It's the best one in recent memory for the price, in terms of looter shooter.It's really an outstanding game. I can nitpick quite a bit, but compared to the competition.. It's far above.
Delta-03 error code disconnect. First issue like this with 30 some odd hours of gameplay under my belt.
Possible you were just kicked out because there was an update. The game updates whenever you first start it up, and they push stuff in the background pretty often from what I can tell.
Delta 2 - 5 = The connection to the servers timed out. They also refer to this link for more info: https://support.ubi.com/en-US/Faqs/000038816/Connectivity-issues-in-The-Division-2-on-PC-TCTD2Just happened again. I'll see if there's any updates.
Really??? what caused you to have to restart? I had a progression bug that I had to open a ticket with ubisoft, but thanks to the internet(reddit) found the work around. I started a 2nd character that I think I found a use for later to redo some of the missions for specialty points.I got a euhm… well "nasty" surprise once I cleared the third fortress and got world tier 1this I did not expect, but I'll run with it.and basically had to start thegame over
I've been getting these momentary stutters after about an hour or two of gameplay. Was running 16GB of RAM - decided to throw in the other 2 sticks of ram to take me back to 32GB of RAM. I took 2 sticks out when I first upgraded to Ryzen due to stability issues, seems the latest bios has fixed that. Been playing all afternoon with 32GB of ram and no stuttering at all.
He’s talking about the black tusk invasion once you reach WT1.
Our HardOCP clan earned the highest tier weekly clan cache this week. Nice!
Yea, some of us probably enjoyed this game a bit to much. LOL
If I pick up this game on Epic will it automatically be added to Uplay?
BTW: Not sure if there's a good answer to this or not but how do you guys decide what to keep, what to deconstruct and what to sell or donate?
I'm basically keeping what's best for each slot + checking for set synergy but the other things are hard to decide on.
At the moment all gear is broken, you best bet is all red set bonuses and traits. Do that until you get to 450, then stash any other balanced gear you get.
I would say yes, the loot drops like crazy so you will have plenty of supplies. Don't forget you and run missions over and over for farming too. I did that a ton in Div 1.At that rate I'm not going to bust my ass until they fix it. I just crossed 30 yesterday and I have not done any strongholds yet. I have all the perks. I have all the skills everything done and unlocked.
Is it ok for me to start breaking items down for some crafting and upgrades? I'd like to try and get the Lullaby and Ruthless guns upgraded and things of this nature.
So random question, once you hit 30 do you have an opportunity to finish all the side missions, etc? I'm probably going to hit 30 tonight and due to some prolonged exploring, I'm way behind on the side missions, haven't touched strongholds, or finished the story missions.
PSA if you are dropped a desert eagle side arm put it in your stash, don't sell or break down, you will need it later for the exotic side arm. I haven't come across one yet.
yes, you have an opportunity to complete all the side missions after you hit the higher world tiers. I hit WT1 last night and still had several of the blue side missions avail. WT1 isn't started until you finish the story missions + hit 30 + do all 3 strongholds.
Yeah I deconstructed a lvl ~300 one last week. At that time I wasn’t aware you needed one for the exotic. I wonder if the D50 you can unlock on the Survivalist skill tree will work?
If you buy it through Epic it's like Steam. You just launch it once, and it'll be added to your Uplay account. From that point on you can just launch it straight from UPlay anyways.
I don't do it with just exotics......i hoard everythingI am glad my instinct has been to hoard exotics. I will continue to do so as I do my vacuum cleaner impersonation.![]()
o if anyone wants to do some level 3 Control Point farming for Blueprints, hit me up.
These level 3 and 4 control points are freaking hard. I'm embarrassed to say I've died several times while trying to get these. And this was in a group too.
