- Apr 29, 2005
Sweet mods, thanks
Are people running the official HD texture pack with community mods?
Awesome! Cool to see some more content making its way into the game.
Did they ever fix the zoomed in menus when using eyefinity?
Birds and Flocks
http://skyrim.nexusmods.com/downloads/file.php?id=11555
Cloaks of Skyrim
http://skyrim.nexusmods.com/downloads/file.php?id=12092
No Boring Sleep-Wait Menu
Increases the wait time to 1-720 rather than 1-24.
http://skyrim.nexusmods.com/downloads/file.php?id=12625
Automatic Variants
This is an especially cool mod that I'm surprised hasn't gotten more attention.
http://forums.bethsoft.com/topic/1355628-relwip-automatic-variants/
DYNAVISION - Dynamic Depth of Field
I don't like it but some people might.
http://skyrim.nexusmods.com/downloads/file.php?id=12525
Anyone having issues with Skyrim freezing on autosaves? I'm using the Skyrim HD texture pack and the official HD textures pack as well as [H]'s suggested tweaks (uGrids is at 9 though). I've played with these settings pretty much since the game came out, but this is recent.
Dual Wielding worked perfect for me. Equip your offhand, then equip your primary hand, then set the primary hand to the favorites. Then bring up a torch and equip that then set it on favorites. Clicking the favorites for torch and dual wield primary weapon should properly equip the weapons.Did they ever come up with a solution to hotkeying for dual wielding? I just want to be able to switch between my weapon and a torch...is that so unreasonable?![]()
I saw some video on youtube where you can make a hotkey for switching the left and the right hand, so it could technically work if, to re-equip my offhand I always (1) equip my offhand (2) hit the swap key, and (3) equip my mainhand. Was thinking about trying that but never got around to it. It really feels like there should be a better solution by now.
Yep, that fixed it, thanks!How many hours do you have on that autosave? At some point the autosaves (and quicksaves) just get currupt, there is a lot of information in those saves if you have 50+ hours. If you can get the autosave to load, us an actual save slot, then exit and delete the autosave. It should fix the issue.
Is there a mod that adds numbers to the character creation screen? I thought I saw one some time ago but I cannot find it.
Thanks for replying, but I had tried it all and so far no dice. I think it's the patch 1.5 if anything. I'll try deleting the whole game and redownloading next, other than that, there's nothing I haven't tried.I recall having an issue like this in Fallout 3. In order to fix, you had to kill your character then reload your save. Afterwords I would be able to auto-save for several hours until the bug struck again. I found it was being caused by one of my mods because it finally went away after I deactivated several of them.
Anyway, not sure if this is the same issue or if it will work in Skyrim but it's worth a shot.
This is the first time I've ever had trouble with them, and I played all of FO3 + expansions and through FO: NV as well. I like to had autosaves on in case I forget to save or I want to try a different approach to an encounter/convo/fight/whatever. Currently, it's not too much of an issue and the game will only freeze after a few hours.Why are you spending so much effort in getting autosaves to work correctly? They have always been troublesome for the semi-recent Bethesda games so it is best to just turn autosave off.
There are autosave mods if you absolutely need that functionality. The other advice here is spot on, disable the built-in autosave feature.
