OK, again, thanks a lot. I guess I can live with that.
As already mentioned, you'll need to define how you want the signal path to work: do you want to keep things in the digital domain as long as possible, or does using simple analog cables and interconnects work for you as well? Personally, after having dealt with this kind of hardware for close to 30 years now, I don't give a flying crap about what people say when it comes to analog vs digital. If you build a solid system, there isn't going to be much difference between using the digital output from the source or the analog.
Our human ears simply cannot be that precise, period. The biggest benefit to pure digital is there's roughly no chance of crossover or serious signal degradation which can happen with extreme connects/cable runs (meaning length). And no, paying $100 for a 6 foot piece of RCA-type cabling won't make a difference compared to the same cable that costs $5 from Radio Shack or even Walmart. This stuff is myth, all of it. Technically, on paper, and to the 15th decimal point there can be a measurable difference but not to our actual analog ears, sorry.
If you want to get everything set up, you decide on what you want first: how many speakers total, what you plan to use as the source (simple stereo output from the PC, multiple outs from a 5.1/7.1 sound card, etc), then work on handling the source material based on how many outputs you're going to require.
If you grabbed the M-Audios or the Behringers they're powered, just like the Promedias, so they just need an input, and from what I can tell the M-Audios are analog input only; the Behringers offer analog or digital inputs. Some would argue the more inputs the better, so whatever. Analog is fine for me, probably always will be.
Let's face it: regardless of what hardware you've got, until the day when we can jack out brains into a real digital output and keep it purely in the digital domain from start to finish, we're still in an analog world. Speakers are analog, our ears are analog.
I think that's a good enough match.
Well, i ended up with a different solution. Now I realize it is a bit more coin than the Behringer solution and I never actually listened to the Behringers to comment on them, but he happened to have some Paradigm Titan v.4 Mini Monitors that he stocked up on a while back before they were discontinued. I had heard good things about Paradigm, and figured what the heck.
Tonight I picked up the brand new Paradigm's and since these speakers do not have build in amps like the Behringers I also bought one of his fully refurbished/reworked used receivers (JVC 6008V) which I needed anyway. I am now running my computer into the receiver (2 x RCA Male / 1 x 3.5mm Stereo Male, Y-Cable) and then the receiver to these two incredible speakers. The difference between these and the logicrap is incredible. I am still setting things up, but I plan to compare the computer output against various other sources to see if I can notice a difference.
Now I understand that this solution is likely 3 times the price, but it is easily 100x better. It is so worth it. I am still breaking them in, but WOW! I realize ears are subjective, but I find it hard to believe that anyone could fault these speakers for the price. (under $250 for the pair)
This has made my day. Thank you for the info you provided and "push" in the right direction. I realize it was not exactly your solution, but it lead me down the path toward a quality solution.
p.s.
I was eyeballing the shop owners "custom" modded $600 paradigms, but that will be for another day...
I gotta admit, this thread got me looking at a pair of active monitors, and I ended up buying the Swan M200 MKII's (although that particular par wasnt mentioned in this thread). I chose those over the M10's as I had a bit more money to spend, and I already have a nice Yamaha subwoofer I am going to use.
Anyone have any real experience with these monitors? Apparently the MKI's where pretty popular.
While a great idea, Behringer's break down fairly easy. Their powered stuff is decent and an alright solution for budgeteers.
I prefer the BX5a's from M-Audio for Computing and gaming, due to their "beefed up EQ". I get a richer (but less honest) sound out of them. I have a set of KRK 8's as well that I use for music mastering. The BX5a's are a horrible reference monitor for musicians and mastering, but they're cheap as heck and great for gaming speakers.
OK, everyone. I haven't read all the posts, but I just upgraded to an Asus Xonar D2X soundcard.
I have Promedia 2.1's and some Fluance HT-AV speakers hooked up to a Yamaha RX-1400 receiver. All in all it is a decent 5.1 setup. I am looking to replace my Promedia 2.1's though with a better sub and front speaker setup.
I will be running the audio through the Xonar D2X optical out to the Yamaha RX-1400, then to the speakers and the sub. I am interested in the Dayton sub b/c my office is kind of small, but what speakers will work best for me?
Since I will have the Xonar soundcard and a good receiver, I just need some decent front speakers. Not really looking to spend more than $150 on a pair of speakers. Any suggestions?
Does your mobo's onboard audio have an optical out port? If so, you completely wasted your money on that D2X sound card. By using its optical out, you completely bypass all the analog circuitry in it that makes it so expensive. The optical output from a mobo and from a really nice soundcard like that is bit for bit exactly the same.
The only reason one would get a nice soundcard, is to USE the great DAC circutry in them.
Sorry to break that to ya...
Just 2.0. I will most likely get the Dayton 8" sub. My office isn't all that big, so I don't want a large sub.
EDIT: Took a look at the D1080's. I will keep them in mind, but the review I read didn't really impress me.
How does Dayton stack up to brands like Polk and Velodyne?
