Skyrim Modding Megathread
Start fresh and keep your saved games + old ini files? None of the mods you listed should cause a dependency.
Mine won't even load after the update. I go into task manager and it says it's running, but it's not. I only had some hi-res textures, and I tweaked my .ini's, and that's it.
Tried that. It still crashed. :(
You're not using the old 4GB patch are you? Running TESV.exe should work, in theory.
I WAS using the 4gb patch. It won't load, and TESV.exe won't work either. The launcher shows up. That's it though.
Make sure you delete all files associated with the old 4GB mod. I would also get rid of anything associated with SKSE, although there is a new version out that's compatible with the new patch.
You could also try "Verifying Cache" on steam a few times.
I just got the latest version of the 4GB mod, and same thing. Skyrim will not load AT ALL! frustrating.
Oh, and I tried it without any of the files for the 4GB mod.
Yes, I know. Skyrim will simply not load for me. I'll go to task manager, and it says that it's running, but it's not running. This is after the patch, and just TESV, not the 4GB mod.
Tried the cache, and haven't deleted all the files. Just the exe and some dlls... Thanks for your help btw! I'm guessing I'm gonna have to delete them all, eh?
It says I gotta log in... I'm just about to be finished re-installing. If it works I'll try your saved file.
Edit: any other sites you can try? I don't want to download dropbox...
Don't they just unequip it every time you leave your house?
if you just put it in their inventory then yes, but if you manually remove their 'hidden' items then no. this is how I got the buggy ones like mjoll/lydia to use what I give them.
Got Skyrim working, and your saved game works for me as well.
With SKSE updated and everything in order should I be launching the game with skseloader.exe or just via TESV.exe or via Steam?
If there are so many steam issues, can't you just use a retail or cracked version?
Retail version of Skyrim is irrelevant since it's a Steam based title anyways.
Cracked? Hit and miss.
I use SKSE, but I'm also using SkyUI which requires it.
I'm using SkyUI as well (everyone get this!!!) which is why I wanted to make sure I do this thing right. ;)
Yup, launch through the SKSE loader. TESV.exe is now natively LAA, so there's nothing to "enable" any more.
Reading through that thread... just wow. And wow to Bethseda not compiling it efficiently enough. Big props to ianpatt (SKSE team) too and his explanations. (he uploaded a version that will work with all steam versions)
Wow. I'll have to try that.
Question: What's Script Dragon?
TO my knowledge, just another script extender which sits in a folder. I have a mod which requires it, don't remember which one lol (too many mods omg)
Oh wow, I just installed it. Markarth would bring my fps way down normally, but now there's only the tiniest drop in framerate. What is this black magic wizardry!!?!??!
Compilation optimization lawl. who woulda thunk? :eek:
glad to hear an [H] got it working, can't wait to see it for myself!
edit:
People actually giving a damn.
Finally on break guys. I'll be overhauling the OP shortly. If anyone is willing to help compile the latest mods, that'd be super-I haven't been keeping up at all.
Sure, I'll help gather some mods I like.
