Oh yeah, that looks real safe, a power supply on a FUCKING CARPET. I'm sorry but you sir are an idiot. You may want to rethink what you have done, maybe buy a different case, or fit the stuff you have in that one, as there is PLENTY of room. Honestly where did you come up with the ingenious idea to put a power supply on a fucking carpet????http://content.screencast.com/users/Trieu/folders/Jing/media/6b386811-b60b-4e65-9c9d-2db397003ff9/2008-10-23_0044.png
^ OMG LET'S FREAK OUT OK?
I'm down with freaking the fuck out. That is almost as bad as what will happen when the large hadron collider forms black holes and sucks our universe into it!
Maybe you should read ? He said :
hahaha thats my buddy, funny thing is that his systems been done for months
So idiot is not vegetto714, but his friend, if someone is idiot at all.
earm wins as far as the inside of the case goes, but the wiring on the outside? LMAO!
Topic says, rate my cables!
Rate: -1
I'm having trouble cleaning up those sata cables, they are really stiff because of the shielding inside, and I can't flip the drives because they will hit the back side and break the PCB... Almost killed a drive testing it, it worked before when I had angled connectors!
ATX connector is zip tied to the rear fan, so it's not going anywhere. Normally I have these kinds of configurations where the ATX connector is located behind the cpu-cooler, but I couldn't afford a more expensive board at the moment, will upgrade later.
My wifes rig: (Lian Li PC-A05B)
No matter how stiff the sata cables are, it looks like they will bundle up nicely and tuck under the drives as a group. Then, bundle them again as the connect to the drives.
If you used the bottom drive bay instead of the top, you may be able to run the HD power cables in the behind, then down the front to connect to each drive.
Example:
http://img156.imageshack.us/img156/8669/3dscn4486smw7.jpg
Just gather them all flat together and ziptie them. As they come out to the drives, gather them again all flat together and ziptie them just below the first drive they attach to.
What HSF is that on there?
Awesome work! Hope she appreciates it!
Nice! I've been looking at that LP Jr, wish it was a little less $ because it is one hell of a sweet mATX board. No way I am gonna fork out a full size board price for a mATX though. Still, you never know, if you must have a mATX and need the best performance... I see little other choices on the market.
I really like the TJ08, used one for a retired lady client. Looks so sweet and elegant on her desk. I just wish they were nicer inside or all aluminum. If I got one for myself, I'd paint the inside and loose the HD drive bay -- putting the HD in a 5.25 adapter. It would open up the interior making it look cleaner, maybe improve airflow a bit (airflow is already great).
What plans do you have for yours?
Woah!
I still have Epos an 8KDA, not the +.
Can't force myself to part with it! Easily does 325MHz FSB with a Sempy 3000 (I think) in it. I liked the temperature and voltage sensor report at POST, I wish more new boards did that.
I've got a number of cuts that I want to do to the interior to improve my wiring to start with. Once the cuts are done I will be removing the 3.5" drive cage, my hard drive is already mounted in the 5.25" cage but it's ghetto at the moment and I'll be doing it up properly eventually....
It's a Coolermaster GeminII heatsink. Usually, you will see (2) 120mm fans bolted on.. However, my wife's power supply was simply too big to allow (2) 120mm fans. So, I took off the bracket and used (4) very small zip ties and secured (1) 120mm fan directly to the heatsink. Temps are still VERY good as that fan moves about 89cfm.
I spent the afternoon today, working on my new Lian Li PC-A05B (bought two of them - one for me and one for my wife). I had to mod the front lower plastic bezel but I managed to get my friggin monsterous Enermax Galaxy 1K psu in this little case!
mine is now running at 6*c lower on the core since reading this post and taking all your advice! cheers!!!!
I just wanted to post a comparison of my first wiring job to my current one. I found it kind of funny.
Here is what abspc sent me: (minus the thermaltake heatsink, that I installed.
This is what my wiring was like went I built my first computer. Same specs as the old one in my sig I think, maybe a little bit different.
This is what it looks like now, the NEW one in my sig though. Same case.
Yeah, I posted it already but I just wanted a laugh
My old computer is in my moms room in an antec 900, I will try to take pics later of my wiring job... I did it the other night, it looks decent but that case is horrible for routing wires. There is nowhere to hide them. NOWHERE! You can't route them behind the drive bays, as there is no "behind the drive bays", you can't hide them on the back of the case, because there is noway to route them there. Whatever, I'll show my progress so far.
My weekend initial build of PC-V350... Not really a nice result, but so far it doesn't make problem with temperatures. Maybe if i will get more time i will rewire it :
You probably don't see the Xonar DX between graphics card and CPU cooler, or T-Balancer bigNG "glued" to inner side of front panel using Alphacool Velcro.
I have always wanted to dive into a SFF build but never have the extra cash to put into it, but yours my friend is pretty descent.
You'd have to cut the sleeve off and flatten the cables out so they can go under the mobo without bulging it. Tower cases are so much easier to work/manage
