problem with e machines hard drive
sammy29926
Hi everybody,
Friend of mines e machines d series desktop's psu burned up adn that taking the mobo with it. She asked me to help her with th ecomputer since she has bunsh of programs and her bus program ont hehard drive.. I purcahsed anew psu and mobo but after i installed everthing and power it up .. i see the boot menu and it detects the hard drive cd rom drive ect. but it doe snot load the windows at all... it gives me an error saying that windows did not shut down properly and gives me 5 option to choose ..
Safe mode
Safe mode with command prompt
Safe mode wiht networking
last know good configuration
Start the windows normally..
which option i check it goes back to boot menu.. liek it turned th ecomputer on and off..
when i install the hard drive in my desktop i can see it as aecond drive and see th efiles ect.
so my question is how can i get that hard rive work properly alone..
I wonder if e machines installed a some kinda safe or securty program in it..
Thank you for your help
Sammy
Ok, so no matter which option (safe mode, last known configuration, etc) you choose, the PC just reboots, correct?
Since you're moving an existing install of XP over to another motherboard, this kind of problem does happen.
running the windows repair will fix the problem without having to do a fresh install.
Did you buy a new E-Machines mobo and PSU or some other brand ?
Hi everybody,
i purchsed the same part number mobo for the computer and everything is working right now...
thank you for the help
Sammy
