insanevibez
- Nov 19, 2008
would disconnecting the power to the all in one reader and dvd drive (since i really dont use them) free enough watts to add a 9500gt without the 45w cpu?
Hey Archea I was wondering how you got the cd box out because I'm having some problems doing so to put more RAM. In the bottom. If you could explain what you did that'd be great. I checked out the hp site and for one of the instructions it said to unscrew the screw that's connected with the box. There's something blocking that 1 screw, it's a small box. In 1 of the pictures posted In the bottom right corner that's what it is blocking it. So please help me out before I have to go to geeksquad haha, they're kind of annoying and don't explain much.
And the answer is... of course there are supposed to be four sets of threads to secure the cooling heat sink and fan. It has been a while since I pulled out a motherboard, but I should have remembered seeing an X shaped thingie. It turns out my built in Mexico box doesn't have this part secured to the motherboard in any way. Pictures below, first is what I found, second is what I should found, and third is a picture of the motherboard side of the brace. There's a cardboard pad, but no adhesive to keep it in place against the motherboard.Grateful reader, first time posting.
I had to remove the CPU heat sink and fan to be able to swap the power supply.
On reinstalling, I found only one screw thread to secure it down.
Anyone else run into this? There is a thread for the hole nearest the power supply and back of the case, but from peering into the other three holes, no threads seen. No loose nuts making noises when I shake the box, and everything seems to work fine, although now I'm concerned about CPU temps.
I'll probably find out myself soon, but if I take the motherboard out, will I find three more sets of threads? Loose nuts?
TIA,
-->Aaron
HP said:* Genuine Windows Vista Home Premium with Service Pack 1 (64-bit)
* AMD Athlon(TM) 64 X2 4850e dual-core (2.5GHz)
* FREE UPGRADE! To 3GB DDR2-800MHz SDRAM (1x2048,1x1024) from 2GB
* SAVE $20! 256MB NVIDIA GeForce 9300, DVI-I, VGA adapter, HDMI
* 250GB 7200 rpm SATA 3Gb/s hard drive
* LAN port on system board (10/100Base-T), no wireles LAN
* SAVE $50! Blu-ray DVD player & Lightscribe SuperMulti DVD burner
* 15-in-1 memory card reader, 2 USB, headphone port
* Integrated 5.1 channel sound with front audio ports
* Microsoft(R) Works 9.0
* No additional security software
* No speakers
* HP keyboard and HP optical mouse
* HP Home & Home Office Store in-box envelope
Just got the 9500GT yesterday, and not a moment too soon - my 8600GT was obviously eating away at my PSU and started crashing left and right after having it in there after a month. The card is fine though, with a 65wt CPU it's just too much strain on the SL if you game for any extended period of time. Plus it's one noisy bastard, so I'd recommend to avoid the 8600GT unless you have a 45wt CPU, and even that may be pushing it over time.
The 9500GT is nice and quiet in normal operation, the fan does ramp up when gaming but goes back to near silent at the desktop after a minute or so (Vista as well). Performance wise I'd say it's pretty much on par with the 8600GT stock, in some older games the DDR2 ram holds it back and I can notice a little more slowdown than the 8600GT such as in games like Q4 in high res, but we're talking perhaps 10-15% slower in some rare situations. In other games it seems a little bit faster, the extra 256megs of memory helps such as in Gears of War where running with high textures has less stuttering than medium on my 8600GT. So performance wise over all it's a wash, I may try to overclock it a bit and see.
I've got a kill-a-watt on order so I'm going to be running a stress test and measuring total system load during a benchmark, I don't have any other cards in the system other than this. I doubt it's anywhere near stressing the system as bear in mind HP will sell you a quad-core slimline with a 9500GS + TV tuner card but I'm curious.
So this is pretty much it unless you want to add an additional power supply, Galaxy supposedly has a GDDR3 9500GT LP version but I haven't seen it available anywhere. It would likely give better results and closer to an 8600GTS, but for now the XFX9500GT is as good as it's going to get.
Edit: Should also add that heat is extremely negligible - just slightly warm after a decent gaming session, so it may be possible to cram the TV Tuner in the adjacent slot without issue.
Regional Coffee, I've got a XFX9500GT a month ago and put it on a Slimline s3620f (Intel E5200) with 160W PSU. I ran Crysis, Sins of a Solar Empire, Dead Space, Bioshock and Company of Heroes @ 1024x768 and got noise and no overheat. All those games ran above 30fps. It's a great card, but I want to know your Slimline specs and PSU. I don't know if I'm pushing mine too much!
Those are well within tolerances for the CPU and GPU, that's actually quite a low temp for the GPU actually. I don't necessarily think it was heat related.Sadly, first lockup tonight while playing Bioshock for 3 hours with my 9500GT. It started with Windows Vista sounds inside the game, just like connecting and disconnecting a flash drive, then it freezes while loading a saved game. I looked for a temperature measurement and got 51C for CPU and 45C for GPU...
