[Spectre]
I Will Find You
- Aug 29, 2004
I'd be interested in hearing your answer to jonny's questions.
mine is in .. powers my rig great .. not loud
my one complaint is how short the 8 pin motherboard connector is kinda short .. on my evga 680i board the power connector is in the top right corner .. and in my tj09 .. the psu is on the bottom .. no slack at all to hide the cable .. it barely makes it
how does that compare with the Corsair?The 8-pin is 550MM long. That's not unusually short at all.
470MM!
Most are even shorter.
PSU's aren't made for cases w/ the PSU on the bottom. I think if chassis manufacturers are going to put the PSU on the bottom, they need to flip the mobo too.
Ah... That makes a difference. Big difference between 99% of the scopes out there and a Fluke 199C.
It's not something you commonly see done since the Fluke will run you $3000 and the attachment you're talking about is another $300.
For that kind of money, one could buy an actual load tester actually made for testing power supplies.![]()
Is this PSU quieter than the PCP&C 1kW? And if so, is it noticeably quieter?
edit: I looked up the noise level the Silverstone is 25 dBA-42 dBA while the PCP&C is 32 dBA-44 dBA. Is that a big difference?
Just for that, I'm setting it back another week.
I see, thanks.Meaning, It's not a normal scale. For example, 20db is twice as loud as 10db, right? In a Log scale, it'd be significantly more than twice as loud. I believe it's every 3 db, but i could be wrong, that it doubles.
Think of the richter scale in terms of earthquakes.
Any Reviews yet![]()
High-frequency changes in the voltage. Check out the link on the third page; those graphs represent a 20ms interval of time on the horizontal axis, and the vertical axis is .4 volts. This high-frequency oscillation can cause problems with lots of components.
Anything with a motor will be unhappy - hard drives, fans, optical drives. Same reason you buy real sine-wave UPSes for anything with a motor load.what type of problems?
Note that it's a lot louder than the Olympia. If you don't mind that, more power to ya.Well if saving some bucks means having a chance of component damage, i mightest well just go for the PC Power 1kw sr. The only thing that I dont like is the absence of 8-pin pci express connections for the price.
Just a thought, how does the Enermax Galaxy 1KW compare to the PC P&C in terms of noise, ripple and quality ?
W
This mob won't change it to another power supply![]()
So far Im loving my Silverstone 1W PS. Quiet and powerful....Two thumbs up.
How long did you have your power supply?
I'm lost, Please make up your minds is it quite or not?
Is the Ripple on the power supply bad for your computer or not please?
