Post your Ryzen 3000 configs!
Discussion in 'AMD Processors' started by RamonGTP, Jul 8, 2019.
  1. DooKey
    DooKey [H]ardness Supreme
    8,038
    Apr 25, 2001
    Because I'm getting one for 10% off.
    RamonGTP likes this.
  2. matt167
    matt167 Gawd
    777
    Dec 18, 2016
    How does this sound?
    MSI B450-A Pro
    R9 3900X W/ stock Prism cooler
    16gb of Cas 14 Flare X 3200 ( 2x8 )
    Gigabyte G1 gaming GTX 1070
    EVGA 600GQ PSU
    Optical DVD burner. Might go blueray
    Fractal Design Focus G case. PSU mounted fan up to double as extra case fan, and 2 fans in the top as intakes along with included front intake fans
  3. Dadebraafsie
    Dadebraafsie n00b
    52
    Feb 27, 2017
    Gigabyte x570 mini itx
    3700X cpu
    corsair 32GB 3200 cl16
    gigabyte 2TB M.2
    samsung 4TB SSD
    noctua NH C14S cooler dual fan
    asus 24 inch 144Hz monitor
    bitfenix prodigy case
    gtx 1080 came out of the prev rig , but will upgrade to x5800 or x5900 in a few months
  4. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,291
    Jun 13, 2003
    Why?
    If you need one, get a USB external slimline that you can move around. No reason to put one in a system these days.
    Otherwise your build looks good- remember to take pictures and post your build experience and impressions!
  5. IdiotInCharge
    11,291
    Jun 13, 2003
    These haven't been announced, let alone tested- and if they arrive without DXR, well, making pre-announcement decisions will look a little silly ;).
    [just say you want to upgrade and you're waiting for the next round of high-end GPU releases, we'll understand]
  6. matt167
    matt167 Gawd
    777
    Dec 18, 2016
    I use a DVD drive quite often where it makes sense for my uses. I have a large stock of good working Dell branded Sony Optiarc's as well
    IdiotInCharge likes this.
  7. crazycrave
    crazycrave Limp Gawd
    419
    Mar 31, 2016
    I buy there with price match as they match any body any day and after State tax has been added by Newegg and others which have lost that part now from buyers as to make Best Buy the better option all the way around as said about returns if needed . also I order online like from any store around NC when Best Buy has a fresh supply of Navi = 46 miles one way but in hand = I like not waiting and enjoying my purchase with in 24 hours without 1 day air .
    Also I been telling BB that they already have the stores in the rights spots = College towns to take there business model to Micro Center level with more product to sell .. but yes they sell a lot of cpu's as 3600 are hard to keep in stock as I would of bought another one if they had it yesterday = $199 so why not ? … I saw 3 = 3700x to be had yesterday in that store at same Newegg price and they price matched my 1600 last year .
  8. thebufenator
    thebufenator [H]ard|Gawd
    1,182
    Dec 8, 2004
    Testing a 3700x on a ROG X370-F with some cheap ram CRUCIAL 16GB 8X2 D4 3200CL16 BSLT.
    So far on the AGESA 1002 BIOS, boost to 4.4Ghz works, and I have the ram running at 3600C16.
    Will be swapping to an X570 shortly and doing more comparison testing.
  9. RamonGTP
    RamonGTP [H]ardness Supreme
    7,679
    Nov 9, 2005
    A number of Youtube channels have already done this and basically, there's no difference in performance, at least as far as the CPU is concerned. As long as the VRM on those older boards is good enough to allow the CPU to boost, performance is virtually the same. There was some theories that the higher quality PCB's on x570 may, in theory allow higher memory speeds, but I have yet to see this happen in practice from what I've read and watched.
  10. thebufenator
    1,182
    Dec 8, 2004
    Yeah my main intention was to verify a functional bios, as there are a lot of reports of buggy bios's for the x370 and x470 boards.
    Also am comparing power usage and memory clocking.
  11. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,779
    Dec 23, 2001
    Here is my finished build. The shots in the dark are with the front cover off. During summer gonna run this way. Plus I love the LED lights that shine through my Noctua redux 140mm fans
    GPU is a gigabyte 1070ti
    Boot disk is the inland m2 512 GB and steam library/data drive is a 1tb team sata SSD.
    LightsOut41 and IdiotInCharge like this.
  12. primetime
    primetime [H]ardness Supreme
    5,747
    Aug 17, 2005
    think you mounted your pc together upside down!:) (been a while since i seen supply mounted on top)
    LightsOut41 likes this.
