and is around 1cm too tall.
Here is a brief snippet of my machine, I will be cleaning up some more of the wires this weekend and will put up some updates pictures then:
Here is an update of my Performance-PC's Lian-Li G70 "Goliath." In my last post of it I only had 1 CCFL plugged in and I didnt really have any good night shots, so here we go.
An older one of the outside front:
Older one of outside rear:
Insides(i tried taking a pic including the bay mounts but it was always blurry, thats where the CCFL inverter is mounted)
Side view in the dark with monitor in the background and side panel on:
Side view with panel off:
Those little LED cannons are the Sunbeam Chameleon light kit, that I can change to almost any color I want, but in all the pics they are red.
They do...just different mounting holes for the standoff's...even my PC-60 years ago would have worked fine.
Very nice I(illa Bee...haven't seen h2O done in a V300 yet.
I love seeing pics of the PC-7B, it's nice to see my favorite case gaining popularity, but it just means that I'll have to work that much harder to mod it in a unique enough way that it stands out when I get mine. :cool:
My now one year old Lian Li PC 7B setup. I'll be moving back into the Lian Li PC-75 sitting next to it this summer when I upgrade.
The last three pics are recent, the rest are from while i was building it and right after it was first done.
I made a sheet metal duct for the radiator intake to keep the radiator airflo separate from the rest of the case. air is pulled in through the duct and through a mesh lian li bezel in the front (i put an air filter behind the bezel) and out the top of the case past the radiator
specs:
opteron 170
dfi expert
2gb ocz gold
raptor 150, 400gb and 500gb raptors storage
7900gtx
6600 for triple monitors
ocz 600w
polarflo tt pump, DD TDX, BIX
EDIT: case and parts are for sale here
http://hardforum.com/showthread.php?p=1031119578#post1031119578
Good luck with the 120.3 Thermochill setup in the PC-75...those cases are behemoths and it simply dwarfs your PC-7B.
Personally I'd have gone with the PC-7077 though, but all's well.
anyone one in here wanna sell me a matrix orbital to fit my LianLi PC-A05B
I was considering that case for awhile...but I'm picky enough that i still couldn't stand it.
It's unfortunate that the only case I have NO issues with and a lot of mod plans for is the PC-7B, and so many people already have the case...oh well. :p
New poster here.
Here's a shot of mine as it stands now...
Still got to decide what to do with the front bays, thinking of putting another 120 fan behind some mesh.
Fans are a recent addition, from white LED fans to some Blackfire UV Orange fans.
Other shots show off the mess inside :p
I'm aiming for a new sleaved PSU, new CPU cooler, 2 more UV fans and a window to show it off once finished.
