The Conroe Overclock Database. (Please read 1st post for posting instructions.)
Status
Not open for further replies.
So far it's pretty lame (?)
3158 MHz.
I wonder what the other folks (lopri) are doing right to get 3600 with the same type of setup?
I PMd him to find out.
Yea I PM'ed FORNOWAGAIN because he has a similar setup to mine and he has the same week, L623 as mine. I saw he used the 903 BIOS for the P5W DH, maybe it's a better OC'ing BIOS? :p
Got some new E6300 stable records! Weeeee!
KEY:
Green=official result (all columns filled)
Black and bold=not official result
Highest overclocks that have not been proven to be stable:
Oh mentok I just noticed when I read my entry that I made a typo on the voltage. :rolleyes: I said my vcore was 1.4675 but that is not possible given the increments of .0125 V increase. My voltage is actually set to 1.4625 V.
Ok I have changed it in my document. You will see the change next time I update.
My recent build is an E6700 at 1.5v running at 3400mhz (340x10) dual prime stable, Asus P5W DH bios 1011, WD Raptor 150, 2gb Corsair 8500 at 2.2v 1020mhz 510 2:3 at 5-5-5-15, Ati Radeon X1900xtx, Enermax 535w SLI ready power supply, heatsink thermalright xp90-c with Panaflo 90mm high output fan. Case Xaser II with 5 80mm fan at medium speed. Oh and Soundblaster Audigy card. My temps run between 28 idle and 54 dual prime depending on case fans, on high can keep system under 50 degrees at all times.
http://valid.x86-secret.com/show_oc?id=113134
I don't know how to post pictures in here, but I hope that link and information is all you need to put me on the list.
My stable OC is only 2.8 Ghz. I don't know how people get 3.2 Ghz with theirs but it is good enough for now. Maybe I have a bad chip.
Setup:
Intel Core 2 Duo E6400
2800 Mhz
Stepping 6 B2
Week L624 Week 24
Code A849
65W
1.3125V
Air cooling
Scythe Mine with 100mm 2000 rpm fan
Gigabyte DS3
Bios F4e
Corsair
6400
350 Mhz
5-5-5-12
CPU-Z validation code 112787
http://valid.x86-secret.com/show_oc?id=112787
OC Result:
Anakin357
E6400 @ 3.2 GHZ. L624A769
Gigabyte's Motherboard is so amazingly BAD in the voltage department, I have no idea what the "real" volts are - this is what is set in BIOS:
+0.3V on Northbridge
+0.2V on DIMM
XP-90 w/ LGA775 Bracket + Panaflo 92MM M1A
HR-05 w/ 80MM Fan on northbridge chipset.
Gigabyte GA-965P-DS3 Bios Version F4
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 DDR2 675 (PC2 5400) Running at 800MHz, CPU-Z says it's at 5-6-6-18
http://valid.x86-secret.com/show_oc.php?id=111240
soon.... soon I will have all my weapons in hand, and i will strike down all who stand before my path to overclocking gawddomme. fear my overclocking newbness! give me 'til monday, and i'll show y'all how a rookie OC's. ;p
Don't mind the time:) Ran @ 4:3 on Infinity 975X before it gave me a fit with new beta bios 816.
TT big typhoon cooling..Bios 731.
Sooo.... here's my stable result
CPU-Z validation: http://valid.x86-secret.com/show_oc?id=113583
E6400 @ 3408 Mhz, 1.36v, B2 stepping, batchcode L624A869
Aircooled with Scythe NinjaPlus
Gigabyte P985-DQ6 board with BIOS F3
2x 1GB Corsair TwinX XMS2 6400C3, rated 800 Mhz 3-4-3-9 2.2v @ 852 Mhz 3-4-3-9 2.2v
Update: 3DMark06 :)
Is that 4GHz result stable? If it is not I would put in the not stable section but I can't do
that because you already have the 4,658 overclock using that CPU and that motherboard.
I was going to send you a PM with the above message but you mailbox is full.:(
*also posted on VR-Zone...I'm liking that forum...friendly folk*
Turns out a faulty 79GT...who knew? :rolleyes:...had been foiling all my previous attempts. The above has been accomplished with only .1 on the MCH and FSB. Vcore's still stock and it seems my RAM will be the limiting factor here as it dies out around 925. I've got an E6400 sitting on the desk, but now I'm wondering if I owe this proc some true RAM love. That or maybe I can send a message to !ntel and get my multiplier unluck code for the low low price of...an E6800...bastards! Anyway, it's glad to have finally resolve my "crashing in picasa, crashing in Quake 4, crashing when sending an IM" issue. :p
EDIT: Changed !ntel cause those little links are giving my ADD ADD.
