Show Your LCD(s) setups!!!
thepawn
Loving it so far. No regrets at replacing my U3011, whatsoever. Probably the best computer purchase I've made in the last 5 years.
I understand that other people have different preferences but, for me, the added real estate area justifies it by such a large margin that I will gladly game at 30Hz (which is not as bad as some people think)
I figure that, in a year or so when 60 and 120Hz are available, I can get replace the Seiki and still have saved money over buying the 32" Sharp Monitor now at $5K
Am I missing something? When I search for 4k Seiki TV, it says its 120Hz.
http://www.pcmag.com/article2/0,2817,2418007,00.asp
haunter
I beleive renixinq is correct, its 120hz at 1080p
the HDMI rev it has doenst have enough bandwidth for anything over 30hz at 4K
#Grey
Looks like the Logitech Z906 unit to me.
Correct. I used my z906 for a couple of years and eventually decided I did not want a 5.1 system on my PC anymore. 2.1 is still better for music listening and gaming. (IMO)
The z906 is a costly bit of kit though so I still wanted to make use of the control console & sub.
elvn
Make sure that you differentiate between "faked" 120hz and 240hz etc that tv's have 60hz input in the back and do their higher hz quotes using interpolatated (quasi-cloned) frames, and a true 120hz or higher input computer monitor that will show you many more new, unique frame "slices" of whats happening in the game world per second (provided you supply each hz with a new frame of game action by achieving equal to or greater than the hz rating in fps number).
Currently $1k in gpu's (a 690, 680x2 sli, a titan, etc) can get over 100fps and hit 120fps in some cases at 1080p on high+ or ultra settings , depending on the game. 2560x, triple monitor gaming, and 4k are much more demanding so require a huge expense in gpus to get over 100fps to feed a 120hz input enough frames. Best scenario is over the hz rating in fps... running over 120fps on a 120hz monitor allows you to run without vsync with insignificant tearing, and provides an overshoot "buffer" vs scene complexity fps dips. 120hz increases motion tracking (twice as many unique "slices" of new action info shown per second), and cuts the motion blur by half vs 60hz. Recently, the nvidia lightboost - in - 2D gaming crowd is running 100hz & 100fps+ , or 120hz & 120fps+ and getting zero motion blur via backlight strobing.
D
Deleted member 238539
Guest
Wow I honestly didn't even know that the u3014 was out. Solid set up.
Zetc, how did you get both of your 30" monitors to display at it's native resolution @ 2560x1600?
I currently have 2x U2711 running on XFX Radeon HD6970 but later found out that the card only got 1 dvi-d port capable of supporting resolution at 2560x1600 (or in my case 2560x1440). the other port is dvi-i which the resolution max out at 1920x1200.
under your PC setup spec, you stated that you are using 7950. that card only got one dvi port as well.
Zetc
^ Niiiiice. 2x U3014, I'm very jealous...
Thanks :) Love the amount of screen space I have now.
@Zetc: Where's number 3?
haha, that's the goal.. which is why there's another monitor stand prepared on the right ;)
Will get number 3 some time in the future. Probably wait for the next Rev first so that I can compare.
Am using the DisplayPort outputs on my card to drive the 2 U3014s via their respective DisplayPort inputs.
The U2711 has a DisplayPort input as well. Your card has 2 mini DisplayPort outputs which can drive 2560x1440.
All you need to do is sign up for google voice (free), buy a adapter called obihai (one time cost about $30), plug the adapter into your router and configure the obihai to use google voice. Plug in any cordless phone that you have laying around the house from yesteryears and voila! Free calls as in $0.00 calls. The configuration is easy and provided with the obihai adapter.
Gronnie
You can also sign up for a service that will give you 911 access for $1/mo as Google voice does not provide 911.
Afkap
Oh God, my poor little W8 tablet can't display those epic pictures?! From what I could glean from scrolling around, it looks like a decent setup! Also I think the cat wants to go out... :)
Syndicated_Death
Sounds like some of you need higher resolution monitors. go forth and buy them and report back with pictures of them set up!
r4nd0m
Such a silly comment. The photos are 2851x1900, which won't fit on a screen unless you had a quad HD panel. Why don't you show off your quad HD panel so we can judge whether or not it's worth it to view such photos?
r4nd0m
heys guys what is the best configuration for a 27in setup? 17x27x17 or 19x27x19.
Looking at the pixel size/pitch shows, nothing fits very well like the 20, 30, 20.
http://en.wikipedia.org/wiki/Dot_pitch
I think there were a few 17" 1440x900 widescreen LCDs but those would be too old and slow. Not to mention 900 width is just too narrow.
Moving up, a 20" 1680x1050 wouldn't be bad either but they'd be old 16:10 style monitors again.
Best bet might be a 21.x" 1080p as that's the only real currently widely available (therefore cheap & quality should be possible) size that matches reasonably well other than 3x27".
bdr
20, 30, 20 and 23, 40, 23 both fit nicely. 20, 30, 20 is the perfect match though.
rtangwai
If you're going to use Eyefinity/nVSurround the best configuration is 27x27x27 - there is no PLP support in Eyefinity/nVSurround.
17" and 19" panels don't make good wing monitors with a 27". The PPI is all wrong so there is massive distortion regardless of whether the 27" is 1080p or 1440p. The only good panel match for a 27" 1440p are those 15" 1440x900 laptop panels, but they need a lot of work to wire up. It can be done - an [H] forum member named nickchong did just that. There are no panels that match up with a 27" 1080p monitor. Most of the 17" and 19" you can get ahold of now are TN so putting them in portrait mode makes for a very poor display, another reason to avoid 17" and 19".