  13. Vengance_01
    5,779
    Dec 23, 2001
    Kinda like it on top as it acts a secondary exhaust point and it allows for the GPU to be on the very bottom with vents in the bottom of the case to it can receive fresh air. Plus its a SFX-L so its so cute and tiny, but Sea sonic quality. This was if I venture further down the SFF PC rabbit hole because lets face it this case is more in the realm of Micro-AXT size but super tiny compared to my old school Lian-Li PC Lancool K-58
  14. Darth Ender
    Darth Ender Limp Gawd
    265
    Oct 11, 2018
    cpu: 3900x
    motherboard: Asus Pro X570 Workstation Ace
    Kept from my 1800x :
    cooler: thermaltake water 3.0 240mm (thermal grizzly kryonaut)
    ram: 64GB of 3200mhz ram, gskill tridentZ 14-14-14-34
    gpu: asus strix rx480 8gb graphics card.
    storage: m2 ssd + 4 sata ssd's
    power supply : seasonic prime titanium 750
    case: rosewill atx mid-tower gaming pc (all glass)
    fans: 3 120mm front fans, 2 120mm radiator fans, 1 160mm rear fan. radiator fans are rpm controlled by motherboard. the rest are fixed power.
    240mm aio's are really insufficient for the 3900x. They behave more like heatpipes at that size in that there is no real volume of water to absorb temp spikes when they happen and full load @ 4.2Ghz all cores puts the temps in the 70C range. Granted, I'm using only 2 fans on the radiator. Still, system is rock stable despite temps at idle being 29C and swings to the 70's under full sustained load compiling. Half the compile times with the same hardware and software as my 1800x
    I'll be looking for a 360mm setup in the future when I go to upgrade my graphics card (when the next set of navi cards come out that will compete at the highend)
    ambient temp is roughly 77F
    idle cpu: 29-32C
    full load all cores at 4.2Ghz : 75-78C
    full gaming load for avg games: mid 50's.
    benchmarks here comparing to my 1800x setup. Done the next day on all the same hardware and software (no re-install or anything)
    https://openbenchmarking.org/result/1908102-HV-1908103HV04
  15. ccityinstaller
    ccityinstaller [H]ardness Supreme
    4,169
    Feb 23, 2007
    It's a sweet little build! I could fit like 3 of your cases inside of mine...I think I have more radspace thrn you have case space! :p
    Vengance_01 likes this.
  16. Gillette
    Gillette [H]ard|Gawd
    1,313
    Feb 6, 2005
    CPU: R5 3600 @ 4.2GHz
    CPU Cooler: Noctua NH-D15
    RAM: 32GB Corsair Vengeance LPX DDR4-3200 @ 3600
    GPU: Gigabyte 2070 Super Gaming OC (+100/+800)
    Mobo: MSI B450 Tomahawk
    Case: Fractal Meshify C
    PSU: Gigabyte GP-750H
    Storage: 500GB Samsung 970 Evo Plus
    Loving this setup. Super quiet with virtually no changes needed for fan curves, etc... Paired with a 1440p ultrawide for maximum gaming pleasure!
    Temps stay super low. In synthetics (e.g. prime95/intelburntest) CPU peaks in mid 60s C, and I've never seen the GPU break 64C even in extended Furmark runs. During real world load (gaming) temps hover in mid 50s for both. The NH-D15 barely fits in this case, but dear god does it do a good job!
  17. daphatgrant
    daphatgrant Moderator Staff Member
    17,778
    Jun 15, 2003
    I finally found one in stock this morning! (at mrsp)
    R9-3900X
    Asus X570 Hero
    EVGA 1080Ti FTW3 (already had)
    Corsair H150i AIO
    LianLi PC-O11D
    EVGA Supernova P2 1000watt
    1TB Corsair MP600 nvme
    6TB WD Black (mechanical)
    Corsair (9) ML120 Pro RGB's
    Corsair LED strips
    Corsair Commander Pro
    I'm still working on the ram though... I've been all over the place but I'm looking at this now Trident Z Neo 32GB @ 3600 CL16, if it comes back in stock.
    This is going to be a big jump from my 2600K, lol.
    ccityinstaller and Vengance_01 like this.
  18. Vengance_01
    5,779
    Dec 23, 2001
    you doing a manual 0/C or PBO?
  19. Gillette
    1,313
    Feb 6, 2005
    Validated it through Ryzen Master to start, then set in BIOS (upped multiplier to 42 and manually set voltage/infinity fabric/memory).
