i said it many times here, dont go over 4.6ghz
be happy with 4.4ghz-4.6ghz, its fast enough.
What, does the "You're fucked Fairy" pop out of your case at 4.601ghz and light your underpants on fire?
Can you guys really tell the difference between 4.0Ghz and 5.0Ghz? 4.0Ghz was fast enough for me.
Are the SB chips really dying or just a user error? Be careful with high volts.
http://forums.overclockers.co.uk/showthread.php?t=18227516
http://www.semiaccurate.com/forums/showthread.php?t=4064
4.4 seems to be the sweet spot without adding (much, if any) voltage. Fast enough for me.![]()
Super pi 1m is barely a stability indicator. I mean im not one to fuss all over prime all the time but run something alittle more taxing. Even 3dmark 06 or vantage would be better. Oh and disabling hyperthreading is not recommended.
Its a Vapochill LS, I bought it in 2004 and still can hold new generation of cpu @ -20C. Its like my grandmother's electrolux referigerator with avocado color of late 60's....still cold all the way to early 90's before I junked itVery nice. 1.608~1.620V... though your cooling setup likely costs more than the chip.
Doesn't seem to want to hit 5.0 for anything. Alright by me, really, I wouldn't keep it like this for 24/7 anyway.
Its like my grandmother's electrolux referigerator with avocado color of late 60's....still cold all the way to early 90's before I junked it![]()
Its a Vapochill LS, I bought it in 2004 and still can hold new generation of cpu @ -20C. Its like my grandmother's electrolux referigerator with avocado color of late 60's....still cold all the way to early 90's before I junked it![]()
[H] extreme cooling section is one of the first on the net and most informativeI would spend $600 - $750 on one of these units if I could get year after year stability out of it 24/7.
Would love to run my 2600k at 5.2 - 5.5Ghz
What has always turned me off was not many companies sell these and the ones I have seen, buyers complained of very poor craftsmanship and having to return their units. Also, from all the articles and pictures I've seen over the years, there is that clay you have to form around the socket?
I would love to find someone that could break it down in geek speak as to the pros and cons and answer the simple questions people want to know. Like daily use, power usage, condensation, build prep, maintenance, costs, etc etc
Maybe the chip just cant do x50 multi.
Yep. I purchased my Vapochill LS in 2004 from Sidewinder Computer, just always careful when moving it around.That avocado color is pure win
Using refrigerant R507? That will keep it cold. Being seeing some people using low end off the shelf AC units to cool CPU's. The price range of phase change kind of explains it. This one guy did it with a goal under $600... I'm thinking to myself why have a homebrew setup to save $100, but whatever.
Nice results, just goes to show you can push these chips hard if you've got the right stuff.
