filthysanchez
- Jul 19, 2006
Mine had one the other day
What size are the stock fans and where are they placed?
Here is mine. Made cut outs, rerouted the wires behind the MB tray(duck taped and the side panel miraculously fits over the wiring!), removed HD trays, put some wheels on it, and put fingerprints on it as well. Plan to get a 3.5 to 5.25 hard drive enclosure, to run two 250GB HDs in Raid 0...then use the current 500GB in the case as an external esata drive. Still waiting for the 4870x2 to come in.
Very nice. Did you have to take apart the mobo tray to paint it??
It comes with three 120mm Lian Li branded fans. They are three pin and are decent fans, fairly quiet. One is placed normally for rear exhaust behind the CPU, one is in a special vent slot that you install over the graphics cards, and the third is up front behind a filter, pulling in air for the hard drives and for the rest of the case. The case stock is quiet, but doesn't pull in enough air IMHO.
In one of the cases I thought I saw a 120 mm fan inside 3 5.25" bays. Also will the Lian li's pc-7x mod for 3x 120mm up top fit on the rocketfish?
Dang, Is the stock top panel flat on the bottom without any little support structures on it, so a person can drill 3 120mm holes for a rad? also could it fit a 4 120mm rads on top?
I also ordered the Kama Bay cooler for 20 bucks. Need some more air intake. When I shut the lid on this thing the main intake for air of the case is going to first gather some nice heat from my hard drives. With the Kama Bay cooler it'll get some nice fresher air from the front.
That has 7 5.25" bays right? because if there is I am going to get this case. dual 120mm rad at front, triple at top, Btw will it hurt the flow if you make the radiator upside down with the barbs at the bottom?
Are you able to remove the door without breaking the hinges?
so far with an 80f+ ambient temp i am getting about 35c across the board cpu/chipset/gpu not bad, also ive dropped HD temps with the addition of the second 120mm fan to about the same 35c range before the second cage hd's were creeping up to high 40c's
update on mine, once again sorry fpr crappy cell phone pics
i measured then drilled new holes for the HD cages and reversed them, i also spaced them out roughly 2in apart for a 120mm fan inbetween them
then i reversed the mounting of my rad, instead of the barbs being near the front they are now near the rear
mounted my ek multi option res brackets to the mobo tray
couple pic's of leaktesting
then added capful of zerex super coolant water wetter and about 15-20 drops of feser black UV dye
Alright, here is an update on mine. Finally got the 4870x2 in, put the side panel on finally, and I also drilled four new holes to reposition the hard drive rack. Still going to be installing a slot cooler and the karma bay cooler when it gets in.
The Kama Bay cooler comes with a wimpy fan - quiet, but wimpy. I replaced it with an evercool aluminum fan. Matches the inside of the case nice, and pushes a lot of air. Surprisingly quiet, too.
Notice the slight gaps around the edges. In order to get a completely tight fit, you have to order the Lian Li branded bay cooler, but it's 10 bucks more expensive. I saved the ten bucks, and it's not a big enough gap to bother me. It's not nearly as noticeable in real life as it is in this picture. I think the front of my case looks rather nice right now.
[/IMG]
subscribed ... getting mine on Saturday ...
I have powdercoat wishes and waterjet dreams for it.....
i think i'll just rock it stock for a while though .... it looks really nice stock IMHO
yea, it sure does, but ive already put a window on mine, and put that cross-flow fan in the upper part of my case as a blow-hole.
it's much quieter that way it seems.
any pics?
ill get mine up as soon as the camera charges.
these are some pics while moving everything and before wire management.
the sidefan didnt fit with my accelero so i just moved it down to cover some wires.
more pics coming with updated wire management
EDIT:
here are the pics with wire management, and without my videocard b\c i had to RMA it
