Sorry about that, my overclock is so puny I thought it wouldn't be worth adding to the database. But here's the info anyway:mentok1982 said:Please read the first post of this thread. You are missing:
CPU voltage
Cooling method
Cooling brand and model
BIOS version
Memory timings
centvalny said:![]()
Dual SP32M with stock HSF and 1.6Vcore. Boot up @ 437FSB
DFI Infinity 975X/G with bios 0707. Memory @400...
centvalny said:Yep, Corsair6400C3. Infinity cant run memory strap @ >533 if FSB>380.
WesM63 said:heh.. i've been gone for over a week and no one has taken my spot with an e6600?
FORNOWAGAIN said:
mentok1982 said:I am going to assume that the memory timings for the 3.7GHz overclock are also 4-4-4-12.
Let me know if that is incorrect.
Look for an update either later tonight or tomorrow morning.
DarkSi said:How do you figure? I see 3 stable OC's that are better than yours, one of which is on air.
WesM63 said:The guys that are higher from me are not from [H]ardocp
mentok1982 said:Yes they are. All the results in the database are from people with [H]ard|Forums user
names. The results for eva2000 and OverclockingGuru came from both these forums and the
Xtreme System forums. I will not discriminate against results based on where they are
posted as long as they are posted by a [H]ard|Forum member.
On a related note I scan through several [H]ard|Forum sections looking for Conroe overclock
data and/or people who have a Conroe.
centvalny said:Update with 6400 @1.6Vcore, still with stock HSF..
Devious said:
mentok1982 said:It looks like the voltage was at 1.49 instead of 1.55, correct? I have assumed that the memory
timings are the same.
Devious said:It was set at 1.55v in bios, Asus probe always shows .02/4 less and decreases more when under full load due to Vdroop. Timings are they same 4-4-4-8.
scandigity said:I guess my setup is pretty much identical to aldamon's computer, but this is incredibly stable, I absolutely love this setup.
mentok1982 said:I know it is spooky. I actually checked to make sure that you are two seperate people and
not just one person with two user names.
soki said:Finally another DS3/retail E6600! Brahmzy, what mobo BIOS are you using?
chrisf6969 said:Don't you think it would be better with just the highest stable single overclock with that configuration for each user.
What version of the BIOS did you mod? The new F4E? Also are all three of those overclocks stable?scientificTHEgreat said:This is on air btw... only modified BIOS with+3 on FSB, +3 on vdimm and CPU to 1.35v
soki said:Changes from old o/c:
1.6 vcore (cpu-z lies again)..
new F4e BIOS for the DS3
Going to run 2 Prime95's overnight to see if it holds up (3.6GHz was unstable in Windows).
