The Lian Li Gallery
I'd say good job also, cept for the big ass spot in the loop that's missing water.
You should take a picture that's further away, so we can actually see more of your setup.
I'm planning a "photoshoot" of sorts and will have pictures at that time, I'll be sure to show you then (next week sometime)
Not much compared to the others on here. But here's my Jagermeister Lian-Li :)
Jager FTW!
Edit: you see no IDE because my cdrom is SATA kekelawls
UncleDavid218 said:
Yep, that leads to my fillport. Thanks for the comments guys. I paid for all of this with my own money, too.
nice work... but "paid w/ my own money"... as opposed to whose?
His parents, seeing as he's still living off them. Course, he's 17, so it's not that big of an achievement. At 16, I was paying for my own car insurance.
Here's an updated pic of mine.
I'm thinking of ways to mod the case so that I can better hide the cables. Kinda hard, when everything sits out in the open. I leave a lot of slack in the tubing, so that I can pull items out of the case and not have to drain the loop.
Yeah I understand where you're coming from. But I also pay car insurance on a 1991 240sx that's swapped and over 300RWHP ;)
SevenWords>>
Ya, I like Rei Ayanami. They keep coming out with new figures, so I keep winning them at the arcades.
Here's a pic of my old P4 setup and yes. The Rei Ayanami is inside the case.
UncleDavid218>>
And? The insurance company doesn't care that it's a swap. All they know is it's a stock 240SX. Low insurance. Unless your dumb and told them otherwise.
I paid insurance on an old 87 Mazda pickup. It wouldn't have cost all that much, if it weren't for the fact that I had 4 speeding tickets and a reckless driving on my record. Ya...$444 a month for liability only. Not even full coverage. I found places that were around $257, but after a month, they'd drop me. Too high risk.
Even now I still speed, but the Japanese seem to not care. Seeing as all of them are doing at least 20 kph over the speed limit. I'm usually going double the speed.
Of course I didn't tell them, they never asked. But the point is I still pay for other stuff other than my computers ;)
damn that's a nice case.
I was browsing case tonight and saw that case on the egg. Now i really wanna get it :D
what specs are in that case?
The power, reset, and usb are on top. Weird. First time I've ever seen that case. Pretty not bad.
Edit:
Some more pics.
My Server...
My old random machine. Currently only contains a mobo and proc. I'm waiting to get my comp back from a friend, so I can swap the parts between the two cases. This case doesn't really hold an ATX board easily. It has an IC7-Max 3 inside and all you can fit in there is 1 stick of memory and a small vidcard. The removeable hdd get in the way of the other 3 memory slots.
I'll be doing the parts swap with this comp. It has the mATX board.
A new comp I just built. It's not mine, but I own it for the next couple of months.
My personal PC, here are the specs:
Intel Core 2 Duo E6700@4.0
Scythe Infiniity 10 Heatpipe HSF
2x1024 Corsair DDR2 PC6400
ASUS P5B - Deluxe - Wifi
BFG 7900GT PCIe
IDE Lite On DVDR Dual Layer
ICY DOCK 3in2 Hot Swap Internal Drive Enclosure
MUSIC: 2X320GB Seagate with Perpendicular Tech SATA II
WORK DRIVE: 1XSEAGATE 250GB SATAI
ICY DOCK 5in3 Hot Swap Internal Drive Enclosure
VIDEO: 4XWD RE2 WD5000YS SATA II
WORK DRIVE: 1XSEAGATE 500GB SATA II
ICY DOCK eSATA / USB 2.0 External Enclosure
APPLICATIONS / PHOTOS/ GAMES : 2XWD1800 in a Firewire Enclosure
BACKUP: 1XMaxtor 300GB In NAS
4.2 TB Before Formatting
Lot of crap in a small case. I'm guessing you have to keep the side open to keep the heat down. I couldn't imagine it staying cool otherwise.
me loves my crap!
DMarti said:
me loves my crap!
Never said the comp was bad. Just cooling must be an issue. Where'd you get the 5 in 3 removeable hdd cage? It'd help me cram more hdds into my case.
Leak test passed - N00B to WC but learning everyday. Black Ice Stealth Xflow radiator is mounted in upper exhaust on right side. It is a tight fit with some tricky tube routing due to the tight design. Next up: MOBO load and mounting CPU water block. Specs when completed.
More pics as build progresses. (LL PC-V600/E6400/Abit AB9 Pro/XFX 7600 GS/OCZ Gold 2 GB/Koolance RP-1000SL)
-jr
More pics as build progresses. (LL PC-V600/E6400/Abit AB9 Pro/7900 GS/OCZ Gold 2 GB)
-jr
wow.that's a nice little rig! specs?
Oh, yes, i did that, everything thats been done to the case, i did, i installed those fans after i got the 8800gts to keep it cooler. I put them in about a week ago.
johnrea77 said:
Leak test passed - N00B to WC but learning everyday. Next up : MOBO load and mounting CPU water block. Specs when completed.
-jr
how roomy is this case? it looks fairly tight, so I'll let someone who actually owns it tell me how it really is.
Thanks
V600 seem to be quite easy to add water cooling in as theres a few german versions around
