- Oct 3, 2008
Is it worth upgrading?
No.professional gaming
Yes./ video encoding /
No.working with photoshop.
Yes.
Bollocks.
WiC, Sup Com, Quake Wars and FarCry all like my i7 better than my old Q6600.
1 out of 2 isn't that bad.
2 wrong out of 3 is bad:
http://enthusiast.hardocp.com/article.html?art=MTU3OCwxLCxoZW50aHVzaWFzdA==
http://www.extremetech.com/article2/0,2845,2333775,00.asp
Stop giving bad advice.
Some people would think that it is worth it to spend a big amout of money to gain a little bit more speed, that's why you will see that some people will have a PhysX card or a Killer NIC or both in their rig...
Bahaha, I didn't want to point that out because Atech already hates me.![]()
Don't flatter yourself...you gave bad advice, I showed that...keep the fallacies to yourselfs.![]()
I didn't give any advice. I gave my opinion on the subjective question of "Is it worth upgrading?". If you are going to use the word "fallacy" (which you seem to do in every thread you participate in), learn what it means.
You gave bad (read: WRONG) advice.
The question was, once again, "Is it worth upgrading?" Not, "Is the i7 920 faster then the Q6600"
Did you not catch that?
I gave an "opinion" based on the difference an upgrade would make with his situation and the cost of all the parts required.
IMO, which is what the question was asking, I simple answered No. That is NOT a fallacy, it is an opinion. Learn the difference. IMO, the gains that he would see are not worth upgrading because of the cost involved.
The only "fallacy" here is your inability to understand the OP's question. That and your need to swing your e-peen around about how much faster your i7 is.
20% time is a lot saved (and I am being generous here)...maybe your time isn't worth anything...mine is.
According to dictionary.com, fallacy means:
1. A false notion.
2. A statement or an argument based on a false or invalid inference.
3. Incorrectness of reasoning or belief; erroneousness.
4. The quality of being deceptive.
I think criccio was just pointing out that it's not really worth it to spend over $300 to upgrade from a Q6600 to i7 platform if your only benefit is a 20% increase in time saved. (And according to your post above, that's being generous). In short, if a task takes 20 minutes to complete in photoshop on a Q6600, then it would only take the i7 about 16 minutes to complete in a best case scenario.
Now unless the OP is running photoshop 24/7, it might not be in his best interest to shell out over $300 to save a few minutes on photoshop. You stated earlier that criccio's advice was 'pure smoke&mirrors...', but I don't see any of that. What exactly does he reference or base his opinion on, that you would call out as 'smoke&mirrors'?
His statement to the OP that it may not be worth upgrading based on what the OP would be using the CPU for, is reasoned and I do not think he was trying to be deceptive. I would agree with criccio's opinion in this case. I see that you have an i7 in your sig, so perhaps you may be trying to justify your own purchase of this cpu?
Try an document that statement I have bolded for you...(can't anybody here read anymore?)...if you can, I will reply to your post
I'm not quite sure what you want me to do in your statement above?
I am sorry guys I did not want to start this flame war. My Q6600 was running @ 3.0.
And I am planning to have i7 run @ 3.0.![]()
Bakup the claim you made:
Still waiting.
... Some people would think that it is worth it to spend a big amout of money to gain a little bit more speed, that's why you will see that some people will have a PhysX card or a Killer NIC or both in their rig...
Another thing to consider. The x58 allows you to SLI and Crossfire on the same platform, and shows great increases when using multiple cards over 775 boards.
Atech likes to start arguments in almost every thread he participates in. Its almost laughable at this point.
Anyway, OP, it comes down to if you are willing to shell out for a new mobo, cpu and RAM.
