just got mine...finishing a file server build with it....few light mods...changed fans to yateloons . need to work on teh wiring
nice mods. looks very nice. i also have an a05b and a rocketfish![]()
do you know the name/model number of that fan/hdd drive combo in the 5.25 drive bay?
thanks
yup...i have this one http://www.performance-pcs.com/cata...duct_info&cPath=130_151_257&products_id=23025
MODEL: EX-34N
blah, blah, blah
You know, I'm all for being anal and hiding wires and such, but the main point is that you want to have a clear path for air to enter and exit your case while extracting as much heat as possible from the components. Your setup looks to have all the wires pushed back against the rear wall so any changes would be purely cosmetic...in a windowless case.
Long story short, good job with what you have, don't worry about what you don't - looks damn sex to me.
THB I don't know how exactly the case is laid out but is there room behind the MB tray?? If so you can cut holes and route around and through those or maybe just consolidate 'strands' of wires (if that makes sense) for a cleaner look. Some folks out there are REAL creative and find ways to hide wires that is just impressive.
yes some people do...but as far as mine goes....it gets the job done..temps are good.
Thought I posted mine in here but guess not. Here it is:
yes it is worth that much.... it's a real lian li case
i paid 60 for mine and others paid as low as 45...
you can put up to a 4x120mm rad in the top
there's no need for a grill on the rear fan, its just impeding your exhaust.
WHO STILL SELLS THESE CASES??????
USE THE SEARCH FUNCTION!!!!!WHO STILL SELLS THESE CASES??????