  20. waderunner
    waderunner Gawd
    988
    Jun 2, 2013
    Ryzen 3000, but technically Ryzen+, rather than Ryzen 2.
    3400G
    In Win BP655
    Silverstone TFX 300W
    MSI B450 itx Gaming Plus
    Cosair Vengeance LPX 2 x 8 GB 3200
    Crucial 1TB M.2
    Noctua NH L9a
    LG portable DVD 8X USB
    The case is just alright. I'd rather they sold it for $30 less without the PSU. Then it would be more worth recommending. The included 200W PSU was too loud and had to replace it.
    Also, the front panel cables are a bit short, and can't be routed around things.
    One the plus side, with only an SSD or M.2, this case can offer decent ventilation for its size, unlike some other cases built to a small form factor.
    Meanwhile, the wifi on this motherboard isn't the greatest (Intel 3168 module).
    Given all my unused PSU cabling, maybe I should have gone with a smaller case and a Pico power adaptor. I just really dislike any kind of external adapter.
    And with my 300W PSU I ended up with, I could potentially beef things up a bit down the road without power concerns.
    4aSc17J4Op3xMEdNFS9XC1gxMIN8TqoLleczJTp4R-QHFXMY6L2LUm8jWISw?width=768&height=1024&cropmode=none.jpg
    p6zBFdjehNRXrnc66cixIiramvCQdRXJMUNmH1SwA0e81GBcp2xQpFeQTXpw?width=768&height=1024&cropmode=none.jpg
    Neapolitan6th likes this.
  21. ccityinstaller
    4,169
    Feb 23, 2007
    Is that nasty blue led down the right side on all the time? That would drive me insane.
    Blue LEDs are terrible, and have been linked to sleep issues, migraine/headache/vertigo, and even cancer! :eek::eek::eek::eek::eek::eek:
    I hate the two small blue LEDs on my cable modem...my old one was green and I can't believe any major manufacturer is using blue LEDs in 2019. This is a fairly new modem, only been out for a year or so.
    I took a sharpie and colored over it. Don't care if the cable company tries to charge me down the road either!
    daphatgrant , do you want 16 or 32GB? If $200 is within your budget, I would get the same 32GB G.skilll B die based kit I have. It is running 3400c14 across (this is with 2 DR DIMMs)and will run everything at 3600 c14-15-14...
    I got mine from Newegg for $190, here is a link G.SKILL Ripjaws V Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Desktop Memory Model F4-3000C14D-32GVK https://m.newegg.com/product/N82E16820232214?ignorebbr=1&m_ver=1
    If you want to save even more and roll the dice on OC'ing the Crucial Ballistix LTs that use Micron E die seem to be able to do 3400-3600c16... Personally I think the extra $50 is worth it.
  22. daphatgrant
    17,778
    Jun 15, 2003
    Thanks for the suggestion man, I appreciate it. My preference is 32GB, budget is <$500. I've come to that sad realization that populating all 4 dimms is not really an option as the chances of hitting the advertised speeds isn't guaranteed.
  23. RamonGTP
    7,679
    Nov 9, 2005
    Your temps look perfectly fine to me
  24. Darth Ender
    265
    Oct 11, 2018
    80c is not fine. :). 70c makes me unhappy
  25. RamonGTP
    7,679
    Nov 9, 2005
    You may not like the temps, but they are indeed fine and typical when loading 12 cores. Have you looked at the reviews? These aren't exactly cool running processors even under water.
    extide likes this.
  26. waderunner
    waderunner Gawd
    988
    Jun 2, 2013
    Yes, power and hdd activity LEDs.
    But I only have the power LED active currently. And now that the build is stable, I'll probably unplug that one as well.
  27. ccityinstaller
    4,169
    Feb 23, 2007
    That's too bad they didn't use red or green or even a soft white or something. I would definitely have to unplug them.
  28. thesmokingman
    thesmokingman [H]ardness Supreme
    4,831
    Nov 22, 2008
    I just got mostly dialed out. I'm quite new to Ryzen in general but it was simple enough. It's a bit more reliable than my previous SkylakeX 7820x. I got the cpu to 4.3ghz at 1.3v. Under Prime95 avx it gets up to 77c, but in normal use max average is 55c. Interestingly even at stock, the 3900x beat my 7820x@4.6ghz in Cinebench single and multi.
