$150,000+ while offering only 300-500 miles range between lengthy charges. Uh, good luck with that.
All semi's are very expensive.
i have been saying they really need to add such to all electric vehicles. That way those in their prius can pull up to a stop sign and "rev" their engines to make it sound like an old muscle car
Electric motors aren’t engines. Making the ICE acronym rather silly. Especially since given the context of cars/trucks I believe all the engines are internal combustion.There is no magic in traction control. Also its not just traction control. Electric engines are capable of producing the torque faster than ICE engines. There isnt a "transmission" in the same way there is in an ICE car which is what causes ICE cars to lag on acceleration (as gears shift).
Lolwut. Have you never been to a truck stop? There are completely separate fuel lanes for four wheelers and big trucks.. They are usually even on completely opposite sides of the lot
The regular trucks here are 60 ton and with special permit, 105 tons. I doubt the electric truck will be a success - there are a gazillion of truck stops that lack a charge option.
But mostly I just have a vendetta against that acronym because of the stupidity of BP refineries. They used to require everything in a operating unit to wear a magnet that said ICE on it, redundancy basically, however they also made people put those placards onto fully electric man lifts with no combustion components. Pure idiocy that too years to go away.
To actually add on to your comment about transmissions. In turbo charged vehicles there is also additional lag while the turbo(s) spin up.
Yeah, but fuel lanes, you're supposed to fuel up and leave, or shuttle into the yard. You're not supposed to park there for an hour or more. As "pump" space is limited.
And I don't know how many stops are gonna burn the gobs of cash necessary to put these in their lots.
Remember, 99% of the truckers who come through are decent enough people.
And 99% of the remainder are decent enough people, they're just assholes.
The final remnant are the ones who give truckers a bad name. Steal anything that's not nailed down. And if it's nailed down, steal a pry bar or claw hammer first. And if they can't steal it, they vandalize it.
Well if you want to be technical there were some cars with sterling engines and steam engines. But I am not disagreeing with you - I was just using the vernacular that the person I replied to was most likely to be familiar with.
We have a similar issue with turbos in aircraft and jet engines vs piston ones.
Surely you mean, more widely, turbine engines.
And its not really an "issue" per se but just the way it works. Its an "issue" if you forget that and wanted that thrust immediately
I'm wondering how 'fuel taxes' are going to be handled. Diesel and Gasoline taxes help pay for the roads. Right now EV's aren't taxed like that... but when enough of them are on the road, they will be.
I was going to say they'd do the math for joules in diesel vs what the battery charger use feeGPS trackers...
I am sure whoever orders a fleet of these will have 240v stations at their loading zones.
It's traction control. If those electric motors leaped directly to peak torque without it, it'd sit and spin the tires. An ICE diesel hits peak torque (1000+ ft/lbs) at relatively low RPM (1200 or so) and has absolutely zero traction control beyond a simple differential. They rely on the weight of cargo to keep the drive tires stable.
Put the two trucks on a line, and the Tesla would smoke the diesel because the diesel would sit and spin tires running bobtail. Put them both on a line with an 80,000lb load and they'll run neck and neck.
Now, give the diesel some efficient form of traction control and line them both up bobtail, and whatever margin the tesla wins by is then because of the electric engines.
Charging time isn't that bad considering most short haul trucks are sitting at their pick up or drop off for that amount of time anyways.
Most brand new diesel rigs are in that price range. I was expecting $250k+ personally.
So it costs roughly the same as a new Semi (my friend in the industry said 150k is not unreasonable if its a nice truck, 200k is possible if its all tricked out) and uses no gas. Yeah I think they could have good luck with it.
"Sex appeal"? I know plenty of people who think electric cars are so much sexier because they can get to 60mph faster than ICE cars. Why? They cant really answer that...just that its cooler to get there faster.
The reason that tesla is so damned fast off the line is traction control magic because electric engines.
What kind of outlets do these trucks need to plug in? I assume multiple 240v or equivalent. Charging at loading/offloading I assume would be pretty measly with 110v.
Exactly now its it just doesn't sound the same... And I think I've read something about the smell so there is that... Next it will be the dangers of neck pain due to the excessive acceleration... Deep, serious concerns against electrics.A car's 0-60 time has been the defacto e-peen metric since the advent of them, and certainly since muscle cars. But now that EV leaves ICE standing still at the line, it's "Hey man, 0-60 doesn't matter. The race doesn't matter. Why are we in such a hurry anyway?" Comedy.
I'll just leave this here...
If your managing a fleet of these you just swap battery packs and go on. Throw the depleted one on the pile, the wheels keep moving. Heck it would be automated with a robot. Faster than filling a fuel tank. Still have to give truckers time to piss or eat I suppose.
With commercial fleets you are talking completely different scale vs me parking a car in my garage. Indeed electric vehicles may make far more sense for commercial trucking than for personal vehicles because it's far easier to manage things like swapping battery packs with a small number of large fleets then millions of individual car owners.
There are plenty of fleet only fuel stations around me already so it's not like electric vehicles bring a new concept as far as fleet fuel management goes.
Nobody mentioned the invisible trailer its pulling.Tesla has previously said their semi truck can do 0-60 in 5 seconds and loaded with 80K pounds it can do that in 20 seconds. I would have to see that to believe it and now I've seen a video that makes me tend to believe Tesla and their claims. Check this out.
Watch the video here.
That's why the BMW i8 hybrid supercar produces fake engine noise. Even modern combustion engines can be a bit *too* efficient and aren't loud enough so they add fake noise. https://www.washingtonpost.com/busi...77832eafcb4_story.html?utm_term=.47d60bb8a342The speed of electric vehicles doesn't impress me on a visceral level the way powerful combustion-based ones do. They sound like giant RC toys.
Uh I didnt make the post you replied to. Why did you change the quote to my name?
I'd like to see a trucker speed up and block a car that is trying to cut it off.