Edit: Here ya go (One or more are repeats from your OP):
SkyUI
http://www.skyrimnexus.com/downloads/file.php?id=3863
QD Inventory
http://www.skyrimnexus.com/downloads/file.php?id=667
Immersive HUD - iHUD
http://www.skyrimnexus.com/downloads/file.php?id=3222
Recolored map icons
http://www.skyrimnexus.com/downloads/file.php?id=2032
Skyrim Flora Overhaul
http://www.skyrimnexus.com/downloads/file.php?id=141
Ice of Skyrim
http://www.skyrimnexus.com/downloads/file.php?id=3030
Re-Defined Dungeons WIP
http://www.skyrimnexus.com/downloads/file.php?id=3147
Lush Trees
http://www.skyrimnexus.com/downloads/file.php?id=3385
Lush Grass
http://www.skyrimnexus.com/downloads/file.php?id=3288
Weapon Retexture Project - WRP
http://www.skyrimnexus.com/downloads/file.php?id=1754
Enhanced Night Skyrim
http://www.skyrimnexus.com/downloads/file.php?id=85
XCE - Xenius Character Enhancement
http://www.skyrimnexus.com/downloads/file.php?id=2356
Silly Level of Detail - Wine Cellar -- SLOD WC
http://www.skyrimnexus.com/downloads/file.php?id=4260
Silly Level of Detail - Potions and Poisons -- SLOD PnP
http://www.skyrimnexus.com/downloads/file.php?id=4259
Enhanced Blood Textures
http://www.skyrimnexus.com/downloads/file.php?id=60
Better Decapitation Gore Texture
http://www.skyrimnexus.com/downloads/file.php?id=4285
Snow and Rocks HD
http://www.skyrimnexus.com/downloads/file.php?id=1382
Hectrol DWARVEN SHIELD DELUXE HighRes Retex
http://www.skyrimnexus.com/downloads/file.php?id=3996
Riften HQ textures
http://www.skyrimnexus.com/downloads/file.php?id=705
Skyrim HD - 2K Textures
http://www.skyrimnexus.com/downloads/file.php?id=607
Accingite Vos - Shields HQ Retextures
http://www.skyrimnexus.com/downloads/file.php?id=225
Ruins urn retexture
http://www.skyrimnexus.com/downloads/file.php?id=3453
High Quality Grindstone
http://www.skyrimnexus.com/downloads/file.php?id=3506
Ornate Saddles
http://www.skyrimnexus.com/downloads/file.php?id=3200
N-R HD Display Case
http://www.skyrimnexus.com/downloads/file.php?id=3693
Enhanced Distant Terrain
http://www.skyrimnexus.com/downloads/file.php?id=1598
Better Noble Beds
http://www.skyrimnexus.com/downloads/file.php?id=2533
Hybrids Hires Plants and Herbs 1024 Retexture
http://www.skyrimnexus.com/downloads/file.php?id=1546
Reign Of Fire Dragons
http://www.skyrimnexus.com/downloads/file.php?id=2271
Nightingale Prime
http://www.skyrimnexus.com/downloads/file.php?id=1896
3rd Person Animation Tweak - Sprint with Magic
http://www.skyrimnexus.com/downloads/file.php?id=404
Midas Magic - Spells in Skyrim
http://www.skyrimnexus.com/downloads/file.php?id=3413
Improved NPC Clothing - High Res
http://www.skyrimnexus.com/downloads/file.php?id=2674
RWT Realistic Water Textures
http://www.skyrimnexus.com/downloads/file.php?id=711
Intricate Spider Webs
http://www.skyrimnexus.com/downloads/file.php?id=2532
Deadly Spell Impacts
http://www.skyrimnexus.com/downloads/file.php?id=2947
Realistic Smoke and Embers
http://www.skyrimnexus.com/downloads/file.php?id=836
Alternate Sun Glare
http://www.skyrimnexus.com/downloads/file.php?id=1653
Better Sorting
http://www.skyrimnexus.com/downloads/file.php?id=2730
Weapons of the Third Era
http://www.skyrimnexus.com/downloads/file.php?id=3871
TESV Acceleration Layer
http://www.skyrimnexus.com/downloads/file.php?id=4387
And a few more:
Natural Eyes
http://www.skyrimnexus.com/downloads/file.php?id=3589
HD Furniture and barrels final
http://www.skyrimnexus.com/downloads/file.php?id=238
Chris2012s Whiterun HQ Texture Pack
http://www.skyrimnexus.com/downloads/file.php?id=114
Better Gold
http://www.skyrimnexus.com/downloads/file.php?id=362
Realistic Paper
http://www.skyrimnexus.com/downloads/file.php?id=937
Realistic Magical Impacts
http://www.skyrimnexus.com/downloads/file.php?id=977
Ash Pile Retex
http://www.skyrimnexus.com/downloads/file.php?id=1838
Bellyaches Animal Pack
http://www.skyrimnexus.com/downloads/file.php?id=3621
HR firewood chopping block and tree rings
http://www.skyrimnexus.com/downloads/file.php?id=4438
