HaMMerHeD
- Jul 13, 2004
That steam forum CFG post made a big difference for me. Some of those commands do nothing (like com_maxfps), but I see a clear improvement in sharpness.
Tried it in eyefinity yet? Want to see if people are getting the hitching issue im getting.
I just used the basic cfg tweak to get the game running fine.
you can see the polygons because the game doesnt support forced AF. have to set it using the config file. max of 8x.
What is the basic cfg tweak?
So many tweaks around already, I'm trying to find the right one(s) to work.
vt_pageimagesizeuniquediffuseonly2 8192
vt_pageimagesizeuniquediffuseonly 8192
vt_pageimagesizeunique 8192
vt_pageimagesizevmtr 8192
vt_restart
Just the one that's like:
Code:vt_pageimagesizeuniquediffuseonly2 8192 vt_pageimagesizeuniquediffuseonly 8192 vt_pageimagesizeunique 8192 vt_pageimagesizevmtr 8192 vt_restart
I feel really bad for you and the others. However, on behalf of myself and all the other future bargain bin purchasers, I just want to say thanks, and keep up the good workThis whole spending more time trying to make the game playable, rather than actually playing the game, is getting old.
Your efforts are making this a worthwhile impulse buy for the rest of us at some point in the future![]()
It's OK to think it, but you are not supposed to come out and say it. Sheesh.
They will fix the graphics issues in time. Either with a game patch, or a set of drivers, or more likely, both.
Whoa thats one of the most amazing character models I have ever seen. Just beautiful.
Comes close to The Witcher 2 but not as detailed. I still think TW2 has the best character models I've ever seen.
http://hardocp.com/news/2011/10/05/...ring_blurry_textures_texture_popping_in_rage/
Yes thank you! I'm a pc gamer and I as a pc gamer i can do this to fix what you didnt care too. If i am a console gamer I ask? i dont have access to what you are asking me to remedy a solution. Is this on gfwl? or psn network?
If the graphics driver supports a so called "swap-tear" extension then RAGE will use it and RAGE will V-sync when running >= 60 FPS and RAGE will tear when < 60 FPS. Unfortunately at the release of RAGE, none of the graphics drivers have the "swap-tear" extension enabled.
this is fucking laughable. AMD and NVIDIA screwed you guys not us!
If I may play Devil's advocate for a minute, you could also wonder why they still released Rage if the drivers available didn't have it enabled. It would make one how couldn't they have known. But interesting comment.
All I did was "force on" vsync in nvidia control panel and enable triple buffering. No tearing whatsoever. And I forced high res textures in the cfg. Looks great, no tearing.
yeah i get that. I personally feel on a new engine with modern dx11 card. I cant be happy.
Man just browsing through this thread, it reminds me of Fallout games on that awful Gamebryo engine. Guess I'll wait until everything gets ironed out or the price significantly drops before I pick this game up.
If I may... Do any so-called PC gamers here remember this?
"Z_malloc: failed on allocation of 64024 bytes"
If you don't, turn in your gamer card. Games getting released with rather serious bugs is nothing new. Give them a chance to patch this.
Isn't that a 3D texture allocation error? I remember those but I don't recall from what games...
Eyefinity in this is a bit strange, seems 5760x1080 yields 16:3 according to the options, that results in your view being more zoomed in, only really noticed it after i seen other screenshots and noticed i wasnt able to see as much of my shotgun.
http://cloud.steampowered.com/ugc/577810212136780452/E9E460E9041E19845B509071BA102D914DCE76FD/
Should be able to see much futher back on the gun than i am currently.
Also having weird glitches with interiors in some areas turning grey like the empty space in a room is filled with a grey texture for several seconds at a time.
1) adjust your FOV +15 and that will fix the photo you show.....see widescreengamingforums for the formula code.
2) I see those gray areas alot. I saw them most noteably in the hotel level early on.
When you get to the town with the car races, you'll see the interiors are a faded green-washed out color.
I think its a way to elimanate showing all the textures except in the direct FOV. It sucks big time and I don't think it's a glitch.
I'm getting max at 60 fps. Is this normal? My refresh rate on monitor (CRT) is 90hz and running watercooled 2x gtx 480 with i7 920 processor.
Yes, the game is capped at 60hz....
Rage needs to stop doing whatever it says it is doing and it needs to go die in a fire. Wow ID... just wow... I hope you are proud of the giant steaming pile of turd that you have fed us PC gamers. I assure you that I will be think long and hard before I buy another ID game and also I'll think twice before buying any game that runs off of the ID Crap5 engine.
All this is coming from someone who has played every ID game from the beginning, not the Quake 2 beginning but from the actual beginning, the original Wolfenstein. I am disappointed ID, very very disappointed.
I can tell you that I at least made some people happy as I did a full system upgrade in preparation for this game. i7 2600K, 16GB ram, GTX 570, etc. Well at least I have a nice PC now to play someone elses games on.
that's news to me, and I'm guessing a lot of other people as wellit was known from the get-go that it wasn't going to be a system pusher
Why would anyone in their right mind 'prep' their system for this game when it was known from the get-go that it wasn't going to be a system pusher, as the entire goal was 60FPS for even the low-end PC systems. Not only that, but the pre-release gameplay info on Rage and what Rage 'actually' delivers are the same. The only person to blame here for over-hyping it is you.
It can be uncapped with config settings.
