Show Your LCD(s) setups!!!
@ c3p0, I like your setup set up a lot... very unique. Is that logitech dinovo keyboard? If so, is it worth the $100+?
Thanks mate.
Its cost me around £120 I think. I am in the UK.
Definately worth the money imo. A very good keyboard. Battery life esp is awesome.
The only downside is that its very very difficult to get a key back in, when it comes out!
[IM]http://i53.tinypic.com/zvpnw8.jpg[/IM]
where did you get those Ipod/headphone holders on the edge of your desk... aslo the other headphone holders under that side table??
Hi Atheton,
The ipod holder is the xstand. I have them fastened to the desk using sennheiser headphone holders,
The other stands I use to hold my best cans when not in use. They are made by a company called seivking.
Im assuming u r based in the states. I bought these from etailers bases in the UK,
You can get al three items online from many places online i think.
The headphone holders at the edge of the desk ate from sennheiser, they come w.595s n other higher end models, I think u can purchase them from sennheiser's site
hey there c3po , what is that object your MBP is sitting on? Im prob being a total idiot asking but just curious :)
<left> <mid> <right>
<V7 noname 22" TN 1680x1050> <Dell 2209WA eIPS 1680x1050> <portrait Dell 2209WA eIPS 1680x1050>
plus a trackball
and a kindle dx graphite :D
First Post, Long time Reader. My new set up. PS lots of awesome set ups in this thread game me a lot of ideas so thanks to all 870 pages of posters!!!!!! 3x 2494SW Samsung 24" LCDs, 1x Dell 2009W 20 LCD
The Power behind it all, Sapphire HD5870 Vapor X (my dell lcd is on the HD3450), Accel Active single link Display port to DVI ($26.98 @ ++++) CPU: Q6600 @ 3.4ghz (H70 Cooler), RAM: 6GB Kingston Hyper, Motherboard: Asus P5Q Pro Turbo, PSU: Corsair HX 750W, SSD: 2 x 64GB Kingston V, HDD: 2x WD 640 Black in raid, 1x WD 1TB Green, OS: Win7 64bit, Case: Corsair 800D.
EDIT* I might as well toss in my other 2 LCDs
this is my bedroom LCD(26" Samsung) hooked up to a HTPC (Build can be viewed here: http://hardforum.com/showthread.php?t=1554925)
This is my living room LCD hooked up to my Living room HTPC (the one in the pic has since been replaced, you can view the build here http://hardforum.com/showthread.php?t=1554931 )
@CoolHandL, did you make those monitor stands? As my Samsung 2343BWX's aren't adjustable either I think I need to move them up about 3 inches to be perfectly eye-level. Looks good.
@00PS - Yes i built the monitor stands my self with some leftover pieces of wood i had, top piece is finger joint pine and the bases i used scrap 1x4 pine pieces,
its very temporary, as i'd like to LCD arm desk mount all three, I have one Ergotron LX desk mount, but need a 100x200mm adapter plate to mount my monitor, I'm having a terrible time with the retailer that carries it for ergotron and with the manufacturer as well (no one knows anything)
Just got my 55" 1080p 240hz LCD in.. Since I "enclosed" the backside of my entertainment center in, I keep fresh air on the backside of the monitor via (4) 120mm case fans. I'm pretty happy with my results so far..
