jeremyshaw
- Aug 26, 2009
Hello!
s3700y guy? I swear it's you...
Hello!
Do you think I should buy a new cooling system? Or maintain this one...?It's a vertical cooler. "Tower" as they are also called. The cooler will only cool the CPU, but in the s3000 chasis, it's also designed to move air through the case (as it's the only fan of any worth on the s3000 chasis).
It uses heatpipes to draw heat away from the CPU, and fins on those heatpipes to dissapate that heat. The fan helps dissapate that heat by moving air over it. The cross is just a mounting bracket, to attach the CPU cooler onto the motherboard.
By the way do you think a processor upgrade is a good idea also...it has a weak one that is a intel Dual CPU at 1.6Ghz. I thought of buying the intel core2duo 6600. Is it difficult to install? I would like to keep the Hard Drive unthouched without reeinstalling windows or anything...is it possible doing the chipset upgrade?
Thanks again.
Hello everyone. I searched throughout the thread and couldn't find a solution to my Slimline problem, so I decided to make a post hoping someone could help me. You see, my Slimline model came with the stock Intel CPU heatsink, which blows air upwards to the lateral panel of the case, instead of to the rear like other Slimline heatsinks I've seen here. I recently upgraded my video card and wanted to place a 120mm fan on the lateral panel to blow cool air into it, but the problem is that I can't with this version of the CPU heatsink.
Does anyone know any place where I can find a rear blowing CPU heatsink that will fit on the Slimline? I'm even willing to buy the stock one, so long it blows to the rear of the case. Thanks for the help!
It's actually a Latin America only version of the Slimline, I can't remember the exact model number but it ends with LA. The heatsink is exactly like this:
I put a Sparkle 270 PSU in it, and a Sparkle 9800GT. To cool it I also modded the case and placed a 120mm fan on the side that blows directly to the GPU, much like the first post's recommendation. The thing is that there is a little overlap between the CPU's fan blowing out and the 120mm fan blowing in, so I thought if I could get a rear exhaust heatsink for the CPU the airflow would be better?
Also, do you by chance know what's the heavy gaming temperature for the Sparkle 9800GT and the Core 2 Duo processor? I've seen the cores spike to 60°C while playing Starcraft 2. The GPU gets to around 70-75°C. Thanks!
Well, as I mentioned earlier, both temps are perfectly fine. My i7 (admittedly overclocked) 930 @ 3.6GHz runs about 72C with H50 attached to it. My HD5870 runs 83C in the stock fan profile. About 91C if I have it in crossfire (only have enough space to sandwich the boards, lol...You're right that's not the Slimline, but the CPU Heatsink is pretty much the same; It looks like one of those stock Intel heatsinks but with a different fan on top.That heatsink was the only active cooling component in it before I put the 120mm fan. The model is S3420LA. I'm sorry I couldn't give it before, I didn't have it with me.
What I was thinking is if I switch to one of those rear exhaust heatsinks, I could place another 120mm fan blowing air directly into the CPU and also place a rear exhaust fan to get the hot air out.
And again, thanks a lot!
I think 60-70mm fans will fit, I haven't tried anything really fancy, yet. Archaea mentioned a single exhaust fan would already help immensely, as this is a rather airflow-channeled case.Hello again,
im putting a 9800gt in my slimline, and i was thinking of mounting 3 - 80mm fans inside at the bottom of the case. Will that work and will half a inch be enough for intake?
Edit: and yes jermey it's me! i bought the card and everything but i havnt got the chance to intall everything yet.
Hello all,
I have a HP slimline model S3681d (Malaysia and Indonesia model)
This original model spec:-
180W
Core 2 Duo E7300 (W) 2.66 GHz (65W)
NVIDIA GeForce 7100 / NVIDIA nForce 630i - built in Irvine motherboard
4GB DDR2 6400 RAM (2X2)
Dedicated graphic card - Nvidia Geforce 9300
Hauppage TV card
After used for almost a year and 1 month, I change the Vista OS to Win 7 ulimate.
A month and so, problem occurs which I cannot restart my desktop. I thought it was because of the WIn 7 problem...But after I install back to original windows vista Home premium. Still problem occurs. I checked the hardware - I found my 9300 card problem. So, I switched to onboard graphic before I buy a new graphic card.
Based on this forum, I buy Sapphire HD4550. Just received yesterday. But, when I installed the card, after a while running the card, memory dump happen to my system.
My thinking either the power problem (based on this forum) or the graphic card is too hot because the 4550 have no fan only having heat sink.
If based on this forum, I should not have power problem because I already taken off the docking bay and disabled my firewire.
So I assume maybe the graphinc card too hot. I think this because when I try to test using the 3d benchmark and the window rating ration, when it test with 3D, the memory system will be dump and it will automatically restart.