What is your BIOS version and L6##A### code?
Also that screenshot shows a 50 minute benchmark run which means that overclock will be in
the not stable section of the database until you can provide a pic of a 4 hour or more run.
Huzzah!
Dan and/or Kyle have linked to this thread in the last page of [H]ard|OCP's Asus P5B Deluxe review!
I have already read it and enjoyed it, you should as well. ;)
zoob
Retail E6600 - L626A167 - Step 6 B2
3200 MHz (400 x 8) @ 1.40 V BIOS
Asus P5WDH, BIOS 0801
OCZ OCZ2P8002GK PC6400 DDR2-800 @ 4-4-4-12, 2.1 V
Cooling: ThermalTake Big Typhoon (lapped) @ 870 RPM (Q-Fan optimal mode)
Housed INSIDE a P180.
C2D 6300 L625A705 @ 3.150ghz - FSB 450mhz
Corsair 6400 4-4-4-12 @ 900mhz
Arctic Cooling Freezer 7 Pro Heatsink
E6400 L624A869 B2 6 @ 3071Mhz
Intel 975XBX Rev 304
OCZ PC2-8000 D9GKX @DDR 960 5-5-5-15 2.1Vdimm
Stock cooling and Vcore.
Have only done intial testing of CPU but havent touched the RAM yet. Will be getting a TDX tonite and begin WC testing in the next couple of days.
Ran Orthos overnight with no issues. Only problem I have encountered is mounting stock cooling properly. Really, really did not want to seat correctly. Other than that, these are a delight to work with (other than the XBX hard lock restoring).
Here is my latest...
IDC Staff
Processor Info:
Intel E6700 CPU OC 3804
Steping 6B2
Week L623
Code
A548
Watts
65
CPU Volts
1.500
Cooling Method
Phase
VapoChill Lightspeed Phase
Motherboard
Asus P5W DH
1101
RAM
Corsair
XMS2 8500-C5
760
4.4.4.12 at 2.2 volts
CPU Validation Link
Is CPU Z reading your memory timings incorrectly? It says 5-7-7-23, not 4-4-4-12.
Please be more specific than just "stock voltage". Stock voltage often depends on the
motherboard used. Also what BIOS version are you using?
E6400 LG24A865 Stepping 6 Rev B2 400X8= 3.2Ghz
1.325 Volts on Gigabyte DS3 (Official F4 Bios)
Patriort 5300LLK DDR2 667 (1.9V) 800 at 5-5-5-15
Zalman CNPS9500 LED
Ambient Temp : 29C
Idle : 50C
Load : 59C
Orthos Stable
Zalman CNPS9500 LED
Ambient Temp : 29C
Idle : 50C
Load : 59C
Orthos Stable
I noticed your Orthos window says "7 minutes and 16 seconds". Did you run it successfully
for more than 4 hours? If you say that you did I will trust you.
Yeah I forgot to take a screenshot this morning after I ran Orthos all night. Its stable. Just set it up to take another screenshot. It's legit
I thought that might be the case...
Just goes to show you that like Sauron, nothing can escape my gaze. Mu ha ha ha!
Sry:) Using 1334 BIOS with 1.3Vcore DMM tested.
Anyone know how to turn of C1E on the XBX???I have EIST shut off but I get 1.1Vcore at idle.
I was wondering that too but the SPD tab says 4-4-4-12 and so do the specs for the model I bought on the package and on the zzf site. Havn't found a way to change the timings on my DS3.
(Hope ya don't mind, I'm using your post as template Kyle!)
User Name: Jodiuh
Stability: 7+ Orthos (Medium-High IMO)
Temps: Speedfan
E6300: 1.860Ghz
OC: 3.150GHz
Stepping: 6 B2
Week: L626
Code: A240
Vcore: 1.325V
Cooling: Air
P180 w/ 3 Tricool fans on Med
Zalman 9500 High
Ambient: 25C
Idle: 32C (Outlook, Firefox, etc.)
