SaladDressing
- Feb 21, 2011
After my ATX workstation mobo burned out inside my CoolerMaster Stacker case and being forced to fully upgrade with brand new components all round due to technology having moved on, I've decided to put together a Small Form Factor Workstation for the CGI (Computer Generated Imagery) and Web Development work I do professionally.
The SFF is so that I can easily move my workstation for numerous security and portability scenarios. I'll also be changing from Windows XP Professional to Windows 7 Professional 64-bit. This machine will output to an Apple 27" Cinema Display (2560x1440), an upgrade from the 21" Viewsonic CRT (1600x1200) which was 15+ years old. Instead of a mouse I use a Wacom tablet with USB cable (the cable is a portability hassle, but the tablet is essential for my work). I'm considering a wireless keyboard without numeric keypad (ideally chiclet-style) to ease portability.
For those interested, some of the software I'm running is GIMP, Painter, Inkscape, Scribus, SWiSHmax, Messiah Studio 3D, Rhino3D, Eyeon Fusion, Newtek SpeedEdit, as well as other web development code editors, browsers, and a development server like XAMPP. O yes, occasionally it's nice to move the kit to the lounge where my family and I enjoy a movie together - audio output on a set of Beringer Truth monitoring speakers I have.
Here's the hardware I want to run:
I need a stable, cool, quiet and compact system that can sit on my desk. I've never done overclocking and will probably be happy with a standard speed system. Reliability and longevity is much more important than slicing a few seconds off my 3D renders.
I've been checking out the SilverStone SG07 and Lian-Li Q11 cases and I've been reading through those threads here on [H]. I'm excited to eventually upgrade and to go SFF.
I'll be posting my progress in this thread with the dual purpose of sharing and hopefully also getting some help!
Enclosures : Although SilverStone has a distributor here in South Africa, lack of demand has caused them not to stock the SG07 case. Lian-Li is easily available around here and the Q11 may be perfectly suited. The Lian-Li Q07 has enough space to house the FirePro V4800 card (18cm space for a 16.8cm card), but I was concerned about space for CPU cooling. If you guys think the Q07 can work, then I'm open to your advice.
Data Storage : I've decided not to put a HDD in the system, but to stick with SSD for low power, low vibration and low noise. I'll run HDD's in an external enclosure via USB 2 & 3 for archiving and backup of current projects and perhaps an external RAID for video editing
Power Supply : Using a spreadsheet I calculated the total power draw on this system to be 300 watts as follows:
CPU Cooling : I've considered the low profile Zalman CNPS8700 NT cooler. The ProlimaTech Samuel 17 looks like a good option too, although not available in South Africa from what my research shows. I've been studying liquid cooling, but the cramped space in the Lian-Li Q11 does not motivate me yet, although I'm open to suggestions.
- mini-ITX 1156 motherboard (Intel H57JG)
- Intel i7-870 CPU (1156, 2.93GHz, HT)
- 2 x 4GB DDR3 1333MHz RAM (ideal brand / model?)
- 3.5" internal BluRay / DVD Optical Drive (LG CH10LS20)
- Intel 320 Series 120GB 2.5" Solid State Drive
- ATI FirePro V4800 Graphics Card (16.8cm long)
- 90 Watts : ATI FirePro V4800
- 95 Watts : Intel i7-870 CPU
- 7 Watts : 2 x RAM modules
- 7 Watts : case fans
- 10 Watts : CPU cooler
- 70 Watts : motherboard
- 1 Watt : SSD
- 20 Watts : optical drive
