^ I have that same filco keyboard, it has severed me so well over the years and I love it.
Yep it's an excellent keyboard! Filco Majestouch w/ the Cherry MX brown switches.
http://farm6.staticflickr.com/5530/9157056352_db88df8c6c_b.jpg
Nice!!!
How's that Matrix Mini-i treating you?
I've had a small bug with mine every once in a blue moon playing at full volume (0dB) even when the volume is turned all the way down. power cycling normally takes care of that issue though.
http://i42.tinypic.com/25sofgy.jpg
IBM T221
Dell 3008WFP
Seiki 50" 4k
HP Envy 17.3"
Non gamer setup
IBM T221
Dell 3008WFP
Seiki 50" 4k
HP Envy 17.3"
All on a 20$ folding table.
Before, two Hanns·G 28" monitors:
After, three LG 27EA63V-P picked up for $250 a pop:
Can't wait to use them with my Fanatec setup, just need to figure out a mounting setup that will work for PC use and sim racing.
hey mate could you please upload the r18/corvette wallpaper... if you have any other wallpapers from lemans 2013 upload them!!!
thank you
I haven't purchased it yet but am planning to for my setup. I run two Dell 2007FP flanking a U3011 on the bottom row with a secondary display above the U3011 at 1680x1050 that holds my gadgets, Rainmetre, etc. I am under the impression that Display Fusion lets you use different wallpapers on each monitor...
http://www.displayfusion.com/Purchase/
My setup:
Shimian + Qnix @ 120hz
Going to be building my corian desk soon and then finally mount those 2 bad boys (had mount for like 2weeks now) - then i can also use my razer goliathus and get round to trying my new deathadder
Better Quality Picture Here
Will update when that gets done
Rig:
ASUS P8Z77 V-PREMIUM
Intel i7-3770K @ 4.3Ghz
2x GTX 670 ASUS DIRECT CU II TOP
NOCTUA NH-D14
32GB Ram 10-10-10-27 1.5V
Samsung 840 Pro 256GB
Seagate 3TB Barracuda 7200RPM 64MB Cache
Seagate 1.5TB Barracuda 7200RPM 64MB Cache
Corsair AX 850W Modular Power Supply
Cooler Master HAF X - Full tower
LG BLU-RAY REWRITER
Akasa AK-ICR-07 Internal Card Reader
Qnix QX2710 LED Evolution ll 27" 2560x1440 @ 120Hz
Achieva Shimian lite 27" 2560x1440 @ 65Hz
Razer Deathadder 2013/Naga Molten
Qpad MK-85 Red Switches Mechanical
Razer Goliath Speed Fragged (currently using diablo matt till desk built)
Pioneer S-HS100
Sony STR-DH820
Still rockin' my NEC 2490WUXi. Have two NEC 2090UXi's laying around as well that I need to setup next to my main monitor now that I have a graphics card that supports three monitors.
Ultramon also allows different wallpapers on different monitors, although it is not as flexible as Display Fusion.
www.realtimesoft.com
I've used Ultramon on a rig similar to yours, except I used 3 20" 1680x1050 monitors on the upper row as they are a good PPI match for the lower monitors:
IMG_0060 by rtangwai, on Flickr
