CrombieKid
- Aug 14, 2004
is it worth it? will the windows firewall conflict with the norton one i have?
CrombieKid said:so i took the plung and downloaded sp2.. it was downloading under the windows update icon in my task bar..the icon disapeared and i was not prompted with anything so i restarted.. again nothing came up.. what the hell happened?![]()
nope, SP1.. im downloading it again.. still puzzles me thoughPapa-Ming said:Well, it doesn't sound like you got it, but lets check: right click My Computer> properties> does it say SP2 there?
Bingo!M11 said:Why not download the full install over HTTP (tends to be faster and more reliable than autoupdate) and keep SP2 around on a CD for future installs?
http://www.microsoft.com/downloads/...BE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
Kevin003 said:Heres a problem that i had when i first tried SP2. I am using a dell with specs in sig, and dells come with their own version of windows only to be installed on dell computers. While anyways i have home edition and when i downloaded Sp2 the home edition disappeared on the windows screen when i loaded my computer. And it started slower so i uninstalled it. I am willing to give it another try but is it worth it? Or is Sp2 just not compatible with Dell computers?
UMCPWintermute said:Service Pack 2 removes the "Home Edition" or "Professional Edition" from the startup logo. This is normal and expected behaviour, no cause for alarm.
The first time you launch Windows after installing SP2, yes - it will be slow. Your system is coming to terms with all of the changes made.
If, after the first time booting up (and a subsequent reboot), it still runs slowly: check for viruses and spyware.
