ranviper
- Oct 4, 2010
Did some cleaning up, and finally took a pic of the "business" end of it. Looks good to me tho!
It's a canyon 595.
What a mess! and you could do a lot better with a little work. Cases don't have to be $200 in order to have good cable management.
In cases where there are no cable management holes, the key is routing everything between the motherboard and the backplane which can be difficult.
that and a drill with a hole bore to the mobo mount plate can do wonders. Just did that to mine before the paint. Pics soon to come after its finished ^_^In cases where there are no cable management holes, the key is routing everything between the motherboard and the backplane which can be difficult.
You need cable management holes to keep thing tidy? Orly?
Clearly, the LEGO Clone Trooper is the key to cable management.Here is my older Apollo with no cable management options what-so-ever.
^ Very neat. One thing you can do is flip the drives around so the cables are behind them. CPU is cooled passively?
Thanks man! The drives can not flip around, caused by bracket design I am thinking about using a cover to hide the cables
Yeah, my CPU is cooled passively (it's i3-2100)