What all of you think?
All your help is really appreciated.
So, after upgrade, my current system as below:-
180W
Dedicated graphic card - Sapphire ATI HD 4550
Hauppage TV card
Windows 7 ultimate
I have another question, why everybody only upgraded the PSU? Is changing the case cannot fit with this type of motherboard?
Sorry if I asked the same question in previous post.
Hopefully somebody can help me...
Thank you...
Hello again,
Regarding my Sapphire update problem with my system.
Yesterday I have troubleshoot by take out all the hardware one by one and put it back again one by one to check the cause of the memory dump.
Then after a while, I think it is because of my Sapphire HD4550 becoming too hot when using excessive 3D testing (Benchmark3D) . When I used win7 rating assessment, it works fine. So I was thinking I cannot used this for 3D function heavily. That is my solution.
Then I try to reformat my system and install back win 7 ultimate in my desktop. After finish installation of the windows. I install my Avast antivirus then set a boot up scan. When it start to scan before entering windows, suddenly, it happen again - a memory dump. The computer restart. When it reach windows, I try again to test my system using Win 7 rating assessment. It is ok.
So, for the sake of testing, I try to restart again. It happen again - the restart give a blank on my monitor (no bios start-up or HP logo). I try to reset the system by pushing the power button for more than 30 sec. Wait a while, the power is on but the screen is still black. I take out TV card and the HD4550 card and connect my monitor to the onboard graphic, still nothing happens. I check the monitor, I take out the RGB cable, in the monitor appear no signal means the monitor is ok.
So, hard reset the system and start toubleshoot from the start. Still nothing happens.
Now taking out my CPU. But, I don`t have a thermal paste. So, now just waiting for the paste to arrive before reconnect back my desktop.
If still having problem, I just buy a second hand motherboard (matx or atx), buy new casing with power supply and take out everything from HP motherboard and put it on new system.
Any suggestion regarding my cases or problem before I proceed to buy a new system either second or new one?
This is continuation from my last thread. This is really frustrating...
Regards everybody....
gamedeveloper, your problem sounds similar to mine. My s3300t works fine until I put a GeForce G210 in it. I am pretty sure there is enough power to drive it. Slowly, over the course of a month, I notice some instability. I took out the G210 and go back to VGA. I thought I am out of the woods. Then after a few weeks, problems start popping up. Initially it is random freeze. Then eventually it will not boot up. Then not even POST.
I eventually replaced the motherboard/case/ps for $100.
So my conclusion is that adding a video card kills the Irvine-GL6E motherboard.
For you, you should possibly go the same route. There are plenty of Socket 775/DDR2 m/b options from $30 (VGA only, mATX) to $100 (HDMI, mini-ITX).
HP does provide up to 9500GT (which is custom low profile for the slimline), AFAIK.
There are many happy Slimline users with video card, though. Anyway, if you can afford to reactivate Windows, getting a separate motherboard/case/ps is the way to go.
Someone [here] reported the same issue (and same exact picture of what I have) with my GeForce 9500GS, but in perusing the rest of the thread I couldn't see that he was ever answered or found a replacement fan. Unfortunately CompUSA and CircuitCity both folded here and all I have is that BestBuy, which no small VGA fans on their site or in stock else I would take the card there to check the mounting alignment. I am still not sure how to go about fixing the fan on my video card.
As for case cooling--I really like the case mod someone [here] made to his Slimline. It looks pretty sharp with the blue LEDs matching the power switch. I did some more searching about and found a case fan, which comes with a bezel and grill that I really like the looks of, but it's a 250mm and not a 120mm. Depending on if the 250mm measure the mounting holes or the outside tangents of the circle will say if it will fit or not. If the holes it's way too big; if the tangent it would fit pretty well I think.
I was the one who put in the links with the huge (just removed them) photos of the motherboard that everyone agreed had no visual indication of a problem which turned out to be a correct analysis. There was nothing wrong with the motherboard. I ordered a new one on ebay from Digital Anny. The PCIe graphics didn't work on the new motherboard either.
I finally got a chance this weekend to try a different power supply. That also didn't help.
At this point I've decided that perhaps the "SAPPHIRE 100293L Radeon HD 5570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Low Profile Ready Video Display Adapter" I bought from Newegg isn't compatible with the 3200t ? Does that make sense?
Great thread! I just came across it while researching some options for my hurtin' s3600t. I did find some good information in this thread but not all my answers yet.
I had started a recent thread at the HP Consumer Forums detailing my problems-- specifically hard drive replacement and cooling-- case and vga.
