Not sure if you resolved this but here is a link to someone who used a Zalman CNPS8000.I purchased a case with a motherboard and PSU the model is the s3400f.
So far I have an AMD 5050e, 2Gb Crucial DDR2-800, a Hitatchi 320Gb 7K1000.B HD (supposedly clocked just under the WD Raptor)
From this form I have read to replace the PSU is I want to run any Video card Higher than an 8600GT (even then I could be pushing my luck) so I got the Sparkle 300W PSU to replace the old one, then getting the 20 pin to 24 pin small ATX adapter (or making one have not decided).
But I hear nothing about anyone using another CPU Cooler in their rig...I see the HP part places have it but the cheapest I found it was $70 that's NOT including shipping!
Anyway most of the ones I have seen are too tall or look to big to fit in that small space. I have found only 1 that is a possible Link: http://www.silverstonetek.com/products/p_contents.php?pno=nt05&area=usa
It has a height of 92mm (spec) anyone know the depth of the case with the MB in place?
The only other solution other that bite the bullet and get the HP HSF is using this one http://www.newegg.com/Product/Product.aspx?Item=N82E16835887018
and putting a couple of 40mm fans at the back of the case to vent the heat.
Anyone out there every try using another HSF on their slimline or have a link to a place that sells the HP "stock" HSF at a price that is closer to earth?
Hi there, was just wondering how unreliabel the PC50 was, what were the problems you had with it please?I have a few slimline things for sale
Shuttle PC50 300 watt power supply $65 shipped - only used for a very short while. Purchased new retail. I did not find this PSU was reliable with a Q9300 quad core and a 9800GT. It should be quite sufficient for a lesser setup. (quad core and 9800GT is the biggest power draw you can put in a slimline) The PC50 is inaudible in a slimline. It is the PSU I used to make the PSU video linked on the first page.
9500GS - $50 shipped
8400GS - $35 shipped
160 watt HP slimline stock PSU - $25 shipped
Spare slimline case - $30 shipped (with powersupply = $50 shipped)
Extra microatx adapter to make a standard 20 or 24 pin atx PSU work in a slimline - $20 shipped
or make me an offer on any of the above.
Since the 9800GT will get too hot and will need an external fan, what would be the next best video card to use without adding any external fan to the case?
Hm...the Sparkle 9500GT sounds like a good idea for me to buy. Would the stock PSU of 150 watts be powerful enough for it?
The proof will be when I snap in the sticks and crank it up and it works (OR NOT!)
You shouldn't have a "150" watt PSU. You should have a 160 or a 180 or a 230 as stock options. I would not put a 9500GT in anything but a 230 watt stock PSU.
With a 180 watt PSU you could probably get by with a 9500GS (not a GT).
With a 160 watt PSU (you'll have an AMD slimline) I wouldn't even put a 9500GS in there until you got a 45 watt AMD processor.
Chuck,
Sorry for the late reply. I don't browse this forum as much anymore.
Yes, I have 4GB installed.
Here is the RAM I bought and installed: http://www.newegg.com/Product/Product.aspx?Item=N82E16820134192
I don't think my computer supports PC6400; that's why I bought PC5300.
Here are my system specs:
Mainboard : Asus LOCKTITE
Chipset : Intel i945G/GZ
Processor : Intel Core 2 Duo E4500 @ 2200 MHz
Physical Memory : 4096 MB (2 x 2048 DDR2-SDRAM )
Video Card : NVIDIA GeForce 9800 GT
Hard Disk : ST3500630AS (500 GB)
DVD-Rom Drive : HL-DT-ST BDDVDRW GGC-H20L
DVD-Rom Drive : IBKX OTUFG16F4 SCSI CdRom Device
Monitor Type : Hewlett Packard HP w2408 - 24 inches
Network Card : Intel Corporation 82801GB I/O Controller Hub LAN
Operating System : Windows Vista (TM) Home Premium Home Edition 6.00.6001 Service Pack 1
DirectX : Version 10.00
Hope it works out for you.
Ok so I cant say ive read the 100 psges or so here but I have skimmed through many.
My question is what is the absolute best gaming video card I can get w/o modding the pc with a new psu or whatever else. I have the hp slimline s3713w. It has amd 45w processor and the 160w psu. I pulled the modem out for a little less power draw, and it has 3 gigs of ram. Please let me know, leaving my pc stock, what would be my best gaming card?
9500GS or 8600GT.
Both should be okay with that setup.
Archaea,
I been reading up on this forum and you seem to offer some pretty good advice. I have a S3400F model and want to buy either the 9500 GT or Radeon HD 4650. Do you think the sparkle 270 Watt is enough? Also, is getting an additional fan necessary?
Here is the transcript of my chat with....."ROHIT" from India"!!!:
My SO says that I am becoming obsessive over this issue and that I should just be happy with the extra performance I will get from the 9800GT video card upgrade (which will be done tomorrow AM) and enjoy the gaming and FORGET about a RAM upgrade as well ...Hmmmmmmmmmmmmm....good advise but hard for someone like me to take!
