MisterClean
- Jun 9, 2010
Thats crazy, my 2600k and 6950 handle everythingf this game has thrown at it. Surely there's not that large of a disparity between the 2500 and the 2600?
It's absurd that I had to buy a new cooler so I could OC my CPU because apparently my GTX 580 and 2500k at stock cannot handle Skyrim at 1920x1200 with everything maxed.
Didn't say it wouldn't help at all, but some people have reported it didn't improve the lag when in towns. It looks like the game engine isn't optimized very well.What? If the game is CPU limited, overclocking it will obviously help.
In terms of performance, there are a wide range of tradeoffs, tips and recommendations I have in the guide, but let's be clear: Skyrim is a CPU-limited game, which is why there are slowdowns in certain areas.
Son of a bitch this damned Blood Dragon won't leave me alone anytime I go near Makrath, I am on Master and he will kill me in almost one flame burst. Shits hard.
Haven't bought the game yet, but I know the game is CPU limited. Overclocking won't help much.
From Tweakguides:In terms of performance, there are a wide range of tradeoffs, tips and recommendations I have in the guide, but let's be clear: Skyrim is a CPU-limited game, which is why there are slowdowns in certain areas.
Sure it will, but it depends a lot on the game. If it's poorly optimized you won't see any considerable benefit. Tom's Hardware does show a 10 fps boost when overclocking an i5-2500k from 3 GHz to 4 GHz. I don't see this making a huge difference, but every little bit helps.First of all if you're CPU limited and you overclock your CPU that's exactly what will help, being CPU limited means your CPU is maxed out and is the slowest components in the PC, so making it faster will increase performance. Only if you're GPU limited and you increase your CPU speed will you see no benefit.
Played all night until 7:30am O_O
I SERIOUSLY need some sleep
Love this game. There's a few issues, but the only things I really want changed are the companion clipping, the UI, and the low-res textures.
http://www.tomshardware.com/reviews/skyrim-performance-benchmark,3074-9.html
Of course it does depend on optimization. Skyrim doesn't use more than 2 threads which is a massive waste of power, for quad cores it leaves approximately 50% of the CPU idle.
Still, what it does with those 2 cores hasn't really been demonstrated to be unoptimized as such, people just need to be careful with that word.
I'm pretty sure that it actually does use all 4 cores.. This post has a screenshot of someone's task manager, and it shows that only one core was used before the game was launched, and all 4 cores are being used after the game was launched.
Yes, companions can be extremely annoying. They always seem to stand RIGHT in the doorway, and won't move until you shove on them for a while.. then they complain that you pushed them.. lol
As others have been saying, your issue is elsewhere. 2600k GTX580 here. Runs 60+ FPS with no AA at 1920x1200. Reason for no AA is that at this res(and higher) you really have to be looking to notice the jaggies while everything is in motion. Waste of resources imo.
I'm finding, as a stealthy rouge assassin, that companions are more annoying than helpful to me. I prefer to be a lone wolf, as the companions are little more than pack-mules for me.
Would this account for why I lose some fps when I'm in caves? For some reason, it gets a bit choppy
I've been to busy playing to mess with the interface at all and while assigning a spell to a hand is cool is it possible to either use a hotkey to use an assigned spell or make a generic "use selected spell" button?
Basically I would prefer it worked like Oblivion where you could equip say a sword and a shield and then have a spell slot as well.
Not without modifying the game. Bethesda made it work that way intentionally. It makes if feel more like you're actually casting a spell instead of coming out of nowhere.
OK this is an image of my desktop running task manager and afterburner for CPU and GPU usage, my GPU is at 99% and my CPU is using 4 cores, it's about 50% usage across all cores on average.
Task manager isn't exactly the best way to judge cpu usage. It isn't very accurate.
Wow, you really haven't experienced much of the game yet. I think you'll find the other guild quests just as enthralling as the main story.Finished The Thieves Guild quest lines, but not any of the other main ones (Dark Assassin's, Mage's Guild, and ???)
Hot keys are a pain you'll have to fiddle and see what works. Basically go in to your items menu, select weapons and then highlight the weapon you want and press the F key to add to favourites menu (same method for spells)
Then press Q in game for faves menu and once that's up hover over the spell/weapon you want and press 1-8 on the keyboard to assign a hotkey. Now you can equip things immediately but the system behaves a little odd since some things are quipped on a single hand it means you can toggle some things on/off and allow combos of any 2x single handed weapons like a torch and a dagger or a spell and a shield
As for crafting, as you level up through the world you'll start finding better and better weapons made with better materials, there's mining seams around the world to mine if you have a pickaxe and animals to kill for pelts, you make leather and smelt ore and combine those things at the forge.
There's 2 lines of armour, one light for rogues and heavy for warriors (robes are seperate for mages I believe), the different lines use different materials.
I believe light armour is something like: Hide -> Leather -> Studded -> Elven -> Scaled -> Glass
and Heavy armour is something like: Iron Plate -> Steel plate -> Orcish -> Dwarven -> Ebony
The strongest armour is dragon bone which you craft from the bones and scales from dragons (so save these up every time you kill a dragon and don't sell em!) you can make both heavy and light versions of that.
Weapons are similar you get weapons for most armour types as well and they're all craftable. using smithing you can also improve weapons and armour to make them stronger using the same materials, as you get better at smithing the improvement you add get better, I recently crafted a full (Epic) glass armour set.
Is there any reason(s) a pure archer should not use heavy armor?
Enchanting and Smithing are pretty overpowered
Heavy armour has 2 main downsides, it's heavier so takes up more inventory space, also the heavier the armour the harder it is to sneak, most archers are likely to be rogues and sneak about a lot which makes light armour more favorable.
My rogue with high archery skill gets a critical x3 multiplier for sneak attacks with arrows meaning that I can 1 shot all of the basic enemies as long as I remain undetected, it's more effective to sneak and get critical hits and avoid confrontation than to deck yourself out in armour but then get caught sneaking and have a stand off, it's very risk vs reward, if you're good enough at sneaking you can clear entire dungeons without altering anyone.
You can tank with armour as an archer like that if you wish but it's not really a elogant combination, plus it's gonna be a bit silly when you're constantly in fights at melee range using bows/arrows. For pure archer I would always recommend sneaking, that is the rogue way
My friend maxed both and made dragon armour and used enchanting to buff bow damage +40% on all pieces of armour and you can double enchant with the right perk so he had +40% sneak on all pieces as well. I think he said his total bow damage was about 200 which is absolutely mental. I'm nearly 100 in smithing now and have plenty of stashed dragon parts so should be able to get dragon armour fairly soon. A note on the smithing tree in the skills section, the left branch is all the light armours and the right branch is all the heavy armours, so invest in the branch that suits your character, you can reach dragon armour via both branches equally.
*edit*
Oh Deadra armour is the 2nd to last perk in the heavy (right) tree in smithing, well that's pretty gay actually because not only is Daedric armour better but lower in the tree (so needing less skill to craft) but also there is both heavy and light variants of the dragon armour where as Daedric armour is heavy only.
Although dragon bone is unique in that you cannot create weapons with it, only armour, so if you want to smith the best weapons in the game you NEED to invest in the heavy branch of the smithing tree, even if you don't intend to use all the heavy armours. That screws over the rouges quite nicely then
This is the first Elder Scrolls game I've played where you can not make your own spells. The only way to learn a spell is to read a book known as a spell tome. These are dropped by certain enemies and located in dungeons throughout the game. The Mage's college in Winterhold can also sell you some.Also, how do u learn or make new magic skills?
Do u need to get special materials?