    Parts:
    Ryzen 3900x
    Asus x570 Strix-E
    Gskill TridentX 3600 32gb
    Radeon VII
    Cooling:
    2 - EK PE480mm rads
    EK Velocity AMD cpu block
    EK Vector Radeon VII gpu block
    Swiftefch MCP35x pump
  29. workshop35
    workshop35 Gawd
    568
    Nov 24, 2013
    Have you tried per-ccx overclocking at all?
  30. thesmokingman
    4,831
    Nov 22, 2008
    Not yet, I've still got a bit to learn. I just clocked the memory and set up offset voltage on the cpu. Is there a guide for per-ccx overclocking?
  31. workshop35
    workshop35 Gawd
    568
    Nov 24, 2013
    Der8auer did a video on it but he used a tool that isnt recommended for everyone. You should be able to do it through ryzen master. Heres a link with some discussion
    https://www.overclock.net/forum/10-...-ccx-overclocking.html#/topics/1729680?page=1
    thesmokingman likes this.
  32. mjz_5
    mjz_5 2[H]4U
    3,611
    May 24, 2001
    I got a gigabyte master X570. Motherboard is quiet. Don’t hear the chipset fan
  33. Darth Ender
    265
    Oct 11, 2018
    asus pro x570 workstation mobo here. Chipset fan is not noticeable. Then again, I imagine it only really spins up when needed and I haven't setup something that could try saturating pci4. I imagine i'd need to raid0 both m2's and add m2 addon boards to the other slots and raid0 those before i can really tax pcie4. My old rx480 is certainly not going to make it sweat.
  34. dragonstongue
    dragonstongue 2[H]4U
    3,113
    Nov 18, 2008
    https://photos.google.com/share/AF1...?key=YzBUakJqTEM4RW9kTkoyZlduOHFvRXU3Ry01dlhB
    my camera not highest quality, very tight place to be taking them as well (no room yet to get "money shot" type pictures, but, this is what I have cobbled together for the moment :)
    -- p.s cannot afford tripod right now, suffice to say will be a long while before can complete this with a solid GPU to let me use my monitor @ the full up to 144Hz @ 1440p.
    second fan to cooler (not need, but purple LED keep crazy blue LED tolerable)
    did few adjust settings (after many times force reset BIOS, few times windows itself with no real explanation up/dump)
    manged above 3600x "stock" stats according to cpu-z valid bench check (when went to single core was ONLY below the 7900 xe part
    the top score I had (not cfv file thingy) was when forced ram @ 3600 though windows not seem to like it much (likely subtiming issue, i.e 18 instead of a 19 type thing)
    I did adjust BIOS power supply to typical load instead of auto, disable superfetch, set windows to balanced power plan (not ryzen version) among other changes
    seems to have made more stable and cooler running vs the ryzen based one, maybe a touch more "latent" though is still snappy response (even with many things open)
    CPU-z
    4085-4127 range (multi core) the 2 I list on the photos link you can see the 3 of them scores.
    509-523 single core
    seems performance not quite stabilized (course am stock not best for Ryzen 3 Agesa/BIOS)
  35. IdiotInCharge
    11,291
    Jun 13, 2003
    Put it on a tripod, set ISO to lowest and shutter speed to auto, turn off flash, and let it take its time.
    dragonstongue likes this.
  36. Hakaba
    Hakaba Gawd
    628
    Jul 22, 2013
    While my main computer is listed in the signature below (may upgrade it after moving next year), I decided to swap out the 3770K for a 3600 w/Asus TUF Gaming Plus (using Wraith Prism cooler from 2700X). I pretty much undervolted the CPU/SOC (1.3/.9) and found it is stable at 4.1 manual OC across six cores and Cinebench takes it to about 75c. I still have a few things I want to mess with before calling it good, but I feel that I am near a good baseline.
    I have messed with PBO for a few... I cannot seem to get the voltage under control, even with a -.08 offset.
  37. Nearsite
    Nearsite Gawd
    962
    Apr 21, 2006
  38. Syphon Filter
    Syphon Filter 2[H]4U
    2,590
    Dec 19, 2003
    Out of interest, why are people going with 3200Mhz RAM instead of 3600Mhz?
  39. thebufenator
    1,182
    Dec 8, 2004
    Probably cause it will still run at 3600
  40. Riccochet
    Riccochet Off Topic Award
    21,702
    Apr 11, 2007
    Cost, overclockability, availability.
    Though, cheaper 3600 has been proving to run at much tighter timings, whereas cheaper 3200 might not fair so well at higher frequencies.