Load: 49C (Orthos 7+ hours)
Mobo: Gigabyte GA-965P-DS3
Bios Version: F4C
FSB: +0.1V
MCH: +0.2V
Ram: Patriot DDR2-5300C4
Speed: 900Mhz (450*2)
Latency: 5-5-5-15
Vdimm: 2.1V
Pics:
Comments, concerns, violent reactions: <---taken from Teach
I also bit on a $420 deal for another DS3/6400. Should I...
1. Get some 1000Mhz RAM and give the E6300 a chance to breath.
2. Use E6400 w/ current RAM, hope for 3.600Ghz and call it a day.
EDIT: Changed Vcore to 1.325 from 1.350.
B2 E6600 are growing on the board day by day , cant wait.
Also got the syte Infinty today , yipeeee. The 590SLi left.
I am gonna go eat now.
You guys should post some not stable overclocks for me. Crank it up so high that you can
barely run 3DMark05 or SuperPi.
Gonna steal Kyles template too:)
This is my 50% OC max on the XBX with the 1066 strap and 533 divider.
User Name: turtletrax
Stability: 32M SuperPI
Temps: Intel Desktop tools
E6300: 1.86MHz
OC: 3.2GHz
Stepping: 6 B2
Week: L64
Code: A869
Vcore: 1.30V
Cooling: Air
CM Stacker
Stock Cooling
Ambient: 25C
Idle: 39C
Load: 49C SuperPIx2
Mobo: Intel 975XBX
Bios Version: 1334
FSB: +0.1V
MCH: +0.2V
Ram: OCZ2P10002G-K
Speed: 800Mhz (400*2)
Latency: 5-5-5-15
Vdimm: 2.1V
I am pretty sure I am stable at this speed, I am having RAM issues with the 1066 strap and 667 divider. Still have to try the 1333 strap as I am still learning all this intel good stuff:)
User Name: Shocky
Stability: 4hours+ Prime95
Temps: Everest+Easytune5
E6600: 2400MHz
OC: 3400MHz
Stepping: 6 B2
Week: L623
Code: A790
Vcore: 1.475V Stock: 1.35V.......
Cooling: Air (Scythe Ninga Plus)
Ambient: 20C
Idle: 30C (Easytune5) Idle: 45C (everest)
Load: 53C (Easytune5) Load:65C (everest)
Mobo: Gigabyte GA-965P-DS4
Bios Version: F3
FSB: +0.20
MCH: +0.20
Ram: G-Skill 6400 HZ
Speed: 944Mhz (472*2) Stock: 800
Latency: 4-4-4-15 Stock 4.4.4.12
Vdimm: 2.150V Stock: ?
http://valid.x86-secret.com/show_oc?id=114329
http://homepage.ntlworld.com/storage/prime95.JPG
http://homepage.ntlworld.com/storage/prime95pass.JPG
e6400 retail with a p5b deluxe bios 0507, corsair xms2 pc6400 4-4-4-12, and scythe mine. :p
still looking to push it a bit further. seems stable enough, although i haven't run prime95 yet.
Question...what's default AUTO Vcore on DS3 @ F4C Bios? I put 1.35 for my post, but EZ Tune shows 1.33 and cpuz show's 1.312
aight peeps i'm having a whole slew of problems, and OC'n on intel is new to me. i'm so confused! hehe.... umm... somehow i'm at 3GHz so i guess i'm doin something right. ;p let's see i've got an msi 975x, with an e6400, and 2gb of ocz 6400 plats. my fsb is at 375 right now with auto volts on cpu 1.9v on the ram. i'm tryin to hit 400 but am kind of reluctant to go that high because i'm using stock cooling atm. my noctua hsf doesnt come in til friday, that's when i'll go all out, but 'til then i get to work out all the kinks in this thing (lots of problems with these mobos). well for the time being i'll let yall scope out some screenshots.
:D
yah i know... something's wrong with the mobo reports to speedfan. ;p
oh yah... and the "steppings" for this processor are: L625A452
User Name:
Stability: not tested as of yet
CPU name : E6400
OC: 3006.9
Stepping: ?
Week: L625
Code: A452
Vcore: auto (1.2)
Cooling: air
Cooler brand/model: intel stock
Motherboard: MSI 975x Platinum v2.1
Bios Version: v 7.12
RAM brand: OCZ
RAM rated speed: 6400
RAM actual speed: 750
Latency: 5-5-5-10
Status
