Wow, great chip you have there Kyle
. What kind of cooling are you using on the NB? Also, you might want to try a newer BIOS, it might help you get more out of the FSB: http://www.xtremesystems.org/forums/showthread.php?t=109719&highlight=beta .
Mr. K6 said:Wow, great chip you have there Kyle. What kind of cooling are you using on the NB? Also, you might want to try a newer BIOS, it might help you get more out of the FSB: http://www.xtremesystems.org/forums/showthread.php?t=109719&highlight=beta .
scientificTHEgreat said:OH NO YOU DONT, your not going to take my glory
This is a battle now Kyle!
scientificTHEgreat said:lol
Don't make me take off a side panel on my computer case
I'm a poor consultant working in downtown Dallas, I can't afford phase cooling![]()
sparks said:why is there a cpu wattage column?
idle temp maybe as replacement
scientificTHEgreat said:Please update when you get a chance.
Thanks!
talon95 said:Here's verification for 3150mhz.
http://members.cox.net/dgreen6/C2D_3150_7hrs.JPG
Gigabyte 965P-DS3, F3 Bios
E6300, L625A254, Stock HSF, stock volts set in bios
Corsair XMS2 PC6400, 5-5-5-17, 2x512
MSI 7600GT
Temps are a bit high with the stock cooler (60-62C running as shown in the link above), but stable. I tried 7x475, but needed a small voltage bump to be stable. Temps were way too high at that point, so I didn't try letting it make the 4+hr run.
kelim said:Username: kelim
Processor Info: Allendale E6300 @ 2660mhz, stepping 6, week L625, code A705, stock voltage, (how do I find out my processor's wattage?)
thudo said:ANyone else severely disappointed in the E6700 OC scaling? 3.4Ghz only? WHAT THE HELL?!?! Then again, the E6700 is shipping REAL SOON and I reserved mine - should be in Toronto, Canada by the beginning of Aug 21.. Yippee!! That and the E6800 are the only Conroes not widely available.
In the above chart is the exact specs I am getting (Scythe Mine Heatpipe cooler, AC5 ThermalPaste, and Asus P5W DH Mobo) except the memory (I'm getting OCZ PC8000 DL 2gb geek RAM). Hope to have my reprots in by the end of August. W()()t!
kelim said:mind taker: 1.32500v
peleejosh said:whrswoldo
what memory are you using?
And since when is overnight = 15 hours. Do you actually sleep that long? You may need to see a Doc. J/K
jfloyd said:Allendale E6300
3.010 Mhz
6 B2 Step
L625 Week
705 Code
65 cpu watts
1.288 volts
Water-cooled CPU and North Bridge
Koolance V1100
Cosair 6400 5-5-5-12 @645Mhz (cant get it to boot past 645Mhz)
Asus P5W DH Deluex
celerity said:hi there
Allendale E6400
3,600 Mhz
6 B2 Step
L625 Week
Code: I can't remember, A452 I think
65 cpu watts
1.45 volts
Air cooled with Sunbeam Tuniq Tower 120
G.Skill DDRII 6400 HZ @ 900 Mhz
Gigabyte DS4 motherboard
Bios: F3
cpu-z valid: http://valid.x86-secret.com/show_oc?id=112313
12 h 100% prime stable with orthos
jfloyd said:Sorry took so long. Posted thread yesterday and then went to work.
Bios is 1010. Ran Benchmark for 6 hours, 2 days ago but I didnt save It. I saw your post yesterday and just joined Forum Site. Been running this setting for a week now.
Love the post, keep it up man.
nooh said:This leaderboard still has something missing i feel and that is the idle and load temps, it gives nmore information on the whole thing.
Wall7486 said:So I assume you want to see the entire 24 hour of prime for my post mentok1982, before putting me on stable?
