402blownstroker
[H]ard|DCer of the Month - Nov. 2012
- Jan 5, 2006
What is the safest way to remove the back part of a slot to allow a longer card to be placed into it? For example, putting a 16x card into a 8x physical slot.
I would use a dremel with the flex attachment, but you could probably use a small file or something.
I've actually seen some motherboards recently that just came with the slot already cut like that.
a hot knife or oscillating multi-tool. a dremel can leave conductive dust/residue
