- Aug 5, 2013
Don't bother mass producing any mining outposts, cargo links sporadically break themselves and it seems totally random.
I have 9 outposts all linked up, worked fine for several hours and now 2 of them just stopped working. I had fixed 2 others earlier today, those still work.
I've spent the last 2 days building outposts all over the place and trying every possible combination of cargo links to make it work, and it just doesn't.
All Bethesda had to do was copy FO4's settlement system and it would've been fine. They fucked it all up and I doubt they'll ever fix it, maybe when the dev tools come out a modder can fix it.
If you actually need mined resources, the only real way to do it:
1. Find a planet that has the resource you need.
2. Use your on-foot scanner to find an outpost area with the most amount of the resource in it.
3. Fill the entire place with as many extractors as you can fit, and connect them to as many storage containers as you need.
4. Go do something else for an hour.
5. Come back, loot all your resource from storage, then hold "R" on the outpost beacon to instantly delete everything.
Don't use cargo links at all. They *might* work if you just build one, to connect 1 outpost to another, but no more. It's best to just pretend cargo links don't exist.
The truly sad thing is that there is a perk buried down in the 'Social' tree that DOUBLES the amount of cargo links you can build. I can't even imagine what the purpose of that is.
