96redformula
- Oct 29, 2005
I myself am loving single player.
One Major gripe I have is the vehicle controls, they blow beyond belief.
OK, I posted the fov trick, and I can't get it to work for the life of me, but everyone else seems to be doing it just fine. Anyone have any luck doing it with windows 7 and cat 9.10's?
This file already has FOV=90 in it...Try the willowengine.ini just find the fov line and edit it.
Maybe your eyes adjust better.Can someone explain this FOV issue? I'm not seeing it. The game makes me tear up more than other games if I stare at the screen for too long..but that is because I don't blink. Lol.
But when you setup the hotkey to switch the FOV to 90, this is what you get:
Before:
After:
Only change between the two screenshots was hitting F10. Ok, back to this fun game![]()
Change the "MouseSensitivity" value in the BaseInput.ini file in the game installation folder. There is also a 'MouseSensitivity' value in the in the WillowInput.ini in the 'my documents' folder, which I think is a multiplier of the MouseSensitivity value in the BaseInput.ini. Editing just one of them should be sufficient.
This fixed my FOV issue
http://hardforum.com/showpost.php?p=1034817210&postcount=664
Now I just need to fix my mouse sensitivity issue, grrrr.
This does absolutely nothing for me. Is there a specific area to put the line of code, or can I just put it with all the other bindings?
I manually edited the WillowEngine.ini file and set the FOV to 106 degrees. Works fine for me with the Steam version.I've figured out that the Steam version behaves a bit differently. I'm trying to figure it out on my own, I'll try to have something up tomorrow if no one beats me to it. I plan to play this at 4800x1200 soon, so not fixing the FOV isn't an option.![]()
Does this game seem like a console port to anyone else? The UI screams console port, as do the limited graphical options, poorly implemented mouse controls, FOV, lack of lean, etc..
I played for about 45 minutes last night and yes, it is fun so far. But for a game supposedly designed for PC first and then ported to consoles - it just feels like the devs were blowing smoke up our asses.
I'm up to a level 23 hunter, friend is a lvl 23 siren(sp)...Every weapon in the shops or any we find completely suck..
Do the other classes tend to level up faster? Or does the multiplayer help? I don't know how else to speed up the leveling process...95% of my kills are from critical hit headshots.
I'm soldier class level 18 right now. Been playing since 2pm cst yesterday on single player. Stopped for about an hour to eat and implement the FOV toggle fix.
Does all your stats, weapons, missions, cash, etc. from single player carry over to the multiplayer side also? Or do I have to start all over at level 1?
I played for 6 hours straight tonight with 3 friends and I love the game. I can't remember the last time I played a game on day 1 for so long with no breaks. Maybe wow? lol Anyway great game but it does reak of consolitis. I used the so called FOV fix here but it doesn't stick. As soon as you run or do anything you lose it and have to retoogle it. It sucks. Other than that its awesome fun. Oh and No AA support in game really? Come on.
