Archaea
- Oct 19, 2004
sup all,
I posted here around a month ago about my mission to upgrade my power supply and graphics card. I got both the RADEON HD 4650 and my 250W power supply and installed the 4650 into my computer.
however, whe i removed the power supply, i realized that i need a 24 pin to 24 small pin connector so it could fit the main power connector to the motherboard. I can only find the 20 to 24 small pin connector that Archaea posted on the first page but i have no clue where to look to find the next one. any places i could find one?
US 250 W power supply(rebranded seasonic)
You'll need the same adapter we all needed most likely. The 20 to 24 pin adapter. TYPICALLY the extra four pins on the PSU to make it a 24 pin, are unclippable, meaning they disconnect. If not ---- you'll likely have to modify the 20 to 24 pin adapter by breaking the plastic off the end, because I've never seen anything other than the 20 to 24 pin adapter that atxpowersupplies sells.
