Tried shutting off gear down, but my system failed to post. Guess I am stuck at 3600 CAS20 for now. (Unless I learn to manually tweak things.)
What happens if you try to set the IF clock to 1:2 instead of 1:1? I know it's a long shot, but it isn't like there is this extreme wealth of knowledge about these new chips yet and the buggy microcode doesn't help much!
Here is my other rig. 3600 non X
5700xt
16 GB Gskill @ 3200 tightened to 14 cas
What case fans are you using?
I haven't bought anything yet but this is the plan (coming from a 2600K). I'll be bringing my 1080Ti over from my current build.
I went from a 1700 at 3.8ghz 1.4v to a 3700x at 4.3ghz Allcore OC at 1.4v
X370 Prime-Pro
16ghz Trident-Z at 3600mhz 16-16-16-20
256gb 960 Evo
That scores pretty high, wonder what all core you are getting.
I got mine from Best Buy as well and it came in early, about two days before the estimate. Running great.My 3900X is supposed to be ready for pickup at Best Buy on Monday. We'll see how that goes.
I get 514 in same Single Core test, I notice that the IPC is higher than the I7 7700K and significantly higher to previous Ryzens. 3000 series in this test kicks ass.That scores pretty high, wonder what all core you are getting.
From everything I've read the Aorus Master, Crosshair VIII Hero and Meg Ace are all about the same when it comes to performance. You might gain an M2 slot here or lose a few sata slots there but when it comes down to it bios and appearance are the biggest differences as far as I can tell. I like the looks of the Hero and nothing against that board but my last 3 boards have been Asus and I wanted to give Gigabyte some love, also Buildzoid said it was ok which for him means somethingWhat drew you to the Aurous Master ?
Build in progress... Waiting on AMD boot kit to build.
Pretty happy with the case. Little considered about the solid front but we will see. If I need more intake, the sliver plate can be removed and exposes a magnetic dust filter or I can add 2 120mm fans. The side panel can flip 180 meaning the pattern can block the view of the PSU or as show currently. Which looks better? Love the Noctua Redux fans. Added the red Chromax fan mounts to give it a slight pop of color. If your wondering the PSU is a SFX-L sized PSU. I wanted something on the small side if I decide to go deeper down the rabbit hole of mini-ITX. Plus 450 should be plenty for 3600 and 1070TI class card.
Gigabyte AORUS X570 Master.
This isn't 'cost effective'; that CPU will run on a nice X470![]()
My 3900x died last night. Reboot itself and post code is 07. Nothing I could do would revive it. Put back in my R5 1600 and returned the 3900x. Feels bad. I'll wait for the newer AGESA updates and the 3950X.
If that is a ASUS board that is known issue with memory failing training due to boot voltage on memory being set too low by default. If I remember right that was on the X470 boards, could be others as well.
Dang that’s some low latency ramMSI Meg Ace X570
Ryzen 3600 (Short Term Solution)
48GB of GSKiLL Trident Z 14-14-14-35 3200 RAM
EVGA GTX 1070 FTW3
1 TB 970 EVO NVME
1 TB Crucial P1 NVME
750GB MX300 SSD
250GB Crucial M500
i know $200 CPU in a $350 MB. Its a short term solution since the 3900x sold out so quickly, I plan to move that CPU over to my moms setup and upgrade her from the 1600 she has currently. Then take that CPU and use it for a plex box. For now I need a CPU so I would have a system as my current 2700x is going to a grad gift to my cousins kid this weekend.
