stainremover
- Jul 19, 2008
i meant how did he mount them? is it a special device or something?
it's the cpu cooler that can accept 2x120mm fans
no idea to any of those questions... i'd say test test test
Seeing this thread makes me want this case more and more.
is it a good idea to cut the side panel with a dremel or would it look ugly?
How good are you with a dremel?
i have only used it a couple of times. unfortunately i have no use for this case, thats why I'm going to practice with the case.
What state do you live in? I might trade you for it....
I'm in Idaho.
Anyone have the specs of the 3x stock 120mm fans that come with these cases? I am just curious how much noise they are supposed to be making, as I would like to get some fans that push more air without being louder.
I replaced all of mine with my Antec 120mm Tri-cools. The P5Q Pro SUCKS for fan control. Rocks for everything else ... anyways.
I recommend these:
For a budget, Yate Loons are great.
Here's a few more that really do well:
http://www.frozencpu.com/products/2...Turbine_8939CFM_Fan_-_BLACK.html?tl=g36c15s60
90cfm @ only 32.5db. Very good fans.
These fans are amazing. Absolutely AMAZING. Too bad Newegg really kills you on shipping. $7 to ship a $9 fan.
Anyways, these are great fans:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054
130cfm - A BEAST. It's quiet when not at full bore, too.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185060
Incredible fan for $9. (too bad about the shipping ... agian.)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185059
Those are some good suggestions for ye. Yate loons are good for cheap, but I don't know where to find the ones that people rave about. All I see are the lower CFM ones. I like at least 80cfm or it likely won't push enough air for my tastes.
In my search for a Rocketfish Full Tower, I walked into a BB near my school and they had the item tag on. I was so excited but when I asked them to check their inventory, they said they had 1 in stock virtually but none physically. Neither did any BB in my city. I shall try another city this weekend.
The more I see your mods, I more I want this case!!!
Which section does BB have their Clearance items in?
Yeah. That looks a lot better. I noticed you put a fan on the very bottom like I did. Is yours intake or exhaust? In my cooling system it works as an intake fan. Makes for a fairly even pressure environment the way I have it setup.
BTW, I put two 60mm fans on that top grill above the 120mm exhaust fan on the back. They actually pull out quite a bit of air, I would say as much as the 120mm below it, or at least close. Easy mod.
ill try that later on, but right now, this is fine
and that lower fan is an intake fan.
so ive got my 38mm antec tricool in the front, and the fan that used to be there on the bottom both taking in air
and it lowered my vid card temp's by 6c, it rocks
Yep. Totally worth it. Gotta raise your case off the ground a bit. I've got mine on a little stand-thingy attached to the desk. You'd be ok if you didn't have it on carpet, though.
Post a pic when you get your side window!
ive had my side window on for ages now, lol let me find a picture of it.
here it is.
Yeah... but with the cable management, silly.
I noticed you have a push/pull setup on your TRUE. What do you have the second fan connected to? I would assume one is connected to the mobo. Which one? The one pulling air into the fins, or the one exhausting it?
I am planning on adding a second fan myself soon.
both are connected to my fan controller acctually
they both run @ 100% my fan controller will run it at.
Noise?
they're both yate loon low-speed fans, and they're almost silent.
the only noise from my system is lian-li ones that came with it, and the antec one in the front, and even then, all it makes is a slight wirring noise.
nothing too annoying.
I've got a Cooljag 120cfm fan. It pushes a TON of air. I don't know if I would fix the speed of my fans. I like to be able to crank the fan up a notch when I'm really pushing the processor or stress testing .... or playing Supreme Commander. From 50% to below the cooljag is silent, but when I need it, it cranks up and really pushes some serous air.
Does it hurt anything to have a second fan that doesn't match, not running the same speed on the other side? I would attach it to my fan controller so I could raise and lower it as needed. Are there any problems with doing it this way?
i dont know for sure, but if anything, youll probably want the pull fan running faster than the push fan in a worse case scenario.
otherwise, you can buy some yates for ~$3.50 off of jab-tech and you can just use those.
