Here's mine.
[IM]http://img171.imageshack.us/img171/3058/img0633ec7.jpg[/IMG]
http://img171.imageshack.us/img171/6703/img0629dx9.jpg[/IMG]
http://img171.imageshack.us/img171/2337/img0631ky7.jpg[/IMG]
that looks amazing. Im not very educated with water cooling, but dont those sharp corner elbows slow ur flow some?
Not a bad "work"-station Andrel. Is that TT V1 using pushpins? My Xigmatek 1283 is, but it's "only" 660G total & I have a ziptie holding it a bit. Looks like you've worked on the cables somewhat, so I just wanted to mention your HSF.
Would that stuff they put in car trunks to kill vibrations from subs work? I don't remember what it's called...
Illuminate-not sure if that's the best foam to use, might be creating some temperature problems inside your case with the thickness of it. Might wanna try the akasa insulation that andrelmaraujo is using.
Good job. But why do you never put on the back of your case?
Son, you gonna drive me to drink'in, if you don't stop modd'in that OEM Link'in (case)!
Incremental improvements! Some innovative and unique ideas! By the time you move into a new case, you'll know exactly what you want to do. /cheer
illuminate, why not pickup a rubber grommet to line the inside edge of the cut near the PSU instead of using the ghetto looking tape?
Overall a very nice improvement and a lot of work done, but more could still be done to clean things up and polish up the look of the interior.
I bring you my "new" rig. Screw cable management!
Grommets are a little hard to find here in Korea, that is why the tape is there. I might have found a place to get some though.
Thank you! You're right, it does need some touch-up work. Matching PCI slot covers, some dusting, grommets, and maybe even some hot water to get rid of the black dust from over the years. Thanks for pointing that out!
Most of the time the only way to get rid of old dirt and heat marks in a case is to paint it.
Grommets can be found inside other things... like the garbage cans of automtive shops, an old junk PSU or other electronics.
PCI slot covers you can salvage from old PCs that people will give away if you offer to take it to recycling for them.
I just got done redoing some of the cables in my case... I still have no idea what to do with the blob of cables near the cd drives at the top... Theres nowhere to put them!!! Unless I drill a hole ( like some others here have done), which is most likely not happening.
I am going to work a bit more on this tommorow hopefully.
pics turned out a bit... blue?
*cut out pictures*
Yeah it's a lot of pictures, I know.
edit: yeah, the pics look bad... I'll retake them 2morrow. Too late now.
Kind of astonished that you can build a rig like what you have in your sig but fail at imageshack =.="
Cables? What cables?
