Here is my case. Nothing too special. I know the big mess of wires next to the power supply is bad, but I did hide some behind the motherboard tray and properly routed them through the case. The can fan wires are completely hidden! Wire hiding is much of a big thing for me, just wire management.
Brownie points to those who can find "What is wrong with this picture?" on the computer.
System Specifications:
Athlon XP 2700+(2.171ghz)
Corsair ValueSELECT PC3200 512mbs RAM
DFI Lanparty NFII Ultra B
Thermaltake Volcano 10+
Philips DVD-ROM/CD-RW combo Drive
Generic 48x CD-ROM
Floppy Drive
My modded PSX ports
Painted Black Vantex Nexus 101
Seagate 20gb 7200rpm
Western Digital 120gb 7200rpm
Western Digital 160gb 7200rpm
Sapphire Atlantis Radeon 9600 Pro Ultimate
Maxtor Promise Ultra133 TX2 IDE controller
Sound Blaster Live! X-Gamer
Antec TruePower 430watt
This is workstation of my wife, used mainly for video editing.
I decided to make a frontal mod like my TJ-07 with lcd display e two fan controller.
V2000 is a beautiful case but is too big.....
Downgraded from 2x HD 5870s due to major issues and not so well working 120Hz on ATis.
Lancool (Lian Li) PC-K62 case
Zip ties through fan screw holes and original mounting holes.How do you mount those 120mm fans?
Yep.Did you do that for the top fans also? I think white fans will really rock in that case
Just finished transferring all my old stuff into the new case. I went from a Lian Li PC-7B and have no regrets. I added a pair of Gentle Typhoon AP15s in a push pull configuration on a Cool Master 212 heatsink. My q9550 is OC'd to 4.0Ghz stable an is still super quiet.
Nice, I'm thinking of picking up a B10 myself...how is the cable management, pretty simple?
Anyone using the CR-36B or any other Lian Li card reader that can comment on the performance? I don't use a card reader a ton, but occasionally if I go shoot a race or air show or something I may come home with 1000 pictures on a CF 133x card that I'd like to dump off it without it taking eons like a lot of cheap readers do. I can buy a Lexar UDMA reader for about the same price, but if a built in one will work as well I can live with it and obviously it'll be less annoying built into the case over having a separate box like the Lexar. I don't own, or plan on owning in the near future a UDMA card, otherwise I'd just get the Lexar as it doesn't appear the Lian Li's support UDMA performance.
This thread seems very quiet these days which is a shame as Lian's are truly stunning and deserve to be shown off! On that note, check out my new PC-B10. I changed from a PC-A10 as I wanted a smaller case.
i'm loving my K62
