Hammertime
- Feb 22, 2008
I didn't pick the color the walls, and I can't change them.
I believe I've seen that desk on Costco's website. It's listed as a gaming desk IIRC.
does soyo makes good lcds?![]()
i like the carpet. it's not glued to the floor huh? where did you get that type?
It actually looks like an area rug. Notice the edges look to have a seam on them.
I have that Exact same picture hanging up on my wall XD it looks sooo cool if you actually look at it.I can't remember if I've posted to this thread already, so here it may be again
The now required resin statues are satisfied via Neo and Punisher![]()
No this desk is my own creation. Here are some that I did look at...
https://www.pccasegear.com/index.ph...d=5990&zenid=708cac32637f757820b0396816381fa8
http://www.thev1chair.com/images.htm
http://www.poetictech.com/aura/index.html
Each of these is very cool... but in the end they have some "feature" that I didn't like. Actually, using the extrusions allows for even more customizations. You could add a different type of linear motion and attach a side table. The table I built has an actual work surface, that glass top is 17"x30". The Chair itself has a cup older so you could use the side snack surfaces to hold a book or some other widget.
For me, having a fixed keyboard location was a design intent. The worksurface moves. So your hard cover reference material is on your desk... your doing your thing, need to check something... pull the reference close... The keyboard tray is angled... what angle, you decide, it's adjustable.
that's a nice setup, and wallpaper! have a link to original?This is my main rig.
http://themoores.zenfolio.com/img/v2/p302360453-4.jpg[/IMG]
http://themoores.zenfolio.com/img/v2/p473457222-4.jpg[/IMG]
Small changes from last year. Mainly the sub is now placed under my desk. Have taken great pains to isolate the subwoofer from leaking bass into the neighbours' apartment.
Have been shopping around for desks. It's amazingly hard to find a simple, symmetrical desk that doesn't have all kinds of cheap-ass "features". Also my camera might be on its last legs, can't seem to get a good focus any more.
How is the P241w over HDMI? I am thinking of buying one for PS3 when I get one.
^Its an amazing monitor, and I got it for only $289![]()
why do you have 2 xbox360?
