Show Your LCD(s) setups!!!
I found the connecters on a Samsung quick reference PDF then did some copying and pasted them into MS Word to size everything right. Then I used MS Paint to make the diagram from scratch. It takes a little bit of time to make them. Granted it isn’t exact to how the rears look but I don't need them to be. Hope this helps :D
great idea --- thanks! :cool:
My camera sucks, but here's what I'm rocking at the moment.
the orange computer is iBuy Power, Duo Core, 3.16 Ghz, 4 GB RAM
the black one is really fast :confused:.... Haven't used it for a while so I forgot the specs...
the laptop is an HP Tx1000
I like to draw just about anything. As far as drawing anything on a computer I am just starting to get into it.
Yeah the Cintiq must be pretty awesome. I also noticed, is that a Logitech Illumated keyboard? It's quite sexy, indeed ;).
is anybody running a dell 30" with 2 2007wfps on the sides? I know the regular 2007FPs are am exact match but I was wondering if a pair of the 20" widescreens would work...
Those are the 2007wfps?
The diff between 1600 and 1680 res between screens was ok for you? How noticable was it?
ohhh nope those aren't wfps.. those are the non widescreen displays.. 2007fp.. my bad.. read it too fast
blackacidevil how do you like gaming at 1080p. What size is that. I am currently debating on changing my setup. I don't know if I want to keep my current 24' LG, go with a 32 inch LCD TV, or maybe go for a 30 inch monitor.
