D
Deleted member 82943
Guest
is there no fan blowing air into the nivida gpu? that might be a nice addition
flawless computer though it is really nice
that is seriously impressive
That color scheme is pretty sick man. I like it.
amazing! i think you should spray paint some or all of the pci slot covers purple too. wiring is flawless though.
Actually thats Paracord, its much cheaper and ships from the US. BTW I already got some sleeving for sata cables Next step is getting fully modular psu which will be sleeved completely
snip
Here you go, my latest build is a POS Thermaltake Chaser Mk1 Watercooled 2500K at 4.9ghz and 7970 at 1270x7000 (soon to be CM Storm Trooper)...
Will post back then...
snip
whats wrong with that case? looks nice to me. painted inside, toolless everything, rubber grommets and wire routing space, room for a rad up top... only thing i dont like is those stupid feet but they look like you could probably pull them off.
i'll be impressed when you braid the gpu power cables together.
Will post mine in a day or two, in the process of moving everything in to a FT02BW. No individually sleeved wires yet, though I'm tempted to give it a shot. I am however a bit leery as my PSU (Antec TruePower Quattro 1KW) uses big thick rubber / plastic rings around the cables at the beginning and ends of sleeves rather than heatshrink, and I'm imagining those suckers will be particularly miserable to get off. That and I'm fairly sure I'd have to open it, voiding whatever warranty may remain. I might just use individually sleeved extensions but that gets pricey vs. ordering a bunch of red or black paracord and heatshrink, and it seems like a cop-out.
Ya, new Switch 810. When it comes to wire management, I would have made the following changes.
Moved the PSU mount 1/4" closer to the windowed side panel. This would give more space between the PSU and mobo tray for routing wires behind the PSU. In the picture that lone wire bent towards the back of the case was one hell of a tight fit...1/4" more space would of made it a ton easier.
I would have added 1/8" more space behind the mobo tray...with 1/4" making things absolutely dreamy. If a 4 pin molex gets turned perpendicular to the side panel, you won't be able to close it. 1/4" of an inch would have solved this problem....maybe even 1/8".
There are no wire tie locations on the back of the mobo tray towards the front drive bays. All of the tie down points either run along the top of the case or are directly behind the motherboard. Having some more by the drive bays would have made routing my Sata data and power cables SO much easier. As it was, you just have to mash them flat and put the side panel on really fast....not something I enjoy doing on a case with so many other good wire management features.
No rear fan?
Apevia Blue Full Tower,
Blue and White parachord
ECS A885GM-A2 AM3 MOB
Powercolor AX6850 1GB x 2 Cross fire
HEC XP1080 800W PSU
AMD Phenom II x 6 1055T 2.8 Ghz 125W
Patriot G Sector 5 2 x 4 Gb DDR3 1333 RAM
Hitachi 2 TB SATA 6.0 Gb/s 5400 RPM =(
Windows 7 Home
Antec Performance Max 92mm CPU Cooler
Acer S202HL bd (L-ET.DS2HP.001) Black 20" 5ms Widescreen LED Monitor x 3 EyeFinity
<a href="http://s1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/?action=view&current=2012-01-22164915.jpg" target="_blank"><img src="http://i1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/2012-01-22164915.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/?action=view&current=P1000259.jpg" target="_blank"><img src="http://i1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/P1000259.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/?action=view&current=2012-01-14135855.jpg" target="_blank"><img src="http://i1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/2012-01-14135855.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/?action=view&current=2012-01-14135101.jpg" target="_blank"><img src="http://i1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/2012-01-14135101.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/?action=view&current=2012-01-22164832.jpg" target="_blank"><img src="http://i1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/2012-01-22164832.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/?action=view&current=2012-01-14135957.jpg" target="_blank"><img src="http://i1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/2012-01-14135957.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/?action=view&current=2012-01-14135500.jpg" target="_blank"><img src="http://i1261.photobucket.com/albums/ii589/PaulFSemicolen01/My%20Compy/2012-01-14135500.jpg" border="0" alt="Photobucket"></a>
HTML Links & IMG tags don't work.
Works now, And might I say that is a very clean and tasteful rig.
Nicely done, but that hard drive seems pretty lonely...
So, who makes the best individually sleeved cables?
