Parja
- Oct 4, 2002
Some weird stuff going on there. It says Archmage Robes, but that's the Nightingale Armor.
It is a mod that allows me to craft various armors that are otherwise not suitable for mages. I like how the Nightingale looks compared to the regular archmage robes.
Ahh, ok.
So where does one get this pre-release version of SkyUI?
Ahh, ok.
http://skyrimui.googlecode.com/svn/trunk/skyui/dist/
Schlangster is fine with people using it as long as they don't post installation directions and/or burden him with bug complaints, etc.
Sweet, thanks!
So how is it? Any glaring issues to be aware of?
Timescale 5 is the safest, lowest value to use and shouldn't bug anything.
Don't go any lower tahn 5 and it should be fine. 5 is awesome. It's the way the game should have been set all along.![]()
I'm not sure if changing the timescale is the cause, but since doing this, i get a lot of NPCs which repeat themselves a lot if i loiter in their general area.
Strange. Haven't seen that quirk myself as of yet.
I've noticed it occasionally. I'm not sure if it's more than normal, but sometimes I yell at the NPC irl.
I have a ton of mods installed, so it's quite possibly one of their ill effects. I posted here to confirm if it was the timescale change or not, and apparently it isn't.
I"ll do more testing with setting the timescale back and forth.
installed skyui, its awesome.
Ohhhh I didn't know skyui was out.
the one linked above is a pre-release version, which you may only use if you don't complain about it, apparently... haven't tried it yet, but it's got to be better than QD
Looks like it is now officially released:
http://www.skyrimnexus.com/downloads/file.php?id=3863#
Is it safer to use keyboard and mouse now? I used my ps3 controller from the day I got the game but I really want to use the keyboard/mouse combo. Any control tweaks for ini files that make sensitivity etc. better?
SkyUI doesn't work for stores, or looting (chests, barrels, etc) ???
So it's 50% useless...![]()
Of course I will wait.
It seems silly to constantly bounce back-and-forth between two UI designs.
started using the SkyUI today, definitely a improvement over the shithouse default version. look forward to when the other modules are done to complete the overhaul.
using the most up-to-date version tho as a requirement SkyUI needs the 'Skyrim Script Extender' (0.12.18) to work. anyone else get the error in the top right hand corner of inventory that 'Skyrim Script Extender' is missing. is it not compatible with the latest patch (playing skyrim via steam)?
Note: also using the 'Nexus Mod Manager'.
Forget whether it's partially working or not, it's still a very early beta, maybe even alpha stage. So many of the mods have caused new problems for people. You guys are awfully courageous and generous to be testing it out just for me. I'm humbled.![]()
Okay, so I'm using the latest version of the FXAA Injector that comes with the handy .exe for changing settings instead of modifying a text file. I can't for the life of me get a half-way decent looking profile. Does anyone have a 2.0 compatible file I could try out?
#define USE_ANTI_ALIASING 1
#define USE_PRE_SHARPEN 0
#define USE_BLOOM 0
#define USE_TECHNICOLOR 1
#define USE_TONEMAP 1
#define USE_SEPIA 0
#define USE_POST_SHARPEN 0
#define FXAA_QUALITY__PRESET 9
float fxaaQualitySubpix = 0.1554;
float fxaaQualityEdgeThreshold = 0.2527;
float fxaaQualityEdgeThresholdMin = 0.0673;
bool highQualitySharpen = 0;
float AverageBlur = 0.1;
float CoefficientsBlur = 1.3666;
float CoefficientsOriginal = 2.3666;
float SharpenEdge = 0.255;
float SharpenContour = 0.065;
float BloomThreshold = 19.375;
float BloomPower = 1.669;
float BloomWidth = 0.0213;
#define TechniAmount 0.44
#define TechniPower 3.6
#define redNegativeAmount 0.88
#define greenNegativeAmount 0.88
#define blueNegativeAmount 0.88
#define Gamma 1.05
#define Exposure 0.15
#define Saturation 0.375
#define Bleach 0.125
#define Defog -1
#define ColorTone float3(1.30, 1.02, 0.68)
float SepiaPower = 0.11;
float GreyPower = 0.33;
float Sharpen = 0.014;
AntiAliasing 1
PreSharpen 0
Bloom 0
Technicolor 1
ToneMap 1
Sepia 0
PostSharpen 0
FxaaQualityPreset 9
FxaaQualitySubpix 2
FxaaQualityEdgeThreshold 3
FxaaQualityEdgeThresholdMin 3
HighQualitySharpen 0
AverageBlur 2
CoefficientsBlur 2
SharpenEdge 3
SharpenContour 3
BloomPreset 3
BloomThreshold 3
BloomWidth 3
BloomPower 3
TechniAmount 4
TechniPower 4
RedNegativeAmount 2
GreenNegativeAmount 2
BlueNegativeAmount 2
Gamma 5
Exposure 6
Saturation 6
Bleach 2
Defog 3
SepiaPower 1
GreyPower 3
Sharpen 1
BloomPresetToggle 1
Rawumber
Here is my current 2.0 FXAA Usersettings.h. My intent was slight color desaturation and a more contrast in dark areas. Some of this may come down to monitor type and/or calibration, so adjust if needed.
full resolution image link
Code:AntiAliasing 1 PreSharpen 0 Bloom 0 Technicolor 1 ToneMap 1 Sepia 0 PostSharpen 0 FxaaQualityPreset 9 FxaaQualitySubpix 2 FxaaQualityEdgeThreshold 3 FxaaQualityEdgeThresholdMin 3 HighQualitySharpen 0 AverageBlur 2 CoefficientsBlur 2 SharpenEdge 3 SharpenContour 3 BloomPreset 3 BloomThreshold 3 BloomWidth 3 BloomPower 3 TechniAmount 4 TechniPower 4 RedNegativeAmount 2 GreenNegativeAmount 2 BlueNegativeAmount 2 Gamma 5 Exposure 6 Saturation 6 Bleach 2 Defog 3 SepiaPower 1 GreyPower 3 Sharpen 1 BloomPresetToggle 1 Rawumber