If anyone has any information on replacing the stock 9500GS fan, or experience with the Rexflo fan; I'd really appreciate your input. Thanks in advance, and again-- great thread!
HP uses the same HSF on the 8500gt, and likely on all of their ASUS-derived lowprofile parts of that time period (2007-early2009).
Mounting points are rather standard for low end GPU. Most HSF designed with ONLY two mounting screws will work, though most will not be up to the task of cooling your card.
Archaea did that case mod - he is the founder of this thread
Oh, and welcome to the [H]![]()
Thanks again for the reply. I'm trying hard not to be thick but apparently it's not working...Those two should fit - but I think the 9500gs' cooler is already at max capacity, as is. Anything smaller would likely kill your 9500gs... IMO.
What do you mean by "the 9500gs cooler is already at max capacity, as is. Anything smaller would likely kill your 9500gs... ?" I am not sure what you mean by max capacity. From what I can tell these looked to be about the same size as the stock fan to me so I figured on comparable cooling. Are they smaller? They do not have the offset heat sink and plastic shroud that the stock unit does and I'm not even really sure where the GPU sits under that thing though it would make sense to be under the sink fins I am guessing. The do have cooling fins in a circular pattern around their fans. Do you think it would be better to see if I could remove the existing fan and try to replace that alone leaving the stock sink and shroud intact rather than trying to go with completely different after-market cooling?
I think I will holding off on any vga cooler purchase until I get a chance to pull my card, remove the plastic shroud and thoroughly dedust and oil the stock fan. Maybe I can get it spinning again and if not, I can at least get some measurements more easily. If anyone has experience with this operation I'd love whatever pointers you have. For example, would something like that necessitate removing the HSF from the card entirely and would I need some new heat sink paste to reinstall it?
I am also still looking into case cooling options to increase airflow to sensitive components. I am buying a Caviar Black to replace my failed Barracuda and concerned about how much circulation is in the front of the case as I am thinking that may have led to the initial hard drive's early demise. Does anyone have any idea if a HD cooler would fit in a Slimline? Something like this one at Newegg?
I also wasn't sure if I should go with a side fan (and if so blowing in or out) or else stick to the more traditional cool air in low front-side, hot air out high back-side. I was thinking about possibly using three 40mm fans for this setup. I'd put two blowing out on the grill running vertically on the Slimline back adjacent to the motherboard's external connectors and put the third sucking in where the personal media bay is currently. I've never used the Personal Media Bay. It seems a nice idea but in pricing drives for it, it is far cheaper to go with an external SATA or USB disk for the MB:$ ratio. Has anyone tried anything like this?
After taking another look I think I could go two ways on this. As I last mentioned I could remove the pocket media bay and fit in a 40mm fan vertically with airflow aimed to the rear. This would seem to aid the flow to the video card but with fans at the rear pulling I am not sure how much this airflow pattern would aid the internal hard drive. It would seem to flow diagonally to the rear and miss the internal drives in the top front of the case. If a hard drive cooler will fit in there then I wouldn't worry about getting air up there and likely go this way. Alternately it seems to me that I could also use the pocket media bay itself as a mount to put in a horizontal 80mm fan which would push airflow upwards to the internal drive area. The case has perforations along the bottom and lower edge which would allow decent intake. Pulling up from the bottom I'd probably stick a filter in, but that would get air up to the drives. I'm not sure how this would leave the video card, but it did do fine until its fan died so if I get its fan going again it should still be fine... though then I could also put in that side fan blowing in over the card to be sure. Decisions... decisions...I removed my pocketdrive bay - HP discontinued the drives that were compatible with the HP Slimline's bay, at any rate.
There is no airflow to the HDD section, under the DVD. Technically, most of the air the PSU fan draws (50mm?) is from this section. However.... the PSU fan doesn't punch out any apreciable amount of airflow.
http://www.techpowerup.com/articles/overclocking/psu/116hi, i need some help with the 6 pin power connector for the gpu, i need the wire diagram, to make one,allready have the connector and pins
thanks
I had been adjusting my TCP autotuning when shortly after, my USB Wireless g/b Network Adaptor suddenly became an "Unknown Device" in Device Manager and the network connection disappeared. Sometimes on a fresh unplug-the-power-supply reboot the NIC will work as before, but then after some time falls back into Unknown Device. Updating drivers through Device Manager while the NIC was recognized did not help. The network card is a thin circuit board inside the chasis with an external antenna. It did not seem loose when I examined it.
Any experience with this sort of problem or clues on how to solve it would be really appreciated.
My system is a 2-year old HP Pavilion Slimline s3600t PC running Vista64.
Thanks, Jeremy!! Following your advice, I went to switch out the connection and found that the plug on the motherboard was loose. Tightening the connection has solved the issue.
