tjmagneto
[H]ard DCOTM x2
- Aug 6, 2008
Yes, my windows were open. Not very breezy yesterday. My wife is always complaining about how hot it is. Meanwhile, I have a sweatshirt on and 7 blankets.
Hormones(hers). Enuff said.
We don't have AC here, unfortunately
I'll see about cleaning out the 9800GX2. Have to shut down one SMP client for it as well, so I want to make it quick.
Feel free to ship CPUs and GPUs to my place. Hehe
Everything is included at my apartment. So utilities are never a problem. Our spare room has 2 active portable AC units at 10k and 12k BTUs PLUS Central Air. I'm setting up a rack 'closet' who can basically just run the portable AC year round. Our summertime thermostat is basically the windows. Everything is set at a chilling 64 degrees and when it gets too cold (and it does), we usually just open the windows to warm the place up.![]()
Whoa, no a/c in a westernized country? It isn't like you are living in the land of China or anything. No window unit either? I hate to see how hot your GX2 runs during the hottest summer days........
A/C over here in europe is rare as temps higher than 85F are rare where i live, hence no A/C. We prefer to cook our cards to within an inch of their live'sI've had my GTS 250 at 95c already this year and my 275 at 85c
I've been trying to keep my 275s under what you are getting.![]()
I know what you mean. My living room gets quite warm but since my kids are home for the summer I have to run the A/C anyway.So do I but we had a really hot day a few days back and someone in the house had closed all the windows. The whole house was an oven when i got back from work and my boxen took hours to return to a more normal temperature
Sorry to hear about the shutdown but with that bill I can understand.I just had to shut all of mine off, due to my powerbill getting to almost $380. might be back in the "winter."
God I hate florida.![]()
What part of Florida do you live in? One of my brothers lives in St. Pete.
I'm sorry to hear about your shutdown
I'm kind of worried to see what my powerbill is going to be like for the next billing cycle with the warm weather we have had recently.
Well I'm shutdown for the day. Last night I installed a new motherboard and now my GPUs are spaced farther apart so they should be a lot happier. I still have to install drivers for the board and do some testing before my PC is back up to full speed and folding.
VMware is available for Linux, but I believe he wants to retain a native Windows environment if I'm recalling past threads accurately. I've also wanted to try VMware for Linux but never got around to it and now I'm cutting down on Linux system by system because of the recent client changes and some hardware issues. It would be interesting though.With the A3 bigadv stuff, are you still running 2 VM's with bigadv or have you gone to native Linux yet to run a single bigadv client? If your wife has to use the computer, I wonder if there are any VM's out there that will let you use Linux as the host to run a Windows guest client.......
How did your system and dual VMs manage with the P2684 WUs, BTW?After I finish getting my system dialed back in with the new mobo I'll be running the dual bigadv VMs again. I have to start the whole O/C process over..
I wouldn't worry too much about the CPU as long as you have decent cooling. GPUs are a different story entirely. Shutting down the GPU client might help with CPU temperatures especially if your system is run with the case closed. What I would do is turn off the GPU client in the day when it's hottest, and leave the SMP client processing until you see EUEs. Leave the GPU client off for even longer periods if you experience a heat wave. When the GPU client is shut down, the SMP client will actually produce higher PPD. I think that's your best balance between PPD and temperature.Just shut down one of my Q6600s because it was running above 75C on its cores. That's about ~6k PPD gone. About 14k PPD left, and tempted to shut down the GTX275 as it's at 90C. I could also get a better case for it than the current one with only crappy 8 cm fans![]()
In the summer, in my opinion, SMP rigs with low power/integrated GPUs make the most sense. If you can, pull GPUs out of your SMP rigs rather than shutting down SMP clients.
Arghhh..........
Now my central a/c unit broke. I may have to shut down my rig now as we are supposed to get into the 90's today. The house is already at 85 degrees and the humidity just sucks...........
I'll be keeping an eye on CoreTemp and will shut down if it reaches over 82 degrees.
Anyone feeling generous? :3
In that case, do as others suggested and remove the GX2 from your system. I have one myself and understand your situation. Don't worry about the CPU, they are surprisingly resilient unlike GPUs. In the past before GPU clients were released, I used to be able to run more systems in my farm and they produced far less heat than presently. I rarely had any kind of issues those days unless a cooling component or other crucial part was malfunctioning. To recap, remove GX2 until fall, and either use onboard video or find an old low-powered card that runs cool. Your SMP client will also perform quite a bit faster without the lost cycles from the GPU clients. If you find your processor still runs too hot for your liking, then reduce the number of cores in the flag for your SMP client.Even with the GPU client not running the 9800GX2 manages to heat up the system considerably. The Q6600 system (identical other than the GPU) does ten degrees less on its cores with just an IGP.
Sorry to hear that, lassiterbI guess that's mostly from running the AC?
Earlier I proclaimed that I wasn't going to let the summer heat cut into my folding. Well I just got a reality check (bill actually) in the mail this week. My power bill jumped from $280 to $450 for the month of June. Yawza! So I shutdown my main rig to help cool things off, and I'm parting it out to help pay the bills so check the DC/FS thread for some nice hardware.
