lolIgg said:Top Nurse, do you work for Sharka?
TN = Wes? (Stab in the dark)![]()
The sad part is SNT was a great place to order from just six months ago. I am still shocked Dan has refused to post anything on his forum about the his business, if there still is one. To each his own, but SNT could have made a ton of cash of AC products. I guess the easy way is just to remove posts and sub forums.Igg said:Good drama at SNT , supposely ppl have ordered stuff from march and still no words from the owner...
Glad i ordered from sharka.
Top Nurse said:But I am going back to work saving lives this weekend so I am not going to be as available as I have been.But it's been fun
tbooth said:Well, I managed to take a couple crappy pics before the batteries in my camera died. The EVO 240 fits perfectly in the back of my V2100, well I did have to move the power supply down a few inches. Anyone know where I can get some molding to fit on the edge in front of the radiator?
Happy Hopping said:http://www.cnn.com/2005/WORLD/europe/06/02/dutch.poll/index.html
W/ 2 countries backing out of EU, the currency exchange of Euro is getting weaker.
Igg said:Duh, forgot that you were a nurse, stupid me.
How many hour shift?
Top Nurse said:12 hours is standard in critical care units
Top Nurse said:A new Sharka shipment is leaving Austria no later than Monday or Tuesday from IT-Trade. More of everything that was already in stock.
more AquagraFX 6800 Rev 2 and AquagrATI 800/850 coolers!
Igg said:Yay, my aqua fx is coming in, I wonder how long it takes to get from there to sharka.
Master Ninja said:I need opinions. I'm hoping to cool an Athlon64 3000+ overclocked and a GeForce 6600GT non-overclocked, and I can't decide between getting a better block or a bigger radiator. Which of these do you all think would drop temperatures more? (Note: these are both theoretical item lists)
- Eheim 1046
- AC Cuplex Evo
- 120x2 radiator
- 1/8" tubing
OR
- Eheim 1046
- AC Cuplex XT
- 120x1 radiator
- 1/8" tubing
I think with a low-flow rig, a bigger radiator would make more of a difference since the water would spend more time getting cooled down. Opinions?
Top Nurse said:This is what I would suggest as the Cuplex Pro's are about 30% less expensive compared to the XT, which will give you some scoots for your TwinPlex and bigger radiator.![]()
Master Ninja said:Yeah, I forgot the Twinplex, but that'd be in there too. I can't find the Cuplex Pros for sale anywhere in Canada or the US, though. It's all Evos and XTs.
Common misconseption with rads. As Cathar explained in an overclockers.com article, fluid flows through a radiator so that the heat will be pulled into the rad fins. While it may sound like slower=better cooling, think about your WC loop as race track. If the rad takes up 1/4 of the track, and it takes you 1 minute to go around the track, youll spend 15 seconds going through the radiator. Now if it only takes you 30 seconds to go around the track, in 1 lap you will only spend 7.5 seconds going through the rad. But as the first example took a minute to go around the track, if you give the 30 seconds/lap example 1 minute to go around the track, you will have spent a total of 15 seconds in the radiator, just as the first example.Master Ninja said:I think with a low-flow rig, a bigger radiator would make more of a difference since the water would spend more time getting cooled down. Opinions?
J-Mag said:Hey anyone know if the RPM cable that attaches to the Aquastream controller and the MB Fan Header is pulling amperage from the MB header or not? The fact that it is using all three wires makes me suspicious...
lemmy said:whats diff between cuplex xt and silver cuplex xt?
ikellensbro said:Common misconseption with rads. As Cathar explained in an overclockers.com article, fluid flows through a radiator so that the heat will be pulled into the rad fins. While it may sound like slower=better cooling, think about your WC loop as race track. If the rad takes up 1/4 of the track, and it takes you 1 minute to go around the track, youll spend 15 seconds going through the radiator. Now if it only takes you 30 seconds to go around the track, in 1 lap you will only spend 7.5 seconds going through the rad. But as the first example took a minute to go around the track, if you give the 30 seconds/lap example 1 minute to go around the track, you will have spent a total of 15 seconds in the radiator, just as the first example.
Basically, extra flow doesnt decrease a rad's cooling ability, the flow just takes more heat off of the blocks, giving the rad the ability to remove more heat.
simon27 said:so... bigger rad > uber leet block?![]()
Top Nurse said:I don't believe so, why don't you snip the +12v line and see what happens?
Top Nurse said:Price wise about a $100. Performance wise no one knows as the first ones to get here are ShoNuff's and mine. However, silver does have better thermal conductivity over copper. They also really look nice!
I think there are still some available by special order only. However, there is only going to be 100 of these blocks ever made. So....order now or forever hold your piece.![]()
J-Mag said:Also, when society crumbles and all curency is devalued, the silver in your waterblocks could come in handy
Master Ninja said:Conclusions:
- If all other components are unchanged, increasing or decreasing the waterflow of a system will not affect the system at all. It will only affect the difference between the high and low temperatures in the loop.
- If forced to choose, a larger radiator will be more effective than a better waterblock.
A good block will increase the high temperature of the water, which will increase the equilibrium temperature
A larger radiator will decrease the low temperature of the water, and also decrease the equilibrium.
- When choosing a block or radiator, choose ones with a high thermal conductivity, lots of surface area, long pathways and low thickness. All of these will increase the transfer rate of the part.
SCIENCE!
Cathar said:Right on that it does affect the high/low temps in a loop.
Wrong in that it only affects the high/low temps in a loop. Increased waterflow increases the Reynold's number of the water, improving the convectional heat transfer of both the radiator and the waterblock. The waterblock will perform better, as will the radiator.
Wrong. A good waterblock offers a lower degree of thermal resistance between the CPU and the water - it does not increase the temperature of the water. The temperature of the water is dictated by the heat-load, which does not change when one changes the waterblock, and how well the radiator is performing.
Rather than go by a visual point of view, I would suggest actually obtaining items for which their thermal properties have been correctly measured and ascertained. A visual inspection of an item is quite likely to be wrong.
Master Ninja said:Then at what point does a pump become too powerful for a loop? Everyone here has indicated my Hydor L30 is too strong for a low-bore system, but does that mean I should spend the money on a less powerful pump when I already have this one?
Nevertheless, lowering the thermal resistance will allow heat to transfer from the CPU to the water more efficiently, thereby increasing the amount of heat that transfers to water that is in the block. The heat load will not change when the waterblock changes, but the amount of that heat that can be transferred to the water will increase.
That's not always possible, unfortunately. Waterblock specs usually indicate the material they've been made of, but rarely include a measurement of their surface area. If it comes down to a choice of two blocks from the same material and no other information, how else can one compare if not visually?
I didn't mean to express my results as absolute, that was just the thought process I was going through in trying to solve my question. I still feel a larger radiator would be a better investment than a better waterblock; if I'm wrong, I guess you're the one who'd know.
Mysticcal said:Has anyone seen Dan around? I asked him to refund my money a few days ago because the black aquatube wasn't dated for stock, and then yesterday I demanded he refund me..... I still havn't gotten anything back as far as emails / funds go.... lets this be a note to anyone purchasing with him...![]()
