JayteeBates
[H]ard|Poof
- Jul 21, 2007
I'm looking to do this water cooling thing for the first time. I bought the Thermaltake Bigwater 735 kit (when it was on clearance for cheap last week) but I haven't installed it just yet. I am thinking when I move to i7 in a few weeks it may not be sufficient.
Since WC really is simple in concept I was thinking why not go [H] on this thing. Here is a radiator I was thinking of getting. COPPER-RADIATOR
It is all Copper obviously and 16-1/2" X 10" X 3/4". I have a Antec P-180 case and I think this would mount just fine on the side of the case. My question really boils down (no pun intended) how big a pump I would need to push water through this thing and the cooling circuit.
Next question may be a bit silly - I was thinking I could use the 735 kits water block but will a 775 block physically fit an i7 mobo or should I just get another one and if so are there some suggestions?
