badcookies
- Mar 17, 2010
@PB4UGO & @ikem: thats some sexy white! i think my next builds (whenever that is) will probably be white now
If you can get an H50 in like I did then the H60 is a piece of cake.
Anyone here installed Corsair H60 in their Lian Li V1000 Plus II?
If the H50 fits, the H60 most certainly will, its profile is shorter, so it should fit just fine!
My mini gamer build:
Very neat!! Can you post the specs of the system?
Everything on one 120mm rad?
We have a saying here that is..."once you go for a lian li...there is no turning back"
Since the 80s I have had many Pc cases. One of the best i had i that can remember was one of the old thermaltake xaserII A5000A case that was really heavy, they don´t build them like that anymore.
But the best PC case i just fell in love with and it is the best case i had in my life is my PC-Q07. As i get older i don´t use the pc for playing anymore, to be honest the last game i played on the PC was the latest command and conquer red alert. I normally use the pc for internet use, burning media, downloading stuff
I am still waiting for lian li to come with something even smaller in the future. (same model and smaller than PC-Q07 to be used with ITX amd zacate boards or the next intel atom cedar trail, without normal PSU, using a regular external power brick)
BY THE WAY....I MODDED THIS PC-Q07 TO HAVE USB3.0 FRONT
here'smy A04
Is that a 120mm fan you added to the back? I noticed that there you have a rad in there as well. If I can fit my H50 in push/pull then I might get this case. Would you mind sharing a bit more details of how you set up your case?
Thanks,
Just upgraded my original 2004 build once again. This time I upgraded the chassis itself. Went with the Lian Li PC-P80 ATX full tower for the room and filtered airflow. Painted the internal chassis flat black and custom wired the majority of the power supply, fan, and lighting cables. If only I had a million dollars...
dont mind the finger prints
pfsense box
mediacenter
main rig
nas
I can't vouch for how RiDaTa did it, but what I did was to unscrew the stock USB 2.0 ports and screw in some USB 3.0 ports. It was not a challenging mod.How did you mod it? I would be interested in upgrading a q07 to USB3.0, but wasn't sure of the best way of doing it.
LIAN LI PC-Q25BWhat's the Lian Li model for your NAS?
that's one sexy case even without a cd/dvd drive!
LIAN LI PC-Q25B
.. or front USB ports .. which could be useful (imo) even on a server.
