BobNoxious said:Also, the subwoofer for the Altec Lansing MX5021 is NOT magnetically shielded... it is kinda close to that PC... you may wish to move the subwoofer to the right
aburgard said:I really like the vented front on the lian-li. Is it louder with those than the solid fronts?
aburgard said:What have you done with your video card, or is that passive also? I have 2 Nexus fans, and another on my headsink. The CPU fan and CASE_1 fan are motherboard controlled and the other is on a 7V fan extension. Right now I keep the fan on my GeForce 6800 unhooked because it's so bloody loud. My Zalman VF700-CU from Newegg should be here tomorrow. We'll see how that goes. It's a pain hooking up the fan every time I want to play a game.
I even dropped the case on one of them Nexus Drive-A-Way HDD enclosures (I was in a spending mood). Makes the HDD near silent but there's no front fan on top in the V1000 so its temps aren't as low as they could be.
What do I do with those extra molex connectors on the Nexus fans?
I'm considering moving the HDD enclosure into the bottom compartment but I'm not sure how to hold it down yet. I'm thinking the 4 rubber feet that came with the case plus zip ties throught he bottom grating. Ideas?
Can't you unplug the molex connectors on the Nexus and use the 3 pin mobo connector?
aburgard said:Thanks for the help.
I do notice a small sqeak in the VF700-CU fan at 5v but it's definately more quiet than the stock cooler. The highest reading I've seen on the 6800 is about 52*C now. Still not as quiet as it could have been. I don't see why they don't have fan control on this card.
you can run it at 5v or 12v.cornelious0_0 said:Well, I've never used a VF700 before...but I could have swore that there was an option to run it at 12v or not.
You can run it at 12 volt. 12 volt is too loud.
aburgard said:Thanks for the double sided tape idea. HDD temp dropped near 10*C.
Apallohadas said:Aburgard, your oversized pic really screws up the entire page.
aburgard said:Anyway, has anyone tried an ASUS EAX1600XT SILENT/TVD in a Lian Li? I bet those heat pipes aren't wicked either... Lian Li = Noisy SOB because you can't heatpipe for nothin'.
aburgard said:Any inverted case. PC-V1000.
aburgard said:Your ram really shouldn't need that, definately not.
cornelious0_0 said:I agree completely, at those timings you couldn't be pumping much voltage into those sticks, even for 280MHz...you could probly ditch the fan bro, things'd look a lot nicer for sure.
aldy402 said:lol thanks cornelious. I want to get rid of the fan real bad but because im running BALLISTIX, im sure you know how it is. Until I can get another 2gb set that can do in excess of 280, im gonna stick with it for now.
cornelious0_0 said:What voltage are you actually running through them? I've heard all kinds of stories about Ballistix memory...but the point still stands that if you're not clearing 3.0vdimm I really don't think you need that fan. Granted it's not the same stuff, but I previously had a pair of OCZ PC4000 EL doing 278MHz 1:1 2.5-4-3-5 with 2.9v or so. I can't imagine you'd be putting a lot more voltage into your ram then I was, and my OCZ did perfectly well without any extra cooling, and didn't benefit from it either when I tried.
